AntiHer0
Costum Recovery hast du schon ?
V.2.0:
- Android 5.0 (LRX21T) Lollipop
- Firmware base: XXU1BOB7 (build date February 13rd) (Silent mode is back! + LP app pinning)
- Final: Added latest G900I/K/L/S/W8/T/M Stock kernels as an option
- Final: Updated System Android Webview to v.40.1728298-arm
- Final: Updated Google Play Services to v.7.0.87
- Final: Updated SuperSu to v.2.46
- Final: Updated Google Play Store to v.5.3.5
- Final: Updated Ktoonsez Lollipop TW custom kernel to v.26-02-2015
- Final: Updated G900K/L/S kernel and wifi fix to the latest G900K Lollipop BOB1 firmware
- Final: Changed default Ktoonsez kernel profile to an modified version of Smoothmaniac v2
- Final: Updated BusyBox to 1.23.1
- Final: Updated Google Messenger to v.1.0.131
- Final: Added extra quick toggles option, including an flashlight toggle (they will show up after 2nd reboot after an clean install)
- Final: Removed Knox version information from Settings app
- Final: Enabled 'Unkown sources' at default (Settings -> Security)
- Final: Enabled 'Show all content while locked' at default (Settings -> Sounds & Notifications) to show full notification info on lockscreen
- Final: The 3 animation scales are set to 0.5 at default now
- Final: Added Google Backup/Restore & Feedback at default to the ROM
- Final: Added NEE CSC
- Final: Many more changes & fixes (by me & Samsung)
- 12 Toolbox mod (at default in the ROM)
- optional 5-way reboot menu!
- Updated Google Keyboard to v.4.0.21203.1613964
- Deodexed using the latest oat2dex.jar by @_riddle
- Disabled 'Software update' option in Settings -> About device
- Disabled KNOX in build.prop
