[ROM][JUN 28] ViperOne 9.0.0 | 1.40.401.8 | Android 5.0 Sense 7.0 | Venom Tweaks
  • 10.676 Antworten
Moin, nun steht es ja bei XDA #3 der neue Changelog für 2.5.0 , wird also bald kommen...
Reaktionen: MarkusK
Da es ja nicht mehr den Followern vorbehalten ist, stelle ich das hier mal rein :)
ViperOne 2.5.0 (Soon)
  • Fixes
    • Fixed always show widget tweak
    • Fixed folder size
    • Fixed fake IMEI
    • Fixed Lockscreen notifications - all notifcations should work now, including hangouts, facebook, etc.
    • Fixed Superuser app - can no customize optionsf for different apps
    • Fixed volume button when screen off and listening to music
    • Fixed Send button disappearing in SMS app when hiding keyboard
    • Fixed secured applications installing to /mnt/asec - Swiftkey/Swype will now remain default keyboards when installed
  • Additions
    • Added ViperOne down animation
    • Added Save/Experienced/Expert UV settings (-50/-100/-200uv)
    • Added Prism icon theming compatibility with Play Store icon packs
    • Added Sense icon underlay in launcher, app drawer and lock screen
    • Added app drawer button theming - Choose from icon packs or self made appdrawer icons from sdcard
    • Added navbar theming - Choose from icon packs or self made navbars from sdcard
    • Added theming for lockscreen lock icon
    • Added customizable bounds to icons when using underlay
    • Added customizable blinkfeed/appdrawer mappings for clock/weather click
    • Added custom lockscreen shortcuts - lets you configure lockscreen shortcuts from the sense dock independetly
    • Added custom position of appdrawer icon
    • Added CRT or fade effect screen on & off
    • Added Back Light Notifications/Flashlight Notifications (independant of kernels) with ability to customize apps
    • Added custom folder icon/folder bg transparency (0-255 steps)
    • Added limit to 255 apps in folders
    • Added new T-Mobile APNs
    • Added Volume Up/Down actions to camera: No action, default system action, Focus, Shutter button, record video
    • Added status bar transparency with fade-in animation
    • Added more granular Corporate Exchange policies
    • Added Sense Launcher and System animations (fade, fly-in, etc.)
    • Added PIE tutorial to Tweaks app
    • Added ability to display all widgets on HTC/AOSP Lockscreens
    • Added the ability to turn off delivery report notifications to SMS App
    • Added Smiley button toggle to SMS app
Ordroid schrieb:
kernel:
alle vier core auf 1350
undervolt 750 min
gpu 400Mhz
gpu governor simple
thermal settings: default
manages cpu cores: battery savings
in den viper tweaks eingestellt
reed ahead size 3072 Kb
gpu : stock
cpu min 384
cpu max 1350
cpu screen off max 384
glabal voltage -50mV
und haben die Einstellungen bisher jemand getestet ?
habe bisher noch nichts gelesen wie es bei den anderen bei der einstellung war,
und ob es zu empfehlen ist
  • Fixes
    • Fixed folder size
    • Fixed fake IMEI
  • Additions
Ist es dann Android 4.3 oder noch 4.2.2 ?
Gesendet von meinem HTC One mit der Android-Hilfe.de App
ist noch 4.2.2
4.3 dauert doch ne weile.
Jan schrieb mal, wenn ich mich recht erinnere, von beginn bis ende beta test vergeht rund 1 monat.
und die aktuelle 4.3 Sense ist keine entgültig version.. sondern nur ne art vorabversion
Ich habe sie getestet und bin zufrieden. Bilde mir ein, dass mein Akku mind. 80% besser länger lebt.
hast du bei Trickster MOD auch was eingestellt oder es so gelassen ? zb ob du intellidemand hast, weil davon steht da ja nichts,
aber ich denk schaden tut es nicht wenn ich es anmach.
kenn mich da nicht so aus deswegen frage ich lieber
Doch, ebenso Westwood und co habe ich eingestellt.
wie macht man den Full Theme PCB Blue drauf ? ich habe es über Recovery geflasht aber es hat sich nichts verändert oder den Tweaks habe ich auch nichts gefunden
Viper 2.5 ist draußen. Erstmal nur für diejenigen die der Viper "Folge leisten".
Update 2.5.0
für alle Follower bei XDA
Reaktionen: MarkusK und Holli33
So ist drauf , installieren hat alles geklappt ohne Probleme. Morgen gibt's ersten eindruck.
Kann mir jmd sagen ob das Entfernen der Apps, im Aroma, bei der Full Rom funktioniert?
Gruß black
EDIT:
Jep es klappt.
Oh, das ging ja schneller als erwartet. Danke - lade es gerade runter und werde es morgen ausgiebig testen :)
NEU im HUB Elementalx 3.11
Kleiner Bug gefunden.
Die Größe der Schrift ist etwas klein geraten.
Kann das jemand bestätigen?
Gruß black
Ja bei mir auch
Reaktionen: blackline2008
nicht wirklich, hatte ich gestern schon im HUB :)
Gruß black
klein is da wohl untertrieben ^^
Wo gibt es ein Link bin irgendwie blind.
Edit. Gefunden
Finde auch irgendwie nix obwohl ich Follower auf XDA bin.
Hab es jetzt auch gefunden ;-)
