[ROM][JUN 28] ViperOne 9.0.0 | 1.40.401.8 | Android 5.0 Sense 7.0 | Venom Tweaks
  • 10.676 Antworten
Ok, Sportlerwette....
Leute per OTA kommen die ganzen anderen FEATURES auf 2.5.0 soon....
Also lohnt es sich 2.0.0 gleich zu laden.
Trotzdem war das nicht der ganze Changelog meiner Meinung nach, man werde es merken.
Ne ist es auch nicht , bei xda habe die schon gesagt war ein Spaß
Doch das war er, per OTA werden die Features kommen auf 2.5.0, laut dem Entwickler, kann aber auch ein Spaß sein und sie hauen alles aufeinmal raus, was ich mir denke
:scared:
ViperOne 2.0.0
* Updated to new 2.24.401.1 base
* Updated to new Aroma 2.70B6 Installer
* Added tweak to display traffic speeds in status bar
* Added Hide clock weather on lockscreen
* Added toggle to hide initial page hints on AOSP lockscreen
* Added toggle for small 3 dot menu on top right of some apps
* Added Custom Autobrightness
* Added kernel settings to Venom Tweaks
* Added CM Quiet Hours with white list to allow apps to notify
* Added Quick Unlock (toggle to automatically unlock AOSP and Sense lockscreen when correct pin/password is entered)
* Added Venom Pie
* Added toogle to force maximize widgets on AOSP lockscreen
* Added toogle to allow all widgets on AOSP lockscreen
* Added instant update of summary while sliding on sliders
* Added hide LMT launcher icon from app drawer -> LMT launcher icon hides itself..but requires one reboot.
* Added toggle to hide clockweather widget on lockscreen
* Added 5x6 app drawer grid size
* Added Venom Boot Animation
* Added 5x6 App Drawer grid size
* Added tweak to hide beats icon when music is playing
* Added All Contacts button to Contact Widget
* Added tweak to activate native EQS by dragging the edge of the status bar (thanks CM!)
* Added kill all buttons to AOSP and Sense Recent Apps
* Added hide unlock hint on Sense lockscreen
* Added additional inactivity lock timeouts: 5, 10, 30, 60 seconds
* Added ability to configure rom with stock or Viper look
* Added HtcContacts with disabled mask (for low res images)
* Added Htc messages Widget from HTC Butterfly
* Added lockscreen mod to always show widget even when lockscreen notification appears
* Added CM tweak to flip to notifications/settings by dragging bottom bar
* Added ability to configure device with stock or Viper config (or migrate existing tweaks)
* Added new VenomSideBar: fixed errors on menus, recent apps, flashlight and added QuickSettings and clock
* Added HtcContactWidgets with 4x5 and 5x6 homescreen support
* Added tweak to enable/disable horizontal EQS and Quick Launch bar for the noobs
* Fixed double clock/reapearing clock when using AOSP
* Fixed 3 fingerservice fc'ing when expanding statusbar
* Fixed custom button actions bypassing security on lockscreen
* Fixed cm brightness control not beeing able to deactivate
* Fixed some system notifications not showing on lockscreen (calls/sms)
* Fixed volume down to turn screen on turning screen off again when volume down to screen off ativated
* Fixed preview of power+home screenshot not showing
* Fixed SMS/MMS Screen On regardless of Notification Light setting
* Fixed HtcWeatherClockWidget with 4x5 and 5x6 homescreen support
* Fixed status bar background color not being applied at startup
* Fixed GPS and Alarm icons showing even when set to hidden
* Fixed APM mobile data toggle
* Fixed Header data color not sticking on reboot
* Fixed Longpress Toggle (When displaying Both HEQS and QuickLaunch)
* Fixed Tweaks profiles are now saved on sdcard
* Fixed minfree settings now set to stock for everyone
* Fixed status bar crash when reording EQS settings
* Fixed problem with long city names in notification screen weather bar
* Fixed backkey not working on camera/emergency screen when security pattern/pin enabled
* Updated Venom File Manager icons (Thanks to Rayford)
* Updated Venom App Installer icons (Thanks to Rayford)
* Updated Small Apps icons (Thanks to Rayford)
* Updated Play Store to 4.2.10
* Updated all other APKs
Haha da war jemand schneller -> löschen .
Was hab ich gesagt, das war von ARHD.
Kann mir jemand sagen wo die Einstellungen von Vonem Tweaks gespeichert werden?
Im Venom ordner auf 0
Ja, das dachte ich mir. Ich habe jetzt zwei Profile angelegt, aber die tauchen nicht in den Ordnern auf.
Wo ist der Download Link zur neuen Version?
Venom/Profiles , dort sind meine alten einstellungen
Noch nicht freigegeben
Reaktionen: MarkusK
Ah - gefunden. Ist unter Profiles, aber die Dateinamen werden nicht angezeigt, sondern die Profile werden schlicht durchnummeriert. Danke!
Wenn du das dann in die Tweaks portierst dürfte dann auch Name stehen ;)
Reaktionen: MarkusK
davon gehe ich auch aus, wird vermutlich in der csv stehen. War nur verwirrend, dass der Profilname nicht angezeigt wird :)
AH - endlich 100 :D
Reaktionen: wirevo
hoffentlich kann man ma diese systemfarbe ändern die stock hell blau ist...
Habe grad irgendwo gelesen DL sollte so ab 20 Uhr online sein
Reaktionen: Michael San
Haben se selber gesagt in ca 2 Stunden.
Rom is uploaded...we just need to get the mirrors up, so that you wont crush the servers.
Be a bit patient for another few minutes guys.
Ja seit 19:43 Uhr....
