Darkman
Ehrenmitglied
- 14.791
[table_old][tr_old][th_old]Dimension[/th_old][th_old]Kamera[/th_old][th_old]Display[/th_old][th_old]S pen[/th_old][/tr_old][tr_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][/tr_old][tr_old][td_old]
153.2 x 76.1 x 7.6 mm (171 g)[/td_old][td_old]
Rear : 16MP OIS (F1.9)
Front : 5MP (F1.9)[/td_old]
[td_old]5.7” Quad HD Super AMOLED
2560 x 1440 (518 ppi)[/td_old][td_old]Sample rate 240Hz
Pressure level : 2,048[/td_old][/tr_old][tr_old][th_old]Prozessor[/th_old][th_old]Betriebssystem[/th_old][th_old]Netzwerk[/th_old][th_old]Memory[/th_old][/tr_old][tr_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][/tr_old][tr_old][td_old]Exynos 7420 (64-bit, 14nm)
Octa core (2.1GHz Quad + 1.5GHz Quad)[/td_old][td_old]Android 5.1 (Lollipop)[/td_old][td_old]LTE Cat.9
LTE Cat.6
* May differ by country and carrier.[/td_old][td_old]RAM : 4GB RAM (LPDDR4)
STORAGE : 32/64GB (UFS 2.0)
* Storage options may vary by country and carrier.[/td_old][/tr_old][tr_old][th_old]Batterie[/th_old][th_old]Payment[/th_old][th_old]Ladung[/th_old][th_old]Connectivity[/th_old][/tr_old][tr_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][/tr_old][tr_old][td_old]3,000mAh[/td_old][td_old]
-[/td_old][td_old]Fast Charging, Fast Wireless Charging
NFC, MST (US/KOR)
* Available in select countries and accepted payment solutions may vary by country.[/td_old][td_old]WiFi 802.11 a/b/g/n/ac (2.4/5GHz), MIMO, Bluetooth® v 4.2 LE, ANT+, USB 2.0, NFC, Location (GPS, GLONASS, BeiDou)
* BeiDou coverage may be limited.[/td_old]
[/tr_old][tr_old][th_old]Sensoren[/th_old][th_old]Audio[/th_old][th_old]Video Format[/th_old][th_old]-[/th_old][/tr_old][tr_old][td1_old][/td1_old][td1_old][/td1_old][td1_old][/td1_old][/tr_old][tr_old][td_old]Accelerometer, Proximity, RGB Light, Geo-magnetic, Gyro, Fingerprint, Barometer, Hall, HRM [/td_old][td_old]Format : MP3, M4A, 3GA, AAC, OGG, OGA, WAV, WMA, AMR, AWB, FLAC, MID, MIDI, XMF, MXMF, IMY, RTTTL, RTX, OTA[/td_old][td_old]MP4, M4V, 3GP, 3G2, WMV, ASF, AVI, FLV, MKV, WEBM[/td_old][/tr_old][/table_old]
Quelle: Samsung Galaxy Note 5 - The Official Samsung Galaxy Site
Partitionstabelle:
LTE Cat.6
NFC, MST (US/KOR)
Partitionstabelle:
Code:
BOOT -> /dev/block/sda5
BOTA0 -> /dev/block/sda1
BOTA1 -> /dev/block/sda2
CACHE -> /dev/block/sda15
CPEFS -> /dev/block/sdd1
DNT -> /dev/block/sda10
EFS -> /dev/block/sda3
HIDDEN -> /dev/block/sda16
OTA -> /dev/block/sda7
PARAM -> /dev/block/sda4
PERSDATA -> /dev/block/sda13
PERSISTENT -> /dev/block/sda11
RADIO -> /dev/block/sda8
RECOVERY -> /dev/block/sda6
STEADY -> /dev/block/sda12
SYSTEM -> /dev/block/sda14
TOMBSTONES -> /dev/block/sda9
USERDATA -> /dev/block/sda17
