AFFiNE, die Next-Gen Knowledge Base: Notion-, Miro- & Monday-Alternative in Open Source
  • 0 Antworten
say_hello
say_hello
Dauer-User
270
AFFiNE, das neue System, das Miro (collaborating-whiteboard) und Notion (note-taking) und Monday resp. Trello. (Projektmanagement) ablösen will - es kündigt an die Integration der Features beider Systeme zu bieten - und quelloffen zu sein.
Links: AFFiNE:There can be more than Notion and Miro. ::
Interessant: eine Kombination von Notion & Miro-Features zu haben, und gleichzetig ein Open-Source-Projekt, welches offen entwickelt wird.
Zentraler Ansatz: das Open-Source-Konzept, welches komplett anders ansetzt u. sogesehen radikal anders ist als alle o.g. Projekte:
Motto: Open-source, privacy-first,and always free. Built with Typescript/React/Rust GitHub - toeverything/AFFiNE: There can be more than Notion and Miro. AFFiNE is a next-gen knowledge base that brings planning, sorting and creating all together. Privacy first, open-source, customizable and ready to use.
AFFiNE is the Next-Gen Knowledge Base to Replace Notion & Miro. Open-source, privacy-first, and always free. Built with Typescript/React/Rust
Projekt: AFFiNE:There can be more than Notion and Miro.
Demo:
- AFFiNE - All In One Workos
- https://pathfinder.affine.pro/workspace
weitere Links, Quellen, Ressourcen::
AFFiNE is an open source alternative to Notion & Miro and can help build knowledge base.
Click Here to know more: GitHub - toeverything/AFFiNE: There can be more than Notion and Miro. AFFiNE is a next-gen knowledge base that brings planning, sorting and creating all together. Privacy first, open-source, customizable and ready to use.
ein Artikel auf Medium: AFFiNE: The Next-Gen Knowledge Base to Notion and Miro
community-page: AFFiNE
Twitter: https://twitter.com/AffineOfficial
AFFiNE - FREE, Open Source, Privacy First Monday Notion Miro Alternative
ses
medion1113
medion1113
