dawkon13
- 21
Hi
This it's easy way to better battery life
Results:
1. Enable airplane mode:
Battery save: 1-3%/10 hours
2. Disable Mobile Data:
3. Disable location services:
Battery save: 1-5%/10 hours
4. Disable sync:
Battery save: 1-6%/10 hours
5. [The best result] Disable sounds:
Battery save: 8-13%(!!!)/10 hours (in deep sleep mode)
6. Battery save: 1-5%/10 hours
a. Download & install GO POWER MASTER from play store
b. After run goto "Smart" tab
c. ENABLE "Screen off optimalisation"
d. Add GO POWER MASTER widget (4x1) on your desktop- after close application click on widget:
YOU SAVE 13-35 %/ 10 hours !!!
Results:
4. Disable sync:
