braXdor
4.3 selbstverständlich
3.2-2 (same as r178 SVN) – works without full wipe coming from 3.2-1!
- removed HTC Premium Navigation (Locations) – was from 4.2.2 802w base, HTC doesn’t provide it for WWE device => not working on 4.3
- fixed Wifi hotspot for Tmobile US users (hopefully)
- updated Xposed Framework to a working alpha version for 4.3 (only full rom)
- cleaned updater-script (only full rom)
- added extra permission if supersu option if selected for supersu daemon (only full rom)
3.2-4 (same as r197 SVN) – works without full wipe coming from 3.2-1/2/3!
- fixed some code in updater-script
- fixed system ro after purexsound instalation
- improved ramdisk
- updated purexspund to 5.0b(without xloud, should minimize any incompatibility)
- updated xposed framework to 2.2 beta 2
- updated market apps
3.2-5 (same as r202 SVN) – works without full wipe coming from 3.2-1/2/3/4!
- fixed X-Reality MOD
- fixed Remove Picture Grid MOD – props @V6-Maniac
- replaced PureXAudio with Viper4Android FX – props @zhuhang ( yes i know many of you asked for this, now is finally here) – just remember to use “CortexA8 with NEON”
- added optional Long Press Back Key to Kill active app – props @gharrington for the original mod
- optimized AROMA installer
kolibree schrieb:Hab mal wieder 9.1 geflashed und wow.. sie rennt einfach nur wie bekloppt. Hatte jetzt monatelang die Viper. Die war dagegen sowas von träge![]()
3.3-1(same as r5 SVN) – works without full wipe coming from 3.2-1/2/3/4/5!
- rebased on 3.10.502.2 (Made it WWE) – props birdman @ROOTZWiki
- fixed some Bluetooth issues with car audio systems (not 100% working but a bit better)
- fixed auto-sleep
- fixed stability issues
- NOT FIXED Sim contacts
