[FIX] Fast GPS lock for the Galaxy 3 [2.3.7]
  • 9 Antworten
Gingerbread23
Gast
Original Post
I recently posted this in Kyrillos V10.5 as I use his (Great) ROM but as more people seem to complain about the GPS in 2.3.7 ROMS and there doesn't seem to be any other fixes that work this well (Tried many) I'll give it it's own thread with some explaining for those who also prefer 2.3.7 and and often use GPS.
I haven't tried this on any other Android versions yet, this might works as well, if it does, would be great to leave a comment!
gps.conf:
NTP_SERVER=europe.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
DEBUG_LEVEL =0
ENABLE_WIPER=1
CURRENT_CARRIER=common
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=TRUE
DEFAULT_SSL_ENABLE=FALSE
SUPL_HOST=supl.google.com
SUPL_PORT=7276
SUPL_NO_SECURE_PORT=3425
SUPL_SECURE_PORT=7275
SUPL_TLS_HOST=FQDN
SUPL_TLS_CERT=/etc/SuplRootCert
C2K_HOST=c2k.pde.com
C2K_PORT=1234
secgps.conf:
#Generated by GpsLocationProvider.
#Sat Mar 17 17:29:52 CET 2012
SSL=1
SSL_TYPE=0
POSITION_MODE=121
OPERATION_TEST_MODE=0
ACCURACY=50
SESSION_TYPE=2
SERVER_MODE=2
ENABLE_NMEA=false
START_MODE=HOT
GPS_LOGGING=0
AGPS_MODE=0
ADDRESS_MODE=1
TIME_BTW_FIX=2000
OPERATION_MODE=STANDALONE
USE_DEFAULT=false
SUPL_PORT=7276
ENABLE_XTRA=true
NUM_OF_FIX=999999999
TIMEOUT=10
So just edit gps.conf in /etc and create in data/gps a new text file called secgps.conf
Be sure to update The Assisted GPS for the best results, can be done in a GPS Test or the easiest way is downloading GPSStatus from the market and go to Tools - A-GPS (You do need an internet connection)
I myself get a lock outside within 10 sec and even inside after about 30-60 seconds mostly with 10+ satellites.
As you can see the NTP Server is Europe, if you're from outside of Europe you can try changing it.
Go to pool.ntp.org: the internet cluster of ntp servers
and select your region (go to Active Servers on the right side)
If your region for instance is India, you should change it in gps.conf:
NTP_SERVER=europe.pool.ntp.org to asia.pool.ntp.org
(only suggesting as this isn't the case for me)
Best/Easy to use apps like Root Explorer to do this.
Don't use Fasterfix or anything like that after you've 'fixed' your GPS as it will change the gps.conf file.
It's recommended to make a backup before attempting this.
I'm open for improvements or other ideas, I myself am not the biggest expert on this but if I can and have some spare time then I do like to help out.
Also a big thanks to zsolt64 and the other developers who helped making the Galaxy 3 a great phone!
Have a good lock. :D
Lieber Gingerbread23! Danke für den Hinweis auf den Beitrag, aber ein Link hätte es wohl auch getan! Oder wolltest Du Deine persönlichen Anmerkungen sowie eine deutsche Übersetzung noch nachreichen? :winki:
Nein, aber schaden kann es ja nicht wenn ich den Text mit rein post oder?
I'm sorry, but as far as I know, this bulletin board is called "Android-Hilfe.de" and not "Android-Help.or.uk", isn't it? So, maybe some of our users aren't able to translate the text properly on their own. :winki:
Also die Zeile
'SUPL_TLS_HOST=FQDN'
in der gps.conf ist schonmal Sinnlos!
FQDN=Full Qualified Domain Name
Da gehört eine Serveradrese rein!
Das sollte aber jedem klar sein, der sich in der EDV und seiner Notierung (~Schreibweise) auskennt. ;)
Nunja ist es vielen leider nicht und im 1st Post wird das auch nicht erwähnt!
Habs leider bei vielen gesehen das die config 1 zu 1 copy und paste genutzt wird was ja nicht wirklich Sinn macht mit der Zeile ;)
Gesendet von meinem GT-S5830 mit Tapatalk 2
Mir ist sowieso nicht klar, was dieses Skript bringen soll.
Hab online den Fix in 10s, offline dauerts schonmal 1-2 Minuten.
Kann mir schwer vorstellen, dass die paar Zeilen Code das verbessern.
Zumal in einer aktuellen CR wohl auch GPS optimiert wurde, soweit machbar...
mardon schrieb:
Also die Zeile
Hey,
weißt du bzw. jemand anderes denn welche Serveradresse dahin soll?
Ich weiß es nämlich nicht, würde den Fix aber gerne mal testen.
Lg
Larry51 schrieb:
Hey,
Lg
Gibt da mehrere Möglichkeiten.
Tip das doch einfach mal bei google ein. ;)
Holger1974
  • Holger1974
Holger1974
Holger1974
  • Blackstorm
2 3 4
Holger1974
Holger1974
qaysedcftgb
Q
