G900F [ROM][4.4.2][XXU1ANJ1] *24.10.14* WanamLite v1.2
  • 6 Antworten
Glatzi84
Dauer-User
601
WanamLite Rom
vom Entwickler des sehr bekannten WanamXposed
Original Thread auf XDA
WanamLite Homepage
Changelog
Change-log 1.2 :
Based on NJ1
Update Root files
Based on the latest Official KitKat FW
Stock Odexed & Rooted & Busybox
Adam Kernel (SELinux Set to Permissive, Init.d support, Disabled Knox/TIMA verification and few other tweaks)
Large APN list
Debloated (Removed some useless Apps, available on the PlayStore)
Kies support
Removed Knox container and its Services
SHealth and Private mode support and a lot of other features through Wanam Xposed
Features :
Wanam Features list:
Call Recording
  • Auto call recording
  • 4 Ways Reboot (Reboot, Recovery, Hotboot, Download)
  • Full Color/Transparency customization for Status bar and Notification drawer elements
  • Secure Samsung Keyboard
  • Option to keep “Add Call” button with Call recording menu
  • Disable Camera shutter sound (+Screen Capture)
  • Flashlight trough volume button UP
  • Skip Music with Volume buttons
  • Save Call Logs View
  • Enable Keyboard Symbols
  • Enable Hangouts Calls trough cellular
  • Enable Camera while calling
  • Unlimited and Customizable Multi-View support
  • Bypass Exchange Lock check (Must be enabled before account setup)
  • Notification Panel Customization
  • Long Home key behavior
  • Long Back key to kill App (+ white list)
  • Disable increasing ringtone
  • Messaging Tweaks (raise limits and conversion)
  • Disable Scrolling cache
  • Enable Full rotations
  • White/Colored Circle Battery
  • Transparent Notifications panel
  • Customize Clock format and size
  • Customize Battery text helper size
  • Customize Quick Settings buttons number per row
  • Collapse Quick Settings after toggle
  • 2 line formatted date on the panel header
  • Dark themed Multi-Window
  • Disable Boot sound
  • Customize Two line date header format
  • White/Black Email App background (Supported on some devices)
  • Transparent Quick Settings buttons background
  • Default hidden SMS logs
  • Add Call button to Logs and Contacts list
  • Disable Accounts icons on Contacts list
  • Custimize Wifi AP Clients number
  • Disable Launcher page rotation
  • Add Exit button to browser
  • SMS Automatic input mode
  • Disable Call number formatting
  • Enable unlimited Contacts joining
  • Enable Gallery Rotation trough button
  • Set default Browser view to Desktop
  • Hide Wireless charging popup
  • Hide Full Battery Notification
  • Clock position Status bar (Hide, Left, Right, Center)
  • NFC behaviors (UN/Locked on Screen ON/Off)
  • Hide Headset icon and notification bar
  • Disable TW DVFS
  • Blacklist for Application where you want to disable DVFS when it’s default enabled
  • Hide Smart Stay, Alarm, NFC icons on status bar
  • Launcher: Enable Scroll wallpaper and Hide Dock labels
  • Disable Wake Home button
  • Use separate Address field on Contacts
  • Add Fast PIN unlock (to be used with caution)
  • Added SMS sent time details
  • Enable Screen ON options on Messaging App
  • Disable low Battery warning
  • Add custom carrier label on notification label
  • Set low Camera battery level
  • Change System Holo Dark/Light background
  • Acces hidden Lockscreen shortcuts menu
  • Disable SEAndroid/Knox notifications and container
  • Disable volume control sound
  • Disable low battery sound
  • Auto Disable Knox notifications when Knox Apps are installed
  • Set SELinux to Permissive mode on boot
  • ScreenShot and ScreenRecord (Requires Busybox) on Power menu (KitKat FWs only)
  • CM Numeric Circle battery (Kitkat Roms only)
  • Screen Off animation (CRT/Fade) (Kitkat Roms only)
  • Expand all notifications
  • Disable Temperature check on Camera recording and Flash
  • Enable Heads up notifications for Kitkat Builds (Optional ongoing notifications and display delay customization)
  • Support SHealth and Private mode (Disable secure storage on both Apps)
  • Disable battery and USB cover warning
  • And more to come
Important Notes:
  • Make a Nandroid Backup (Including EFS)
  • A Wipe data is recommended if you came from any other custom Rom
  • After Private mode setup, Do NOT clear your Personal pages service data (You will loose your private data)
Installation
Kopiert das Rom auf die Interne sdcard
Flasht
den neuen Bootloader und Modem
Flash-ROM-Datei über CWM Recovery
Neustarten und Installiert Xposed Installer , und installiert Wanam Xposed , aktiviert den Xposed Installer
Starten & genießen
Downlaod
SM-G900F_WanamLite.XXU1ANJ1.V1.2.NO-WIPE.zip
(MD5: 60465CFF78EF92B3E634EB916276EF3B)​
Donations und Danke <--- klick mich
Platzhalter
Danke für die Übergabe.
OP wird angepasst sobald i zu hause bin und an den PC komme...
Reaktionen: Muppi
Neues Update auf 1.1 ist da.
hat schon jemand Erfahrung mit dieser Rom und kann etwas dazu berichten?
Würde mich auch interessieren und ob die rom sauber läuft?
Also ich habe die Rom seit gestern drauf, und was soll ich sagen, läuft super und mit dem Adam Kernel ja sowiso ;)
wo finde ich denn die ganzen Einstellungen?
danke
edit gefunden :)
Neuestes Update im OP gelistet :thumbsup:
Triple_H72
Nobby1960
Nobby1960
borisbecker01
tlmiles
travor
Angel30
Angel30
