Triple_H72
[ROM] xXx No Limits 6.1 [G900F/W8][CQAV] ☆ Fast ☆ Smooth ☆ Xposed/Viper|Atmos
Hallo Liebe Andoid Hilfe Galaxy S5 Nutzer,
Viel Spaß mit der wirklich genialen TW basierenden Custom ROM
ÜBER die ROM:
GALAXY S5 Model ☆ SM-G900F/W8
Android 6.0.1 ☆ G900FXXS1CQAV
Changelist: 9493471
Security Updates: Januar 1, 2017
Rooted: SuperSU v2.77 Stable
Major flash options
SuperSU + suhide
Odexed
Deodexed
xXx Tweaks
Keyboards
Kernel selections
Xposed
Xposed Material Design Installer
Viper4Android|Beats|Atmos
Good Lock
Modded Camera
Version 6.1 based on CQAV is available for Download
Many of you who are using TWRP 3.0.0-0 or PhilZ Recovery experienced issues after flashing v6.0 with write access of apps to the internal sdcard. This was caused by the sdcard fix script from osm0sis which obviously only works with TWRP 3.0.2 or higher.
Version 6.1 solves this issue and is compatible again with TWRP 3.0.0-0 or PhilZ Recovery.
If you are already successfully using v6.0 you can stay with it as this is the only difference between v6.0 and v6.1. If you need to flash the rom again to use other options etc. you should use v6.1.
Was ist neu in 6.0 gegenüber 5.9
S5 Rom, ROM für das Samsung Galaxy S 5
Changelist: 9493471
Major flash options
SuperSU + suhide
Odexed
Deodexed
xXx Tweaks
Keyboards
Kernel selections
Xposed
Good Lock
Modded Camera
- New G900F Rom base CQAV
Change list 9493471
New Android Security Patch Level – Jan. 1, 2017
New Bootloader & Modem Combi
CQAV Bootloader
CQAW Modem
Updated several build.prop settings to improve smoothness, multitasking and lag free operation thanks to @airidosas252
More details here
Sound mods
NEW Viper4Arise/eXtremeBeats xXx Combo thanks to @A.R.I.S.E. Sound Systems and @Ben Feutrill
Set sound.mod=3 in xXx.options.prop to get it. (new default)- To get my favorite headset sound profile for perfect bass and clarity open Viper4Arise app, go to the menu and “Load Effect Profile” called “Deep Bass+Clarity” thanks to @mantakos
- After applying the profile, don’t forget to switch on the Master Power” switch in Viper4Arise
- Please Note: This new sound mod combo is not compatible with the previous one. It will completely replace any old sound mod and I didn’t add Dolby ATMOS as an option for this as this new combo itself is more than awesome especially in combination with the Effect Profile from mantakos.
- Known Issue: After each phone restart you will see the green apps updating screen for about 1 sec. Don’t worry, but we couldn’t get rid of this so far.
OLD V4A Combo is still available with the following settings:
Set sound.mod=1 in xXx.options.prop to get Viper4Android + eXtremeBeats
Set sound.mod=2 in xXx.options.prop to get Viper4Android + eXtremeBeats + Dolby ATMOS
SDcard Fix Permissions script thanks to @osm0sis
Added this script as a new option.
It’s NOT solving the known r/w access permission issues in Marshmallow but fix ownership and permissions of files and directories on the sdcard to what they would be if Android OS had put them there itself, since some apps can't access pushed files that have root.root as owner/group.
Sometimes Apps FC when trying to access/write files on sdcard even they seem to have correct r/w permissions. This might fix this issues.
Set sdcard.fix=1 in xXx.options.prop to get it. (new default)Please Note: Depending on how much files you have stored on your sdcard it can take up to several minutes to scan and fixit!! Therefore don't become nervous when Rom flashing process will stuck here for a while. It will continue. Promised J
Also this sdcard.fix option is triggered whenever you choose the new sound mod to be installed.
Updated xXx.options.prop to v14
New defaults
sdcard.fix=1
xposed=2
sound.mod=3
SuperSU 2.7.7 Stable for best compatibility
Updated Boeffla Config App to 2.4.28
Requires a system restart after a clean install and the very first initial Boeffla Settings App execution
Downloads
xXx No Limits Roms for G900F/W8
downloads for Samsung Galaxy S5 by xXx | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
Bootloader & Modems for G900F/W8
Entwickler
xXx
xXx
ROM OS Version: 6.0.x Marshmallow
Version Information
Status: Stabil
Aktuell stabile Version: 6.1
Veröffentlicht: 02.02.2017
Tag des Releases: 31.01.2016
Letztes Update: 02.02.2017
Link für xda Thread
Status: Stabil
Link für xda Thread
