[ROM] InsertCoin 8.1-3 | Stable | Tweaks (ROM Kontrol) | Performance | Sense 5.5
  • 502 Antworten
InsertCoin HTC ONE v8.0-1 – Sense 5.5 Android 4.4.2
Flash using a recovery that supports Android 4.4
8.0-1 (same as r204 SVN) – No wipe needed coming from 7.xx
- massive ROM installer Redesign; introducing Tweaks (Rom Kontrol)
- removed obsolete options
- added skip tracks by volume keys
- removed bloatware KeyVPN
- updated Google Play apps
- updated SuperUser to 1.0.3.0
- updated SuperSu optional to 1.9.3
- Verizon: updated to official files and kernel
- Sprint: removed always on Cross-hair icon (O.M.J)
- Sprint: removed always on Spark Icon (hawknest)
- Sprint: disable always on LTE icon (hawknest)
- implemented Rom Kontrol (Tweaks) (thanks to: lyapota, j to the 4n, w00dstock)
For Rom Kontrol usage you have 3 variants (until the Tweaks App is finished – hell if think you can land a help with the app let me know):
You change Kontrol values (Tweaks) on both ODEXED and DEODEXED ROM
1. Via Kontrol-InsertCoin flashable zip. It will be automatically made available at the root of your sd-card after you flashed the ROM.
If you performed FULL WIPE please do ONE complete boot before using it.
2. Via Kustomizer 1.3.0 and above.
3. Via ROM Build-in Kontrol Script.
Kontrol Script Explanation
kontrol sys <parameter> <value>
Example:
InsertCoin@/# kontrol sys tweaks_sms_wake 1
You need to reboot in order for new values to be applied
Parameters
- Values (if no value is defined will use value 0)
tweaks_recentapps_style
- 0 AOSP Style Recent Apps
- 1 HTC Style Recent Apps (default value)
tweaks_support_heqs
- 0 disable Horizontal Quick Settings (default)
- 1 enable Horizontal Quick Settings
tweaks_backkey_kill
- 0 disabled (default)
- 1 enabled (long press back button kills active app)
tweaks_htcsync_notification
- 0 enabled (HTC Sync Notification Enabled) (default)
- 1 disabled(HTC Sync Notification Enabled) (disabled)
tweaks_powersave_notification
- 0 enabled (Power Saving Notification Enabled)(default)
- 1 disabled (Power Saving Notification Disabled)
tweaks_exchange_security
- 0 enabled (exchange security enabled) (default)
- 1 disabled (exchange security disabled)
tweaks_mtp_notification
- 0 MTP Notification Enabled (default)
- 1 MTP Notification Disabled
tweaks_sms_wake
- 0 disabled (doesn’t turn on screen on sms receiver )
- 1 enable turns screen on when a SMS is received
tweaks_prism_semitran values
- 0 disable (stock)
- 1 enable transparent Sense (appdrawer / blinkfeed) for more check Kustomizer
tweaks_launcher_orientationchange
- 0 disable (stock)
- 1 enable landscape Sense
tweaks_crtoff_anim
- 0 crt off animation disabled
- 1 crt off animation enabled
tweaks_autobrightness_mode
- 0 default
- 1 webpatrick
- 2 moderate
- 3 agressive
tweaks_brightnessbutton_mode
- 0 default
- 1 always on
- 2 high
- 3 low
- 4 always off
tweaks_volkey_media
- 0 is off (default)
- 1 volDn (play/stop), volUp (play/forward)
- 2 volDn (play/backward), volUp (play/forward)
- 3 volDn (backward), volUp (forward)
- 4 volDn (screen ON), volUp (screen ON)
If you have problems with WLAN (not connecting to your AP) here it is the workaround
Custom Full ROM
Download from Android File Host
Download from ab-ed.de – kindly provided by deagleone
Download from amazon cloud – kindly provided by trjlive
MD5:45bd53d9d80c150b0bf96983ec426c4d *insertcoin-m7-r204-v8.0-1-ReleaseCandidate.zip
Jetzt muss ich doch mal nachhaken. Hatte gestern vor, mir die IC drüber zu bügeln. Habs natürlich auch geschafft, nur hab ich das mit den Revisionen (?) nicht so wirklich verstanden. Wo der Unterschied zwischen Version 7.1-5 und 8.0-1 ist, ist klar, aber wo ist jetzt der Unterschied zwischen 8.0-1 rev209 und rev212?
mfg Marcel
das Rom kann man via SVN so oft man möchte aktualisieren und immer wenn der Entwickler etwas ändert,
wird diese Änderung sofort herunter geladen.
Diese Daten werden dann aufbereiten und mit 7zip zu einem Rom verpackt.
Anleitung: https://www.youtube.com/watch?v=9jzlm12hyxw
Es gibt an manchen Tage im Minutentakt Änderungen und so ist man immer auf dem neuesten Stand.
Außerdem lädt man nicht immer ein ganzes Rom herunter, oder muss auf OTA´s warten.
edit: ich lade die Roms hoch für Leute die sich das mit der SVN nicht zu trauen, oder keine Lust haben
MfG
starbase64
Reaktionen: Ruppi2010
Ich hab irgendwie mit der 7.1.3 immer noch die beste Akku Laufzeit. War jedenfalls deutlich länger als mit dem7.1.4 wie ist das nun mit der8 er?
Thread aktualisiert.
InsertCoin HTC ONE v8.1-1- Sense 5.5 Android 4.4.2 INT TMO(WiFi Calling) ATT VZW SPRINT Tweaks
8.1-1 RC2 (same as r226 SVN) No wipe needed coming from 7.xx
- more AROMA Wizard Changes (do NOT use UPDATE ONLY option / Install without wipe is safe to use)
- updated base to 4.19.401.9
- Tweaks disabled noise suppression
- Tweaks show traffic monitor
- updated market apps
- implemented Rom Kontrol (Tweaks) (thanks to: lyapota, j to the 4n, w00dstock) see at the end of posts for details!
Bin mal wieder von der Viper auf IC gewechselt.
Leider ist der Akkuverbrauch auf der 8.1.1 r226 alles andere als schön.
Android-System ist ungewöhnlich hoch wenn ich bei GSAM schaue.
Der Beschleunigungssensor und der Lagesensor sind dauerhaft aktiv und nuckeln so gut am Akku.
Gibt es ähnliche Erfahrung und evt. Lösungen?
Gruß Dennis
Siehe Average im Screenshot...
In meinen Augen mehr als ausreichend gut. Zumal da auch häufig YouTube und Co dabei sind und das bei mir gefühlt am meisten frisst...
Und so leid es mir tut. Wann immer ich mittlerweile lese "mein Android-System verbraucht am meisten/so viel", ohne dass auch nur ein Minimum an Angaben gemacht wird was denn die Laufzeit ist, kann ich nicht mehr für ernst nehmen und auch nicht mehr sehen...
Mein android system ist auch bei 50% und mehr und trotzdem komme ich ohne zu spielen oder YouTube häufig 2 Tage hin bei 4-6 Stunden Screen on... Gestern hatte ich 2,4% per hour und Android system hatte über 80%. Ist das so schlecht und schlimm?
Was möchtest du denn noch wissen?
App Nutzung -Android-System -dort unter Nutzung Details kommt "Beschleunigungssensor" und "Lage" nicht zur ruhe.
Der Stündliche Verbrauch pendelt zwischen 10-15%/h
DOT war bei 35min als ich bei 75% Akku angekommen bin.
Gleicher Arbeitsort (wegen Handynetz) und ähnliche Nutzung wie mit der Viper.
Ein Neustart hat nicht viel gebracht. Etwas bessere Werte aktuell aber nicht viel.
Ich lese im Akku Thema mit und kann es nachvollziehen das "Android-System" n7cht mehr gerne gelesen wird.
Aber wenn die Sensoren unter diesem Punkt zusMmengefasst werden dann ist das eben so.
Ich habe es mir nicht ausgedacht...
10-15% ist allerdings hoch... Dass dir das nicht gefällt kann ich nachvollziehen.
Ich hab mask bei mir geguckt. Bin nun nach 4h 15min und 45min Display on bei 19% Verbrauch. Da entspricht hit 4%/h.
Die Zeit des Bewegungssensors entspricht in etwa der Displayzeit (1 min weniger oder so).
Hast du denn irgendwelche apps installiert die auf Sensoren zugreifen? Zum Beispiel smart cover oder sowas?
Du könntest ggf auch mal ein dump / log file mit better battery starts ziehen.
Was ich noch sagen muss:
Ich bin nicht auf dem Standardkernel, sondern nutze Elemental X. Allerdings hatte das bei mir kaum einen Unterschied im Verbrauch gemacht, zumal ich so ziemlich Standardtaktraten nutze.
Außerdem hatte ich das Problem mit hohem Verbrauch nach dem update von 7.0.1 auch. Das hat sich aber nach 3=4 Tagen eingependelt. Allerdings hatte ich auch da nur 8=9%/h.
=edit-
Sry für die Autokorrektur... Manchmal ist SwiftKey echt dämlich.
Ich habe jetzt im Incert Ordner noch eine kontrol-insertcoin.zip. Muss die auch bei 7Zip erstellen mit rein?
Edit: Hat sich erledigt. Ersten Post gelesen. :razz:
Kann man das drei Punkt Menü irgendwo abschalten?
Ich habe bei einigen Apps unten das Menü?
Edit:Habe ich gefunden..
Niro96
thwwiw
Peri25
Peri25
thwwiw
klaus818
klaus818
DrRammel
DrRammel
DrRammel
