Telefon-Codes für die neuen Tabs 7.0Plus und 7.7
  • 8 Antworten
frank_m
frank_m
Ehrenmitglied
8.736
So, ich hab noch mal ein bisschen meinen Dialer malträtiert. ;) Folgendes kam dabei heraus:
Code:
*#06#			zeigt die IMEI-Nummer
*#*#1234#*#*		Zeigt PDA, Phone, CSC, Build Info
*#*#0*#*#*		Test Utility
*#*#12580*369#*#*	Zeigt PDA, Phone, H/W, RFCallDate, CSC
*#*#4387264636#*#*	ServiceMode Sellout SMS, PCode, Mode
*#*#4636#*#*		Testen
*#*#83052020100812173552301071192687#*#*	ProductCode Auswahl (ersetzt *#272*IMEI#)
*#*#9090#*#*			Diagnostic Configuration
*#*#9900#*#*			SysDump
*#*#2678863#*#*			AMP Tune Setting
*#*#232337#*#*			Bluetooth Address
*#*#232331#*#*			Bluetooth Test Mode
*#*#2726564#*#*			Bluetooth Sniff Test
*#*#273283*255*3282*#*#*	Zeigt SMS/MMS Fill Up
*#*#273283*255*663282*#*#*	Kopiert Video- oder MP3-Daten aus dem CSC
*#*#44336#*#*			Zeigt Internal Version
*#*#2767*3855#*#*		Factory-Reset OHNE jede Rückfrage
*#*#759#*#*			Rlz Debug UI with Branding Info
*#*#0842#*#*			Vibrator Test
*#*#7780#*#*			Factory Reset
*#*#0673#*#*			"Melody" Test
*#*#0289#*#*			"Melody" Test
*#*#2663#*#*			Touch Screen Firmware
*#*#2664#*#*			Touch Accurancy/Sensitivity Test
*#*#0588#*#*			Proximity Test
*#*#3263#*#*			RAM Check
*#*#7353#*#*			Diverse Selbst-Tests
*#*#737425#*#*			Zeigt Seriennummern
*#*#0011#*#*			ServiceMode GSM
*#*#0228#*#*			Battery Status
*#*#0283#*#*			ServiceMode Audio Packet/PCM Loopback
*#*#32489#*#*			ServiceMode Ciphering Control
*#*#2580#*#*			ServiceMode Integrity Control
*#*#0782#*#*			RTCTimeRead
*#*#7284#*#*			PhoneUtil USB Modem/PDA
*#*#1472365#*#*			GPS test settings
*#*#197328640#*#*		Service mode main menu
*#*#872564#*#*			USB Logging(DM)
*#*#8255#*#*			GTalk Service Monitor
*#*#2263#*#*			ServiceMode WCDMA/GSM Band Preference
*#*#1575#*#*			ServiceMode GPS Session Control, Display Info, Change State
*#*#3214789650#*#*		LBS Test Mode
*#*#03#*#*			NAND Flash S/N
*#*#0589#*#*			LightSensorRead
*#*#1111#*#*			ServiceMode Read FTA SW Version
*#*#2222#*#*			ServiceMode Read FTA HW Version
*#*#301279#*#*			ServiceMode HSPA Control
*#*#279301#*#*			ServiceMode HSPA Control
*#*#3214789#*#*			GcfModeSettings
*#*#8736364#*#*			Software-Akualisierung
*#*#7594#*#*			Shutdown Modus
*#*#07#*#*			Test History
*#*#232338#*#*			WLAN MAC Address
*#*#232339#*#*			WLAN Test Mode
*#*#3282*727336*#*#*		Data Usage Status
*#*#4238378#*#*			GCF Configuration
*#*#745#*#*			RIL Dump Menu
*#*#746#*#*			Debug Dump Menu
Scherz beiseite: Danke dafür: https://www.android-hilfe.de/forum/samsung-galaxy-w-i8150.470/testprogramme.185540.html
Mit dem Wissen war es leicht, eine funktionierende Codebasis zu erzeugen. Ich hab nicht alle getestet, aber die meisten sollten gehen.
Reaktionen: magyarfiu, Herby3, Handymeister und 3 andere
Mal ne dumme Frage ...
Wie gibt man diese Codes eigentlich ein, wenn man ein Tab 7.7 (P6810) ohne Telefon-Funktion hat?
Gibt es eigentlich auch einen Code gegen Fast Domancy?
Ja, ist der Gleiche, wie beim S2, Note usw. auch. Aber sei gewarnt: An der Einstellung willst du nicht herumspielen! Sieh dir die aktuellen Diskussionen dazu im S2 und Note Bereich an: Jeder, der die Einstellung überschreibt, bezahlt es mit einem sehr hohen Akku Verbrauch.
...wollte nur sagen, ob Bug in ICS unbekannt, die Codes gehen leider unter ICS nicht mehr. Beim G-Note mit ICS gehts wunderbar.
Wollte nur mal einfach die IMEI checken via *#06# oder die PDA Version mit *#*#1234#*#* nach meinen Flash des Tab7+.
Dabei hab ich das festgestellt. Kann man das prüfen ?? Macht wieder den Error mit ungültiger MIME Code oder so.
Nein, steht auch schon im ICS Bugthread drin. Die Secret Codes gehen nicht mehr.
Reaktionen: Don_Ron und Mark77
Wird es da "andere Codes" geben ?? Dumm das es da keine "Norm" gibt. Dachte immer ist "tonwahl" abhängig des Dialers. Naja ok. Danke trotzdem.....
Die öffentlichen Android Codes funktionieren natürlich noch. Nur die Samsung internen gehen nicht mehr. Das waren aber die eigentlich interessanten.
@frank_m:
komisch weis nicht obs am ICS liegt und nen Bug ist.
Nicht mal der "Klassiker" die IMEI checken via *#06# oder die PDA Version mit *#*#1234#*#* gehen nicht am Tab7+
Was sind die "normalen Android-Codes" ??? Danke für Info.
elamyo
Geraldine124
baerchen
baerchen
