IMS Service dreht durch, hoher Akku Verbrauch, CPU ständig aktiv.
  • 4 Antworten
Conan179
Conan179
Moderator
Teammitglied
23.643
Hallo erst mal.
Ich hab jetzt schon mehrer roms durch probiert, aber ich hab hier immer wieder den selben fehler, der system dienst "IMS Service" dreht durch.
Er verbraucht dan viel akku hält die cpu aktiv.
im logcat steht follgendes
Code:
3C Toolbox Pro (logcat)
Process IMS Service(com.sec.imsservice)
I/21:26:49.946 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.946 acquireWakelock with timeout exit.
D/21:26:49.946 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
D/21:26:49.946 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
D/21:26:49.946 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.936 acquireWakelock with timeout exit.
D/21:26:49.936 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
I/21:26:49.936 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.936 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
D/21:26:49.936 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
D/21:26:49.936 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=515}
D/21:26:49.926 acquireWakelock with timeout exit.
D/21:26:49.926 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
I/21:26:49.926 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.926 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
D/21:26:49.926 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=516}
D/21:26:49.926 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=515}
D/21:26:49.926 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
D/21:26:49.916 acquireWakelock with timeout exit.
D/21:26:49.916 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
I/21:26:49.916 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.916 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
D/21:26:49.916 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=510}
D/21:26:49.916 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.916 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
D/21:26:49.906 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
I/21:26:49.906 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.906 acquireWakelock with timeout exit.
D/21:26:49.906 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.906 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
D/21:26:49.906 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=510}
D/21:26:49.906 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=509}
D/21:26:49.896 acquireWakelock with timeout exit.
D/21:26:49.896 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
I/21:26:49.896 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.896 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=510}
D/21:26:49.896 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.896 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
I/21:26:49.886 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.886 acquireWakelock with timeout exit.
D/21:26:49.886 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
D/21:26:49.886 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
D/21:26:49.886 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.886 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
D/21:26:49.876 acquireWakelock with timeout exit.
D/21:26:49.876 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
I/21:26:49.876 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.876 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
D/21:26:49.876 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=511}
D/21:26:49.876 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=510}
D/21:26:49.866 acquireWakelock with timeout exit.
D/21:26:49.866 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=512}
I/21:26:49.866 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.866 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=513}
D/21:26:49.866 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=515}
D/21:26:49.866 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
I/21:26:49.856 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.856 acquireWakelock with timeout exit.
D/21:26:49.856 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=515}
D/21:26:49.856 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=514}
D/21:26:49.856 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=517}
D/21:26:49.856 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=516}
D/21:26:49.856 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=518}
D/21:26:49.846 acquireWakelock with timeout exit.
D/21:26:49.846 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=518}
I/21:26:49.846 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.846 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=517}
D/21:26:49.846 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=520}
D/21:26:49.846 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=519}
D/21:26:49.836 acquireWakelock with timeout exit.
D/21:26:49.836 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=517}
I/21:26:49.836 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.836 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=518}
D/21:26:49.756 acquireWakelock with timeout exit.
D/21:26:49.756 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=530}
I/21:26:49.756 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.756 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=529}
D/21:26:49.756 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=528}
D/21:26:49.756 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=531}
I/21:26:49.746 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.746 acquireWakelock with timeout exit.
D/21:26:49.746 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=530}
D/21:26:49.746 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=529}
D/21:26:49.746 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=528}
D/21:26:49.746 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=531}
D/21:26:49.736 acquireWakelock with timeout exit.
D/21:26:49.736 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=529}
I/21:26:49.736 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.736 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=530}
D/21:26:49.736 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=532}
D/21:26:49.736 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=531}
I/21:26:49.726 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.726 acquireWakelock with timeout exit.
D/21:26:49.726 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=531}
D/21:26:49.726 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=530}
D/21:26:49.726 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=533}
D/21:26:49.726 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=532}
D/21:26:49.726 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=534}
D/21:26:49.716 acquireWakelock with timeout exit.
D/21:26:49.716 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=533}
I/21:26:49.716 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.716 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=532}
D/21:26:49.716 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=531}
D/21:26:49.716 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=534}
D/21:26:49.706 acquireWakelock with timeout exit.
D/21:26:49.706 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=532}
I/21:26:49.706 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.706 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=533}
D/21:26:49.706 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=535}
D/21:26:49.706 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=534}
I/21:26:49.696 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.696 acquireWakelock with timeout exit.
D/21:26:49.696 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=534}
D/21:26:49.696 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=535}
D/21:26:49.696 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=533}
D/21:26:49.696 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=536}
D/21:26:49.686 acquireWakelock with timeout exit.
D/21:26:49.686 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=534}
I/21:26:49.686 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.686 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=533}
D/21:26:49.686 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=536}
D/21:26:49.686 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=535}
D/21:26:49.686 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=537}
D/21:26:49.676 acquireWakelock with timeout exit.
D/21:26:49.676 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=538}
I/21:26:49.676 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.676 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=537}
D/21:26:49.676 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=536}
D/21:26:49.676 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
I/21:26:49.666 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.666 acquireWakelock with timeout exit.
D/21:26:49.666 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=537}
D/21:26:49.666 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=538}
D/21:26:49.666 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
D/21:26:49.656 acquireWakelock with timeout exit.
D/21:26:49.656 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
I/21:26:49.656 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.656 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=538}
D/21:26:49.656 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=537}
D/21:26:49.656 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=541}
D/21:26:49.656 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=540}
D/21:26:49.646 acquireWakelock with timeout exit.
D/21:26:49.646 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
I/21:26:49.646 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.646 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=538}
D/21:26:49.646 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=541}
D/21:26:49.646 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=540}
I/21:26:49.636 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.636 acquireWakelock with timeout exit.
D/21:26:49.636 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=541}
D/21:26:49.636 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=540}
D/21:26:49.636 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
D/21:26:49.636 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=542}
D/21:26:49.626 acquireWakelock with timeout exit.
D/21:26:49.626 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=540}
I/21:26:49.626 Acquiring timeout type wakelock with timeout: 300 ms, Entry...
D/21:26:49.626 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=539}
D/21:26:49.626 acquireWakelock(long timeout), after WakeLock{485fe2a held=true, refCount=541}
kann jemand damit was anfangen, was das app da treibt?
IMS Service wird benötigt für VoLTE.
Mal testweise ausschalten (das VoLTE) falls aktiv
in der custom rom gibt es den schalter nicht.
Ist dann wohl ein Problem mit deiner ROM . Frage mal im Modding Bereich oder gehe auf Stock oder eine andere ROM.
Also alle roms haben das selbe problem?
Ich werde mal in eine andere richtung vom ims service ermitteln, rchtung Rich Communications.
html6405
html6405
  • richi07
The_Lion
