Sh0X31
Enthusiast
- 852
- Themenstarter
- #101
aber noch kein ic mit 3.17er base
Wer die Repo hat, kann sich ic 3.4-1 (3.17) erstellen.
Tyrion schrieb:3.4-2 ist raus und Kustomizer 1.0.9
3.4-3(same as r44 SVN) – works without full wipe coming from 3.2-x/3.3-x
- added horizontal extended settings mod (v6-manianc, lyapota, w00dstock). press status bar date for hqeqs edit
- added editable quick settings (v6-manianc, lyapota, w00dstock). press and hold the tiles in quick settings
- added 5×6 grid option (v6-maniac) (is selectable directly in grid sizes)
- added AROMA optional for dim status bar effect (v6-maniac)
3.5-1 repack(same as r63 SVN) works without full wipe coming from 3.2-x/3.3-x/3.4-x
- rebased to 3.18.709.2 final base!
- modified base to make it WWE! so in fact is 3.18.401.2
- works with kustomizer 1.1.0
- fixed sim contacts error
- fixed bluetooth issue with car audio systems
- fixed torch in HEQS
- fixed FC when quick settings was selected in home screen menu
- updated Twitter and Facebook
- system partition fully writable for S-ON users props flar2 for wp-mod.
- improved updater-script
4.0-1 (same as r91 SVN) – SHOULD work without full wipe coming from 3.2-x/3.3-x/3.4-x
- rebased to 3.22.1540.1 (HTC ONE DEV EDITION BASE) – mad props @CoryTallman for his effort to offer system dump
- modified base to make it WWE! so in fact is 3.22.401.2
- all mods ported! no old files used. And this without an actual phone to test on (my phone is broken)
- rom is tested by InsertCoin most addicted users before release!
4.0-2 (same as r97 SVN) SHOULD work without full wipe coming from 3.2-x/3.3-x/3.4-x/4.0-x
- fixed /system partition not being writable for S-ON users (thanks flar2 for guidance)
Now Xposed Framework and Viper4Android will work just as before without complicated tutorials![]()
fishboxx schrieb:Wie sieht es denn mit dem Akkuverbrauch aus?
Hält der Akku ähnlich lang wie bei der Viper, Android Revolution oder Elegancia Rom?
got word back from warranty. warranty is denied because the software on it was modified so i'm pretty phone less. what i was afraid happened. i haven't got hands on it yet but this is the status. I don't know how they got to this conclusion since the phone was dead and also why they denied the camera issue which is known and is not software related . Only thing left for me is to send an email to Consumer Protection but how things work here it will be a long run (at least 6 months ) .
I'm sorry, but unfortunately without a phone to test on pretty much this rom must come to an end. as i said it 1st time, my contract ends in march 2014 so until then I can't do too much because to be honest i can't afford 600 euros on the phone right now.
Update. Ok i called again and it seems they just check the phone's IMEI in the database and saw the phone was unlocked via htcdev and most probably they denied based on just that, without actually testing anything on the phone.
4.0-4 (same as r120 SVN) SHOULD work without full wipe coming from 3.2-x/3.3-x/3.4-x/4.0-x
- added Sprint Support (there still might be issue with Home Soft Key Remaping workign on it)
- fixed autosleep issue (dirty hack but it works) props yxtl
- made disable hw overlays on boot optional instead of default
- fixed facebook app not opening from blinkfeed.
- fixed twitter in blinkfeed
- updated Viper4Android
- updated Xposed Framework
- updated Chrome
- updated Adaway
- updated Maps
- updated Hangouts
- updated Google Search
- updated Es File Explorer
