[ROM] InsertCoin 8.1-3 | Stable | Tweaks (ROM Kontrol) | Performance | Sense 5.5
  • 502 Antworten
Tyrion schrieb:
Das hab ich schon gemacht, keine Verbesserung, habe auch schon alles formatiert, nix.
Gesendet von meinem HTC One mit der Android-Hilfe.de App
Denke da hilft nur bei xda zu fragen, hab echt keine andere Idee.
Kann ich nicht, hab da keine schreibrechte
Lag nicht an der Rom, hab das jetzt wieder gehabt.
Update auf 7.0-2
6.0-5(same as r3 SVN) – Full wipe Recommended
Flash using TWRP 2.6.3.3
- Android 4.4 with Sense 5.5
- based on HTC Dev Edition 4.06.1540-2
- all 3rd party apps updated to their latest versions
- unsecured boot.img
- rooted
- latest busybox
- init.d support
- fully writeable /system (even for S-ON users)
- removed HTC / Google logging
- cleaned
- stripped debugging info
- optimized and zipaligned
- speed and battery improvements
- Advanced Power Menu
- 20 Editable Quick Tiles in Quick Settings
- Flashlight Quick Tile
- Long Press Back Softkey to kill active app.
- Prism (Sense launcher) with extended menu support
- Prism with 5×6 Appdrawer Grid Option
- Camera: Enabled 360 Panorama
- Camera: Volume Down Key – starts video recording
- Camera: Volume Up Key- takes picture
- Camera: 99% jpeg quality
Optionals:
- Prism w/ landscape support
- Prism with 4×5 Widget Area
- Center Statusbar clock
- Remove Statusbar clock completely
- Stock % battery
- Remove battery icon completely
- Turn screen on when SMS is received
- Disable HTC Mail enforced security
- Force only GPU rendering
- Disable noise cancellation algorithm
- AOSP Recenets Apps Style
- Inline Quick Settings (aka Minor QS or HEQS)
- CRT-OFF Animation
- Remove photo grid for low-res contact pics
- GEL (Google Experience Launcher)
- Facebook Home
- De-Sense the rom (and use alternative launcher from the one above or from Play store)
- Replace Koush Superuser with Chainfire SuperSU
- Xposed Framework
- Viper4Android Audio Enhancement
- Sony’s X-Reality Engine
- Lower Proximity Sensor Sensibility (useful if you have issue during calls)
- Loud sound mode (will make your phone sound louder)
- Stock Android 4.4 Camera (does NOT replace Sense Camera, you’ll have the both installed)
- Stock Android 4.4 Keyboard (does NOT replace Sense Keyboard, you’ll have both installed)
- Disable HTC Color Enhancement (truer colors)
- Disable NFC Persistent Notifications
- and many many more
Und der InsertCoin kostumizer auf 1.2.1 mit KitKat unterstützung.
Reaktionen: shamanous
Was mache ich mit TWRP ????? Ist ein Image :confused::confused:
Kein ART !?!
Im Fastboot flashen.
Okay und die 7.0.2 . Wo bekomme ich die her ???
Der ursprüngliche Beitrag von 17:03 Uhr wurde um 17:04 Uhr ergänzt:
Hat sich erledigt :D
Muss n Full Wipe gemacht werden vom 4.3 auf 4.4?
FB07 schrieb:
im moment noch nicht.. wurde seitens htc deaktiviert.
baadnews macht sich dran und sollte demnächst funktionieren
wipe system, cache, dalvik.. dann flashen.. (bei mir keine probleme)
sollten probleme auftauchen, fullwipe
Kann TWRP nicht Flaschen. Zeigt mir das Image nicht an ???
jetzt fehlt nur noch ein Kernel, brauche wieder meine Menütaste:D
Funktioniert der ElemtalX 9 für die Google Edition 4.4 nicht?
Du sagst es selber für die Google Edition. Kannst es ja mal versuchen.
Ich drehe gleich durch . Versuche schon seit einer Std. die TWRP zu flashen . Habe ein IMac und ich bekomme es einfach nicht hin . Kann ich die 7.0-2 nicht auch ohne die TWRP flashen !!!
nutze den goomanager vom store..
menü .. install openbla...
Reaktionen: Speedtask
Hat endlich geklappt. Danke , hab das "Recovery Tools" genommen. Damit ging es dann endlich auch. Hab jetzt die 4.4 drauf. Läuft stabil und ohne Probleme . Danke
Hi Leute, wollte das ROM auch installieren mit TWRP. Fing auch gut an, Aroma Installer durchgelaufen, geflasht, danach neu gebootet und dann gehts es immer wieder ins Recovery (loop). Natürlich vorher Full Wipe gemacht usw., jetzt weiss ich auch nicht woran es liegt ... kann mir jemand hlefen? Thx.
Android32: Jap, funktioniert ebenfalls nicht der Kernel
Snxper: Welches TWRP hast du? Kann das sein, dass am ende der Installation eine Fehlermeldung mit einer 7 kam?
Du brauchst TWRP 2.6.3.3 anders gehts nicht.
Reaktionen: Snxper
ja, daran hat´s gelegen ;) Danke!
thwwiw
Peri25
Peri25
thwwiw
klaus818
klaus818
DrRammel
DrRammel
DrRammel
