G900F ROM[06/04] [G900F/M/I/K/T/S/W8][5.1.1] V6.0 REVOLUTION S5 (S6E +NOTE 5) Xposed
  • 86 Antworten
RomBeast
RomBeast
!!--Weder ich der Entwickler oder Android-Hilfe haften für schäden am Gerät Flashen auf eigene Gefahr--!!
REVOLUTION S5
ROM FEATURES
- S6 edgeand People stripe
- Note5 Accuweather
- Note5 TouchWiz Home with Themes Support
- Note5 Message App
- Note5 Settings
- Note5 Keyboard
- Note5 Health
- Note5 Smart Manager
- Note5 Gallery
- Note5 Email
- Note5 Dialer and Contacts
- Note5 SystemUI
- Note5 My Files
- Note5 Music
- Note5 Calculator
- Note5 Calendar
- Note5 GalaxyApps
- Note5 WallpaperPicker
- Note5 S Browser
- Note5 Optical Reader
- Note5 Smart Remote
- Note5 Clock
- Note5 Video App
- Note5 Memo
- Note5 Voice Recorder
- Note5 S Voice
- Note5 Theme Store
- Note5 Theme Center
- More!!
Support Device G 900F/M/I/K/T/S/W8
TESTED ONLY WITH G900F
- Stable and Faster
- Rooted / Deodexed / Zipaligned / Busybox / Deknoxed
- Stock kernel, init.d and battery tweak
- Multiple Languages and downloadable keyboard languages
Based oN Note5 and s6e
Android 5.1.1
Fully stable flexible and
Xposed
With viper sound
Finally v6.0 is here
v6.0
REMOVED
CHANGELOG V6.0
New base..
Aroma selectible mm theme and xposed
this build have some bugs im noteremember so itwill be fix
you can write here or PM me
DOWNLOAD V5.3 FULLY STABLE
Revolution S5 Xposed v5.3.zip | by liamstears for Galaxy S5
MARSHMALLOW THEME FOR V5.3
Thanks to @ROBERT CM
¡¡ MARSMALLOW FULL THEME v1 FOR REVOLUTION v5.3 !!
¡Hi guys! I share my personal Marsmallow Full Theme v1 for Revolution v5.3
Changelog v1:
- Add full icons 6.0 & 6.0.1 MM on all apps
- Replace entire icon pack with 6.0 TouchWiz icons
- Update TouchWiz with latest 6.0 icons and color for folders
- Themed Clock con 6.0.1 icons
- Themed SMusic & Voice Recorder app like 6.0 MM
- Add icons for MM Power Menu
- Add S6 MM Weather Iconos for Accuweather
- Full Themed SystemUI & Lockscreen like 6.0 MM
- Add GalaxyApps 6.0.1 MM
- More and More ..
Changelog v2:
( coming soon, work on progress ..)
- Themed Phone app like 6.0 MM
- Themed Contacts app like 6.0 MM
- Themed Message app like 6.0 MM
- Themed Smart Manager app like 6.0
- Full Themed framework con MM 6.0 elements and color
- Themed Settings app like 6.0 MM
- More and more ..
Installation:
1. Flash vía CWM/TWRP
2. Wipe cache y dalvik cache (recommended)
3. Reboot
4. Enjoy ..!!
Credits & Thanks:
- Albe95
- ManuProN5
- Alemtro95
- ROBERT CM
- @liamstears
Big thanks to @ManuProN5 @Albe95 for all your help and files ..
Downloads:
Marsmallow Full Theme v1 For Revolution v5.3
Marsmallow-Full-Theme-v1-by-ROBERT-CM.zip | by ROBERT CM for Galaxy S5
If you like my works, leave a thanks mate, motivate a lot to developer ..!
DOWNLOAD V5.2
http://forum.xda-developers.com/show...php?p=64355926
DOWNLOAD V5.1
CHANGELOG
AROMA INSTALLER REMOVED
Updated xposed
Fixed CSC installtion BRAZIL
Added new CSC's
Added new CSC features
CSC fixes (no more messaging bug)
Fixed quick settings toggles
New photoeditor, no more fc's all functions work + extra functions
Brightness fix
ram management fix
build.prop tweaks
Added missing application permissions, this will now work in smart manager and in settings under applications heading
Modded Settings and removed SysScope so device status is shown as Official
Removed some remaining knox file
DOWNLOAD V5.1
https://drive.google.com/file/d/0ByC...p=docslist_api
3minit battery for V5
XDA-Thread:
ROM [G900F/M/I/L/K/T/S/W8][5.1.1] V5.3 TW REVOLUTION S5 (S6E +NOTE 5) Xposed
Reaktionen: mIStone, timonoeske21 und Olli von G
!!--ACHTUNG WICHTIG--!!
Flashe hispasian kernel nach dem Rom boot
Link https://drive.google.com/file/d/0ByC...p=docslist_api
23 TOGGLE https://drive.google.com/file/d/0ByC...p=docslist_api
PHOTO EDITOR FIX. https://drive.google.com/file/d/0ByC...p=docslist_api
BERIEFING ZIP. https://drive.google.com/file/d/0ByC...p=docslist_api
!!--ALL IN ONE FIX--!!
INCLUDE:
1)Camera filters fixed
2)Floating message enable in menu
3)csc mods (Data compression in browser,enable save and restore sms,etc)
4)Fixed people edge full work in right side
Maybe videocall works but I'm not sure
And more....
Ah...and a little surprise!notification ringtones
https://drive.google.com/file/d/0B8j...ew?usp=sharing
---------- MODS ----------
CSC Mod fix: csc mods.zip von @it87
@alemtro @Chainfire @amarullz @geiti94 @Albe95 @alexndr @yuguo0522 @samsung
@sksarfaraz @Repulsa
@RomBeast,
selber schon installiert?
Gruß 84Odin
Ja habe es gerade geflasht. Läuft momentan gut gucken wie es auf dauer ist nur die Edge sache funktioniert nicht
Reaktionen: 84Odin
Screenshots:
Reaktionen: 84Odin
@RomBeast,
erst mal danke für die Info.
Hast du direkt nach dem Rom Boot den Hispasian Kernel installiert? Also bevor du an deinem S5 irgendetwas eingerichtet hast, wie Google Konto, WLAN Verbindung usw?
Gruß 84Odin
Habe mir die Rom auch mal drauf gezogen, jetzt ist erst mal Titanium dran alles wieder her zu stellen und dann mal schauen wie die Rom läuft :smile:
Bei mir ist die Tastatur Standard Grau und nicht so schön bunt, kann man das irgendwo ändern?
Reaktionen: zbot
@84Odin
Ja habe es direkt nach flash draufgemacht muss sagen momentan läuft die Rom gut. Und Heute Abend Zeige ich euch mal Screenshots vom Akkuverbrauch kann mich momentan nicht beschweren. :) Nur bei mir Funtkioniert dieses RSS-Feed zeug usw. nicht.
@TheFlown
Bei mir war die Tastatur komischer weise nach Flashen so musst erst im Anwendungsmanager die Tastatur Data löschen. Habe selber keine Ahnung wie das passiert ist suche dir doch einfach im ThemeStore ein nettes Theme.:) ;)
Reaktionen: TheFlown und 84Odin
Kann ich den Kernel auch vor dem ersten booten flashen oder muss ich erst einmal booten?
@Olli von G Mach das besser direkt nach dem boot
Reaktionen: Olli von G
Dann mach ich das
Der All in one fix for revolution rom.zip Fix von "Koenig87" sollte im Startpost mit aufgeführt werden...
INCLUDE:
And more....
Reaktionen: RomBeast
@RomBeast,
weißt du warum es so wichtig ist, nach dem ersten Boot, direkt den Hispasian zu flashen? Ich habe diese Rom heute mal installiert und mir ist aufgefallen das auch bei dieser Rom der genau gleiche Kernel läuft, wie auf der Sixperience. Also der Nowenui Kernel. Dass kommt mir jetzt schon etwas komisch vor, dieser dringende Hinweis, im Bezug auf des flashens des Hispasian Kernels. Da ja meines Wissens der Sixperience Thread auf XDA, genau deswegen geschlossen wurde.
Gruß 84Odin
@mikle_01 Danke mache ich jetzt
@84Odin Weiß auch nicht warum, wenn der Entwickler meint das ist besser... wird wohl irgendein grund haben....
Reaktionen: 84Odin
Muss man die anderen dann auch flashen oder reicht der aio
im AIO sollte ja alles drin sein @Olli von G
@Ice23,
genau deswegen frage ich. Dann müsste ja dieser Thread auch geschlossen werden. Da ja der Nowenui Kernel fester Bestandteil der Revolution Rom ist. Auf die Sixperience Rom konnte man ja auch im Nachhinein den Hispasian Kernel flashen. Und der Thread wurde ja trotzdem geschlossen.
Gruß 84Odin
@84Odin Dann könnte ich aber kommen und die Kernel ersetzten oder der Entwickler ;)
Reaktionen: 84Odin
Mit NowenUI-Kernel gibt es evtl. Probleme ( Schließung im XDA ) .
Mit Genehmigung von ShinySide ( Kernelentwickler HispAsian ) KANN der Kernel Bestandteil der Rom werden und sollte damit "sauber" :winki: sein .
( siehe XDA-Post # 28 )
Es stellt sich nur die Frage , ob es überhaupt eine Einigung ( Zusammenarbeit ) zwischen Rom-Dev. und Kernel-Dev. geben wird , da dieses "Problem" bei einer anderen TW 5.1.1 - Rom ( :winki: ) ja bis heute nicht gelöst ist !!!???
Reaktionen: TheFlown, RomBeast und 84Odin
Triple_H72
borisbecker01
borisbecker01
borisbecker01
tlmiles
RomBeast
sabo690
sabo690
