G900F [ROM][4.4.2][FXXU1ANG2] *06.12.14* AllianceROM v5.6 [Themes]
  • 460 Antworten
heavymetall66
heavymetall66
Dauer-User
245
Reaktionen: Steveria, Deerix, Droidbabe und 5 andere
Alliance Manager App
ist wie eine Ein-Klick App um verschiedene Themen für das Gerät zu installieren. Von hier könnt Ihr aus einer Auswahl verschiedenster Themen die Standard setzen und ein Backup dieser Einstellungen durchführen.
Zu beachten ist, dass damit keine Bilder als Hintergründe geladen werden können, die App stellt im Prinzip die Weichen zum Setzen der vorgegebenen Mods.
Changelog
Changes in 5.6:
Updated Alliance Settings to new application with sliding tabs nav drawer and more;
Added abstract tiles, mont blanc and brilliant ring lockscreen effects thanks Tamirda
Lockscreen information layout centred like note 3 thanks Tamirda
Added new battery icons;
Added more themes to Alliance Manager;
Added OTA for ROM updates and link to alliance rom website Thanks Kryten2k35;
Added keyboard background wallpaper;
Added keyboard key shadow colour;
Added toggle for sound mode bar to be stock blue or transparent;
Fixed recent item colour in landscape;
Added an ota option for toggle background;
Disabled HDCP for screen mirroring to work;
Fixed private mode toggle choice;
Minor fixes and maybe other things forgotten.
Changes in 5.5:
This is more a clean up and fix build...24 themes added to Alliance Manager as seen below and all code cleaned up and issues fixed. Wallpaper support also added so themes will change your lock and home wallpaper. Hopefully you guys will be happy with it. Oh and added Note 4 weather widget with thanks to @Tamerlan2009
Point to note: To experience the themes as intended you should use AOSP theme. They will work just fine on Stock and BlackGlass but the screenshots were all taken on AOSP theme
Changes in 5.4:
Any color/transparency popups (e.g powermenu bg) with toggle - make your own tinted glass backgrounds!
Any color popups text with toggle
Any color/transparency list menu bg with toggle
Hold statusbar and slide for brightness with toggle
Ime animations
Totally new statusbar clock from Liquid
Clock seconds toggle
Clock font style choice (font dependant)
Statusbar date style choices
Statusbar date format choices
Pulldown right/left/center access quicksettings
Radio button color linked to checkbox color
Ime animations
Ime cursor control with vol buttons with toggle
Extended reboot follows powermenu color
Headsup Blacklist
Action bar text color with toggle
Actionbar bg color with toggle
Custom Carrier in statusbar with toggle
Double tap statusbar sleep with toggle
Overscroll type - none/bounce/glow
Overscroll weight...i.e how far it bounces or glows
Added the ng2 kernel to install options for those who have new bootloader and made it so if select ktoonz you will get his kernel apps and if select 900i kernel it will also install the nfc fix
Probably one or two more fixes etc...I lost track
Changes in 5.3:
Working Private Mode - clear data of personalpageservice if you face problems
Added option to use private mode with insecure lockscreen
Added option to disable the ongoing Private Mode notification
Added private mode toggle back to dropdown - download OTA update
Added 2 dropdown panel animations and option for none - thx to @Nunhugger and @Tired Storeman
Fixed settings fc on pressing notification panel
Fixed keyboard fc on changing button to comma
Fixed icon for custom app 7 - download OTA update
Fixed heads up ongoing causing fc on making a call
Added Nfc option for screen off, onlockscreen or unlocked only and nfc icon type
Something for easter to test a concept
Changes in 5.2:
Added 3rd color for Statusbar Gradient
Added 3rd color for Dropdown Gradient
Added Option for custom wallpaper on Notification Items with alpha slider
Added 3 color gradient for Notification Items
Added Omni traffic meter with options for left or right side, update interval, hide when inactive and download/upload colors
Added Settings text color
Added Settings Icon color
Added 4 sets of icons for settings and powermenu and custom settings to OTA Thx @Tired Storeman
Added HeadsUp Notifications with toggle
Added options for HeadsUp Notifications - Include Ongoing, When Locked, Limit to High Priorty only
Added slider for HeadsUp Notifcation fade speed
Added colorable glow for Heads Up Notifications
Added option to diable screen dimming on pulling down dropdown panel
Added CM Ram bar in recents with mode selection and 3 colorable bars
Added Quick Unlock with toggle
Added option for custom lockscreen carrier text
Added Reboot and Recovery dropdown toggles
Added more dropdown date formats and custom entry
Added color picker for recent items background
Added 2 extra batteries to selection
Added floating message apk to enable floating messages
Changed Black Glass settings icons to match theme Thx @Tired Storeman
New Bootanimation - Thx @NunHugger
Added Alliance Overscroll glow - Thx @Tired Storeman (Stock is in OTA)
Fixed typos and default values in Custom Settings and had a bit of a rearrange
Fixed Alliance App Panel FC if uninstall custome app
Fixed Alliance App Panel custom apps 2 and 3
Fixed some email content text colors
Fixed Settings block list FC
Fixed Pull Up in Alliance Settings so app can be changed
Fixed TW Themes all app icon not changing
Fixed hide battery when charging
Fixed Alliance Theme contacts FC
Fixed Alliance Theme tab selected to white
General clean up of code to remove some old unused stuff
Einige Screenshots
24 Themes neu!
Läuft diese Rom so stabil wie die Omega Rom?
Kann ich diese einfach drüber Installieren?
Ist bei der Rom auch schon das Update vom 31.03.2014 (Stabilitätsupdate) enthalten?
Ed
Stabil läuft sie ,
Update ist natürlich schon drauf...
nächstes Update wohl nach den Feiertagen:thumbup:
Schöne Ostern!
Hm, jucken würde die mich schon, alleine wegen den OTA Updates.
Bei Omega muss man ja immer die ganze Rom Laden und das nervt.
Habe mal die build.prop verglichen, die ist bei beiden fast gleich, außer das bei dieser die securytie auf enable ist.
Runter geladen habe ich sie auf jedenfall schon.
Danke, auch schöne Ostern
Habe gestern Abend mal versucht diese Rom zu Installieren, aber die Installation bricht sofort ab. :confused2:
ich klink mich hier seit langem wieder mal ein ;)
hab gestern die rom , streng nach vorschrift , angefangen mit cfroot , philz recovery danach kompl wipe und dann rom drauf gemacht .
beim 2. anlauf hats dann geklappt .... muss sagen ... geniale rom :) hut ab
Reaktionen: heavymetall66
Ich habe es auch mehrfach versucht, aber vielleicht liegt es auch an TWRP?
Edit:
Es lag an TWRP, mit Philz hat es geklappt!
Sollte man im ersten Post erwähnen.
Ed
Der ursprüngliche Beitrag von 11:47 Uhr wurde um 12:22 Uhr ergänzt:
Muss man eigentlich alle Update laden oder reicht es wenn man das letzte nimmt, in dem Fall das 3?
ich hab alle geladen , da ich erst alle funktionen danach gefunden hatte ;) weis aber jetz nicht obs an mir lag oder es so sein soll ;)
Hab jetzt auch alle Updates geladen, danach war erst alles da!
Nur die Updates bleiben im Ota weiter sichtbar, ist das bei dir auch?
Was mich noch stört ist, dass es keinen Automatischen reboot macht obwohl es einen diese Option nach bem Download anbietet!
Der ursprüngliche Beitrag von 13:15 Uhr wurde um 13:54 Uhr ergänzt:
Edit:
Ich gebe auf und bleib bei meiner Rom.
1. ja die bleiben bei mir auch bestehen , aber das stört mich nicht .
2. ja das mit reboot is bei mir auch so gewesen , machte mir aber ehrlich gesagt genausowenig , im gegenteil , ich mach das lieber von hand .
schade das du die freude an dieser rom verloren hast , ich für mich kann nichts negatives entdecken .....
was ist "deine" rom ( bitte pm um hier topick zu bleiben )
Gibt's schon Info über neues update von heute ? Xda hab ich auch nix gefunden .
Momentan wird an einem größerem Update "geschraubt" , wird wohl morgen oder übermorgen verfügbar sein...jetzt gibt's update4 über OTA!!
Reaktionen: mred33
Ich meinte das update 4 . Obs dafür Infos gibt
Nein , leider nicht ...
wie kann man die uhr auf 24 stunden stellen?
V1.1 verfügbar! Dirty Flashing über bestehendes System, anschließend keine zusätzlichen Updates drüber flashen... Bin grad beim laden
Reaktionen: mred33
gibt es schon eindrücke zu 1.1 ?
Flashen sinnvoll ?
Definitiv!
Läuft 1A keine FC oder reboots...
Einzig mein catlog läuft ununterbrochen, wenn ich diesen benutze...
Grüße
Reaktionen: mred33
