[ROM][JUN 28] ViperOne 9.0.0 | 1.40.401.8 | Android 5.0 Sense 7.0 | Venom Tweaks
  • 10.676 Antworten
Okay, vielen Dank für die Info!
Jungs und Mädels heute im laufe des restlichen Tages kommt...........
ViperOne 4.3.0
  • Fixed OutOfMemory error when customizing icon packs (e.g. MIUI 5 or other packs with lots of images)
  • Fixed customizing icons loading pretty slow - loading icon pack will just run one time when you select it and not each time you select an app to customize
  • Fixed wifi activity icon requires statusbar reboot
  • Fixed Verizon boot issue
  • Fixed hiding am/pm for statusbarclock back missing in venomtweaks
  • Fixed an issue with some market icon packs not workig (e.g Pop UI)
  • Fixed custom appdrawer background in hub not applying properly (previously manually checking custom appdrawer background in venomtweaks was required)
  • Fixed bypass lockscreen also bypassing initial PIN lockscreen
  • Fixed missing lockscreen hint
  • Fixed profiles in VenomTweaks
  • Fixed small 3 button behavior (doesnt work with all apps, you can test it with chrome)
  • Probably fixed VenomFileExplorer FC issue when deleting files
  • Increased the font sizes for the fonts view
  • Capacitive backlight strength accepts values from 0-100 now (credits Patrics83)
  • Quiet hours are back
  • - added dim option (disables led, flashlight, blink notification)
  • - added ring + whitelist option (Contact whitelist now there)
  • Added option to replace the open appdrawer shortcut with a custom application
  • Added all apps option to prism menu,useful if you use above tweak
  • Added some higher flash speed entries for flashight/capacitive backlight notification
  • Added media volume up/down actions to 3 finger swipe gestures
  • Added option to disable received notifications in Messages/Settings/SMS
  • Added tweak to show next alarm on lockscreen
  • Added button mapping action to show all apps
  • Added ability to customize status bar notification text/icons/action buttons/action text colors
  • Added ability to customize notification action dividers
  • Added hiding navbar in appdrawer
  • Added tweak to double tap status bar to turn screen off
  • Added tint all statusbar icons
  • Updated Nova and Apex
  • Updated Google Play Services and deleted old libs
Reaktionen: cabpit, Zino, Tobse-80 und 2 andere
Schon mit KitKat 4.4.2 ?
ich denke mal nicht, neue bases dauern bei viper immer etwas länger..ausnahmen bestätigen die regel :D
aber wie ich im thread von insertcoin gelesen hab, gibts dort wohl noch probleme
Nein keine neue Base, dieses Update ist das letzte auf der aktuellen Base....
von jan
...who saw that one coming? (-:
This will be the last update on this base...4.4.2 is around the corner I heared (-:
Also @Turge is on vacationf or 1.5 weeks, @hansbert busy with exams at uni and I'm also two weeks away from sunday on.
Update will be out today when I don't mess up..stay tuned.
Der HTC bug mit dem Media link HD ist wieder nicht bei. Naja vielleicht bei der nächsten base.
Habe gerade ne Nachricht bekommen das heute die 4.3.0 kommt. Direkt aufs Display. Mt XDA Link. Hatte ich noch nie. Ist das n xtra Service wenn man spendet ?
Geklaut im XDA Thread
Das kriegt soweit ich weiss jeder, haben auf jedenfall viele bei xda.... Kann dazu persönlich nix sagen, da ich noch immer auf der 3.5 hänge :D
ich hab nix bekommen
Also ich habe diese Nachricht auch bekommen ohne gespendet zu haben. ;-)
gibt ne kleine überraschung beim update.. in den tweaks.. ^^
Fällt die Überraschung auf? Wenn man nicht so gut Englisch kann übersieht man dann die Überraschung?
fällt auf :)
:-D
Ich muss nach jedem Neustart Pie manuell starten und Logo2Wake wieder ausschalten, ist das normal?
Also das starten von Pie muß ich auch immer machen wenn das Handy hochfährt. Früher war das automatisch. Vielleicht kommt es ja wieder...
Puff...... Und es löste sich in Rauch auf :)
Quatsch, bin gespannt was neues drin ist.......
Der Media Link geht noch immer nicht oder? Zumindest steht nichts im changelog
Ich glaube Media Link ist kein Venom Bug sondern ein Bug der Rom Version an sich... Wenn das Update für alle verfügbar ist und nicht nur die dev Version, dann sollte der Bug entfernt sein....
Reaktionen: Peri25
