fromfuture
Philosoph
- 4.594
- Themenstarter
- #1.241
Ja mach ich später. Danke für deine Hilfe
Androidwizard schrieb:Features und ChangeLogs für V8
Red : Highlights
Blue : Change log (Changed/Moved/Fixed/Added new feature)
Base : N7100XXUFND3_N7100OXAFND3_XEF
MultiTool functions :
Apart from ROM flasher you can use ROM file as utility too
-Inbuilt Aroma file manager in case anything go wrong while playing device with different mods, you can manage to explore device from recovery
-EFS Backup/Restore
-Customized Bloatware remover, select only app you don't want.(including Knox)
-CSC features
-Build prop tweaks.
-LockScreen Password cleaner
-GPS changer (select according your location)
-Theme changer
S5 Features/Applications
Ultra power saving mod - Power saving +, UPSM,Emergency mod
Toolbox - 10 application can be edit
Phone app with popup notification and status information option.
Lockscreen Unlock effect - Particle/Stone skipping/water color/Ripple/Light effect/Oil paint/Blind
Launcher
Accuweather Widget
Browser
SecMMS - MMS issue fixed
Kids Mod
Memo
LockScreen effects
NOTE 3 Features :
Air command
Smart Scroll
Smart Pause
Story Album
One Hand for All screen
Writing buddy (direct Input)
PEN Window
Action Memo
Scrap booker
ScreenShot
S Finder
S note with attachment option like chart, map, video, YouTube,scrap book
S suggest
S finder
ScrapBook
Gallery
Sketch Book
Magazine
Rom Built-In feature (will install by just selecting Flash Dr.Ketan ROM options in aroma)
Pre rooted , Zip aligned, Busybox
30 battery Mod (inbuilt 30 battery MOD including stock, you can change battery icon on the fly (without reboot) To change icon tap battery icon three times from status bar. Don't select show battery option in setting. tap battery icon 3 times on status bar, you will get option for battery percent, select from there. OR You can do this with Dr.Ketan utilities - ROM - Battery percent/Battery style
Hidden power menu - Tapping on clock will turn off screen (Lock), long pressing clock will bring power menu. This feature will not allowed to move clock to center. If you want center clock mod then you have to select stock battery option in aroma and don't use any other mods under systemUI section. Option added to remove hidden meter in mod section
300 fonts enabled
Default language english
All Language enabled
Ad Free
Call Recording - Auto call record included On/Off from setting-dr,ketan ROM extra-utility
4 Way Reboot mod
4 PullUp mod : User can select own selectable application instead of stock. 1.Launcher bottom 2.Launcher Lt pull 3.sFinder of Air command menu 4.Long Press menu
MysFinder - Ability to select sFinder from pullUp
Multiwindow hack - Quad view - you can open upto four app from MW
Sec Launcher MOD - Hide application option with dual pullup mod
Camera Hack - Use camera with Flash at low battery
All S5 features
All Note3 features
All Application in Pen window and Multi window + Multi instance (same application in Multi Window)
Advanced function SecMMs
Group messeging
Schedule msg
Backup/Restore SMS to SD card
Recipient limit 999
Original time stamps
Disable SMS-MMS
Raise SMS/hr limit
Split view toggle in setting menu
Increased MMS max size
Increased size of image
No SMS to MMS with Emoji
Dr.Ketan Utilities (also part of built-In ROM)
You can access this by Setting-device-DrKetan ROM Extra OR from App drawer. This utility requires plug in called Secure setting. It should auto install while flashing ROM. you should check in app drawer, if it is missing then you should download from play store.(you can find it here in post #5 too.)
This application is built-in Dr.Ketan's Custom ROM. This application divided in four menu. Also note that you needs to install plug-in to work this app. On opening of app it will direct to play store to install plug in if your device lacking it.
1.Toggles - As name suggest here in this menu you will have many Toggles which you can use to activate/Deactivate services.
Single tap on icon to activate, Long click on icon to deactivate
Incoming Call Record - This will record all incoming calls. File will be saved in IntSD/Sounds/ folder. (If you dont have this folder then manually create it.)
Outgoing Call Record - This will record all Outgoing calls. File will be saved in IntSD/Sounds/ folder. (If you dont have this folder then manually create it.)
Auto GPS - Will Auto On/Off GPS with some commonly GPS using app
Auto Wifi - Auto switch off wifi if no active connection more than 10min
Auto Bluetooth - Auto switch off bluetooth if not actively paired more than 10min
Smart Network - Switch off data connection with 30sec of screen off, Auto ON with screen ON
Media scanner - To turn On/Off media scanner
Torch - Activate flash light with shaking of device with screen (home/Lock) ON
LogIn security - silently capture image is multiple failed attempt to unlock device,pic stored in IntSD/DCIM/DrKetan_utilities/
CPU Control - Controls CPU with following profiles A. Screen Off - Power save governer B Screen ON - ON Demand governer (PS : This function available in Adv version of utility that you have to select in mod section. Recommended for advanced user only.
Tasks
Long press icon to apply.
EFS backup - Backup your EFS
EFS Restore - To restore EFS, Needs to keep efs.img file on intSD card root directory.
Data Fix - Just like Tb restore fix. Probably you won't require this on this ROM but still you can use if you have FCs after restoring app with titanium
IntSD fix - SOmetime you can't read/write on SD card (int/Ext) you can use this utility to fix issue
Flash Recovery
Flash Kernel
Flash Modem
You needs to put raw file on intSD root directory. like if you want to flash any modem, just extract modem.bin and keep in root directory of InntSD and long press Flash Modem icon and reboot. same way for recovery use recovery.img and for kernel use boot.img
Auto Scan This will Auto scan only while your device connected to AC charge. and disable when you remove from AC wall charger.
This is helpful to reduce battery consumption
ROM extra settings
PullUp Chooser
You can choose choose default application for each pullup mod
Launcher bootom
Launcher Side (only available in S5 launcher)
S Finder in Air command
S finder in Long pressing menu
Note that if you want to select default S Finder then you have to choose My Sfinder application.
Battery percent show/hide
Battery style changer
Meet Here/Car Parking
This is application very handy to find your car/ share location/Find location. This is complimentary for all this ROM user. Find more details here.
Power save plus - Power saving + Gray theme
Ultra power saving mod of S5
Emergency Mod
GPS Fix
Select your continental for better GPS fix.
Europe
Asia
Oceania
N America
S America
Africa
Multi DPI
-Option to select 240 and stock DPI (If you don't select while flashing ROM it will flash stock DPI). While flashing ROM needs to select only you needs 240DPI. Also there is option to return to stock DPI without flashing ROM
PS : When you change DPI without clean install, you needs to clear data for launcher (TouchWiz) and accuweather.
Only S5 launcher added support for MultiDPI
Not all applications support multi DPI, You needs to set 320DPI with App setting for phone,contacts,keyboard etc.
Changelog um weitere Punkte ergänzt!
(Unglaublich was er allein zustande bringt)
fromfuture schrieb:Ich hatte doch mal eine ND3 Prerooted Rom hochgeladen. Kannst gerne nehmen.
