[eingestellt][ROM][2. AUGUST] Apolo7 | 5.0.0 | 4.4.3 KitKat | 6.07.1540.1 | Sense 6 |
  • 19 Antworten
Hopie
Hopie
Dauer-User
352
Original Thread auf XDA
About the Rom
*Based on HTC One 6.07.1540.1
*Android 4.4.3 (KitKat)
*Sense 6.0
*Best battery life
*Smooth Fast and Stable
*Tweaked for Best Performance
*Deodexed
*Zippaligned
*Rooted
*Aroma Installer
*Option to remove apps
*Option to install additional mods
*Support of init.d
*And many more
How to install
*You need unlocked device
*Download rom and put it on sdcard
*Enter Recovery: (Power + Volume Down) and select recovery.
*Wipe before installation
*"Choose zip from sdcard" choose the downloaded zip
*Follow the aroma installation
*Reboot device,if you want to flash a custom kernel,flash it.
Changelog
V5.0.0:
-Added HTC music chanel!
-added htc calendar!
-added a wake fix for those with problem with gestures!
-update some gapps
-updated capps
-added NFC icon (disable it on setting if you want)
- added some perrformance and battery twaks
-fixed note!
-Some minor fixes.
v4.1.0:
-fixed radio fm issue
-fixed eqs issue
-fixed power manager issue
-removed heqs
-removed unesesary files
v4.0.0:
-Rebased update to 6.07.1540.1 Android 4.4.3 kitkat!
-added own file browser!
-added battery twaks for better performance !
-added Misc tweaks!
-added Scheduler Tweak!
-Deleted unnecessary files!
-improved app loading times!
-4.4.3 eqs!
-Optimized entropy!
-All other twaks ported and many more!
v3.0.0:
-Added options to remove keyboards in aroma (English,Spanish as default)
-Removed bootsound
-Removed some other stuff
-Fixed supersu problem (tested should be fixed if you have a problem flash this [2014.07.27] SuperSU v2.02 | Android | XDA Forum
and report.
-Some little battery improvements
-Added a better cleaning process during installation.
v2.0.0 :
- updated hangouts
- updated youtube
- updated maps and street
- updated music
- updated drive
- updated youtube
- updated search
- improved Camera Quality (jpeg quality raised to 99)
- improved video recording quality
- improved performance
- minor fixes
*Initial release
Downloads
Apolo7 v5.0.0
https://mega.co.nz/#!oxwAyIZR!BBHBqquaWJxwZCKgg-rgau4oBDy0FOv_waoBREW1rXk
ältere Versionen:
Credits
Chainfire:
- For Supersu
rovo89:
- Xposed Framework :Xposed - Legacy thread. Don't panic, Xposed is still here. - XDA Forum
langer hans for:
- Sense 6 Toolbox :[MOD][XPOSED][1.3.3 | 2.9.5] Sense Toolbox -… | Xposed General | XDA Forum
caspase for :
-AppopsXposed :[Xposed][MOD][1.17.2] AppOpsXposed - AppOps … | Xposed General | XDA Forum
zhuhang for :
-Viper4Andorid :[APP] Official ViPER4Android Audio Effects (… | Android | XDA Forum
mike1986 for:
- for everything and his base,link to the original thread : [SYSTEM DUMP][07.06.2014] HTC One *STOCK* RO… | HTC One | XDA Forum
dragonesdenano:
- for helping and teaching
Thorvic777:
Reaktionen: shamanous
Hatte die schon jemand hier getestet ?
hab sie drauf und bin zufrieden
handy startet bei mir nach ca 5 minuten immer wieder neu (mit und ohne wipe) also kein bootloop es läuft ca 5 minuten und denn aufeinmal bam aus , neustart
im XDA wird emofohlen dem Elemental-X Kernel (die Version für 4.4.3) bei Neustarts bzw. Bootloop zu flashen.
Reaktionen: scarecrow90
oder seit neustem den kangaroo > klick < läuft ohne reboot
hier
der elementalx 17.0 für 4.4.3
;)So, dann werde ich sie jetzt auch mal testen...Bin gespannt, die Maximus HD war nicht so mein Fall. Mal sehen wie sie sich im Vergleich zu Skeletons Eragon so macht
Läuft mit dem ElementalX recht gut, ist nicht so smooth wie Eragon, aber wer alle Sensefeatures möchte sollte sich die Rom auf jeden Fall mal anschauen. Für meinen Geschmack noch etwas zu viele unnötige Apps die sich beim installieren nicht abwählen lassen, aber dank Titanium Backup kann man da ja nach bessern...
Mati arbeitet am nächsten update :cool2:
Es gibt noch Leben beim M7? Ich dachte jetzt echt, da ist jede Entwicklung gestorben. Bei den Sense-ROMs gibt es seit mehr als einem Monat nichts mehr, beim Kangaroo geht es in Richtung Unbrauchbarkeit und jetzt habe ich das hier gefunden?
Werde ich mir bei Zeit mal anschauen. Ein ROM, bei dem sich etwas tut, unglaublich, Wahnsinn!
Edit: Ok, wollte es runterladen, Meldung, Seite nicht gefunden. Geile Kiste.
@klaus download der rom funktioniert ohne probleme...
Tja, irgend etwas ist hier gerade faul. Mega ist bei mir komplett tot. Yahoo Mail geht auch nicht. Bin in Italien, da ist wohl gerade etwas ausgefallen. Oder die haben Mega gesperrt...
Edit: Jetzt geht es wieder. Komisch, Mega war komplett weg.
die nächste ROM, die ausläuft..
dev arbeitet nun für das SkyDragon Team
danke, aber ich bleib nun bei der viper.. bald kommt ja die neue version
Ist schade drum.
Die Rom lief bei mir sehr gut...
Hab mal ne Frage zur Rom!
Warum Base 6.07.1540.1 und nicht Base 6.09.401.5, gibt es da Unterschiede :confused2:
das war zu dem zeitpunkt die aktuellste version, da rom eingestellt, keine neue base
Reaktionen: MenschMarkus
Kann man das nicht irgendwie selber machen, wenn man die Rom weiterhin nutzen möchte?
seine arbeit fließt bei der skydragon rom ein.. evt diese testen
ansonsten.. wenn man sich mit der materie auskennt, geht das sicher
DrRammel
DrRammel
DrRammel
schinge
schinge
thwwiw
klaus818
klaus818
