Fifaheld
Dauer-User
- 386
Imperium LL Rom v18.2
Features:
Kernel:
Removed:
Integrated:
Xposed:
Mods:
Tweaks:
Request:
Flashable tar with odin:
PG1 Modem (CP section in odin)
PG1 Bootloader (BL section in odin)
How to install:
*** COMPATIBLE WITH OLD BOOTLOADER ***
--> Download <--
>>> Change log & Tweaks post 2<<<
Changelog:
Known issues:
- No Menu button on S6 Browser --> You have to choose "3dot menu" mod in aroma
- MAPS don't work in Note4 Weather Widget app integrated in the ROM--> You have to install the stock S4 Weather Widget app from OTA updates
- No SIM Card detect (no signal) --> needs PF3 modem and bootloader
XPOSED
For the framework:
For any modifications/modules that you want to install:
I'M NOT RESPONSIBLE FOR ANY POSSIBLE DAMAGE DONE TO YOUR DEVICE AS A RESULT OF FLASHING.
I WILL NOT TAKE ANY RESPONSABILITY FOR BRICKED PHONES OR LOST DATA.
CREDITS:
Thanks to Google for Android OS, Samsung for Sammy FW and source, @JustArchi for the kitchen, @amarullz for aroma installer, @joeldroid for the deodex tools, Razvan Miron for the Imperium Main Banner and to all the authors of mods and tweaks on my ROM.
Quelle XDA
Features:
- Based on the official 5.0.1 FW I9505XXUHQG1
- Fully Themed like Android Marshmallow (Thanks to HITMAN-CREED)
- Deodexed
- Zipaligned
- Busybox
- Aroma installer (Thanks to amarullz)
- Auto format system before flashing the ROM
- Knox Free
- Compatible with Old Bootloader
Kernel:
- Imperium Kernel
Removed:
- Some GAPPS and Bloatware
Integrated:
- AdAway Material Design (thanks to mrRobinson and Lozone)
- Android System Info
- FasterGPS
Xposed:
- Xposed framework (thanks to rovo89 and arter97)
- Xposed app Material Design (Credits to @DVDandroid)
- Wanam Xposed - (credits to wanam)
- Greenify - (thanks to oasisfeng)
- GravityBox - (thanks to C3C076)
Mods:
- Viper4Android (thanks to viper520 and zhuhang)
- 3Minit Battery Mod (thanks to gharrington)
- 5 Way Reboot
- Multi CSC
- Lock Button on statusbar
- Home Button on statusbar (OTA)
- 3dot menu (choice in aroma)
- Toolbox
- S5 Mirror Link
- S5 Gallery
- S5 MyFiles (Archivio)
- S5 Memo (Promemoria)
- S5 MirrorLink
- Note3 One Hand
- Note4 Side Key Panel
- Note4 popup MultiWindows
- S7 wallpapers
- S7 and S6 Edge Plus sounds
- S6 boot and shutdown animations
- S6 wallpaper
- S6 keyboard
- S6 Browser
- S6 My Files
- S6 Magnifier
- S6 TouchWiz, Widget Meteo and fonts
- S6 Peel SmartRemote
- S6 Optical Reader
- S6 SnapBizCard
- AOSP Clock
- Android M wallpaper
- Android M sounds
- Android M calculator
- Android M bootanimation
- Note5 sounds
- Note5 bootanimation
- Added Theme Support (thanks to @thehacker911) with more themes for S4 TW (thanks to Albe95 and @HITMAN-CREED)
- Note5 theme for S4 TouchWiz (thanks to binh24)
- Enabled TorchLight in Settings/Display
- Enabled "Edit after screen capture" option in Settings/Display
- Enabled more additional lockscreen effects
- Enabled Ambient Display on Settings
- Enabled Grey Scale in Power Savings
- Enabled many other hidden features
- Disable/Enable boot sound in aroma
- Enable/Disable Cam sound when you START and STOP a video
- Enable/Disable LOW Battery alarm sound in aroma
- Hide Sms/Mms in the call log
- Added Call Recording
- No increasing ring tone
- Secondary Symbol on the keyboard (choose it in aroma)
- Scrolling wallpaper in home for S4 TouchWiz users (choose it in aroma)
- and more...
Tweaks:
- build.prop tweaks
- 3G tweaks
- Fix Color Fade Memory Leak
- Performance, moderate and battery saver
Request:
- Recovery custom (Philz or TWRP)
How to install:
- Flash a Custom Recovery like TWRP or Philz Touch.
- Copy the zip Imperium_LL_Rom_vX.X into your SD Card.
- Reboot into Recovery mode.
- Install "Imperium LL_Rom_vX.X.zip".
- Follow the Aroma Installation Wizard.
- Push "Next" and Restart the device.
- After reboot open Themes & Select Galaxy Note 5 Themes.
- Done!
- N.B.: if there is signal issue, needs to flash the tar files with odin
--> Download <--
- Version 18.2
- MD5: 7bc76a661644d5e0618ce9d7fe0a50c5
Changelog:
v16.0 - 10/09/2016
* Based on the last Samsung Lollipop 5.0.1 FW I9505XXUHPG1
* Updated Imperium Kernel v4.6
* Updated SuperSU v2.78
* Updated Xposed Framework v86.2 (credits to @dkcldark)
* Updated Material Design Xposed Installer (credits to @DVDandroid)
* Updated Greenify v2.9.5 beta1
* Updated Note5 MM theme v5.5 (credits to @binh24)
ältere Changelogs:
ältere Changelogs:
v15.0 - 10/08/2016
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHPF4
* Updated Imperium Kernel v4.5
* Updated 3Minit Battery app v4.1.1
* Removed Mirror Link
v14.0 - 02/08/2016
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHPF3
* Updated Imperium Kernel v4.4
* Updated 3Minit Battery Mod v4.1
* Updated Google Play Services v9.4.52
* Updated Google Play Store v6.9.15.G
* Updated Peel Smart Remote v8.8.1
* Updated Xposed Framework v85 (credits to @dkcldark)
* Updated GravityBox LP v5.4.3
* Updated Greenify v2.9 FINAL
* Updated SuperSU v2.76
* Updated AdAway v3.1.2
v13.1 - 02/04/2016
* Updated Imperium Kernel v3.8
* Updated Peel Smart Remote v8.7.2
* Updated Note5 MM Theme v5.2 (credits to @binh24)
* Updated SuperSU v2.71 beta
* Updated BusyBox (credits to @dorimanx)
* Reworked BusyBox installation (credits to @osm0sis)
* Fix hidden Video Player in the TW launcher
* Fix Google Play Store issue with apps installed on the Ext SdCard (back to v6.0.5)
* Fix PowerOn sound issue (back to stock S4)
* Fix S Memo FC
* Fix BusyBox issue with Viper4Android
* Fix other little issues with Viper4Android
v13.0 - 07/03/2016
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOL4
* Added S7 edge wallpaper
* New S7 and S6 Edge Plus MM sounds
* Fixed SPlanner widget FC
* Updated Imperium Kernel v3.6
* Updated Peel Smart Remote v8.6.7
* Updated GravityBox LP v5.3.6
* Updated Google Play Store v6.2.13
* Updated Google Play Services v8.7.03(2645110-238)
v12.1 - 27/02/2016
* Fully themed like Android Marshmallow (credits to @HITMAN-CREED)
* Removed S6 TW (only S4 TW themed by @HITMAN-CREED)
* Note5 sounds (removed all other sounds)
* Removed S4 Keyboard (only S6 keyboard)
* Removed AOSP clock (you can find it on the Play Store)
* Removed AOSP calculator
* Added "home button on the statusbar" choice in aroma installer
* Updated Imperium Kernel v3.4
* Updated Viper4Android v2401
* Updated Peel Smart Remote v8.6.6
* Updated Gmail v5.11
* Updated Google Play Store v6.2.10
* Updated Google Play Services v8.07.2
* Replaced SuperSU v2.66 with the old v2.52
* Fixed Viper4Android issue
* Minor changes in aroma installer
v12.0 - 20/01/2016
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOL2
* Added Note5 theme for S4 TouchWiz (thanks to binh24)
* Updated SuperSU v2.66 beta
* Updated Imperium Kernel v3.3
* Updated Busybox v1.24.1
* Updated Wanam Xposed v1.3.0
* Updated GravityBox LP v5.3.4
* Updated Google Play Services v8.4.89
* Updated Google Play Store v6.0.5
* Updated S6 Peel Smart Rremote v8.6.2
v11.0 - 28/10/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOJ2
* Removed S5 Gallery
* Updated Imperium Kernel v2.9
* Updated ITV csc
* Updated SuperSU v2.52 beta
* Updated AdAway v3.1 buil 09/10/2015
* Updated Google Play Services v8.3.00
* Updated Google Play Store v5.10.30
* Updated Xposed framework v75 by arter97
* Updated Wanam Xposed v1.2.2
* Updated GravityBox LP v5.3.1
v10.1 - 28/09/2015
* Tweaked GPS config
* Set pictures quality to 100% (removed compression)
* Moved Travel and Yahoo widget in aroma>bloatware
* Updated the Imperium LL Kernel v2.8
* Updated Google Play Services v8.1.15
* Updated Google Play Store v5.9.12
* Updated Android System WebView v45.0.2454.95
* Updated S6 Peel Smart Rremote v8.4.7
* Updated all S5 apps
* Updated Wanam Xposed v1.1.3
* Removed S Health (now, you can find it on the Play Store)
* Fixed PIN unlock issue
* Other minor changes and bugs fixed
v10.0 - 13/09/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOH2
* Added Tutorial and Samsung Link in aroma installer
* Added Note5 sounds
* Added Note5 Wallpaper
* Added AndroidM bootanimation
* Updated the Imperium LL Kernel v2.7
* Updated Xposed framework v71 by arter97
* Updated Greenify v2.7.1 (choice in aroma)
* Updated Wanam Xposed v1.1.1 (choice in aroma)
* Updated GravityBox LP v5.1.5 (choice in aroma)
* Updated Android System WebView v46.0.2490.23
* Updated Google Play Services v7.9.53
* Updated Google Play Store v5.9.11
* Updated OTA Updates v2.5.3
* Updated AdAway v3.0.2 build 08/09/2015 (thanks to mrRobinson)
* Updated S6 Flipboard Briefing v1.8.0 (for S6 TW)
* Updated S6 S-Health v4.5.0.0113
* Updated S6 SnapBizCard v5.7.6.0
* Updated S6 Peel Smart Remote v8.4.6
* Removed S6 Optical Reader
* Removed S6 bootanimation
* Disabled scrolling cache
* Removed "fix notification access for 3th-party apps" (cause Air Gesture FC)
* Fixed StageFright vulnerebility
* Fixed S6 TW and AccuWheater FC
* Fixed system ringtones issue
* Other minor bugs fixed
v9.1 - 26/07/2015
* Added Mirror Link
* Added S5 Gallery
* Updated Google Play Services v7.8.93
* Updated Google Play Store v5.7.10
* Updated Gmail v5.4.9737292
* Updated Google Maps v9.12.0
* Updated Google Clock v4.0.2(2047887)
* Updated OTA Updates v2.5.2
* Updated the Imperium LL Kernel v2.4
* Updated Xposed v65 sdk21 v5 krait (thanks to artex97)
* Updated Xposed framework v3.0alpha4
* Updated Wanam Xposed Lollipop v1.0.8
* Updated GravityBox LP v5.1.4
* Updated S6 TouchWiz from the last S6 FW (LP 5.1.1)
* Updated S6 Peel SmartRemote v8.3.6
* Updated Android System WebView 44.0.2403.90
* Finally fixed video HD lag
* Fixed S5 MyFiles installation issue
* Fixed S Memo FC with Note4 Accuweather Widget and fonts
* Fixed all issues with the Note4 Side Panel Keys
* Fixed Notification access issue
* Disabled security mdpp
* More tweaks for performance and stability improvement
v9.0 - 26/06/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOF2
* Full memory leak fix from Lollipop 5.1.1 sources (credits to Google)
* Added S6 My Files (Archivio)
* Added S6 Browser
* Added S4/Note4 Accuweather Widget choice in aroma for S4 TW
* Updated the Imperium LL Kernel v2.2
* Updated Android System WebView 44.0.2403.64
* Updated OTA Updates v2.4.5
* Fixed Note4 AccuweatherWidget graphic issue
* Fixed Video HD lag
* Fixed S6 S Health profile FC
v8.0 - 20/06/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOE4
* Restored stock InCall UI
* S6 Weather and Camera icons style in lockscreen (credits to HITMAN-CREED)
* Replaced stock S4 Accuweather Widget with the Note4 Accuweather Widget (credits to HITMAN-CREED)
* Updated S6 theme for TW S4 (credits to HITMAN-CREED)
* Phone & Contacts like Galaxy S6 style (credits to HITMAN-CREED)
* Removed "Remove S-Finder and Quick Connect buttons" choice in aroma
* Added S6 SnapBizCard
* Updated the Imperium LL Kernel v2.1
* Updated GravityBox LP v5.1.3
* Updated Wanam Xposed Lollipop v1.0.5
* Updated Google Play Services v7.5.74
* Updated Xposed sdk (theanks to artex97)
* Updated S6 S-Health and Optical Reader
* Fixed memory leak (credits to @Kushan02)
* Fixed FC when push share button with S5 MyFiles
* Fixed OneHand touch issue
v7.1 - 06/06/2015
* Added Xposed framework v3.0 alpha2 (choice in aroma) [Thanks to rovo89 & arter97)
* Added Greenify v2.6.2 (choice in aroma)
* Added Wanam Xposed v1.0.4 (choice in aroma)
* Added GravityBox LP v5.1.2 (choice in aroma)
* Added Note3 One Hand
* Added Note4 Side Key Panel
* Added Android M wallpaper
* Added Android M sounds (choice in aroma)
* Added Android M clock (choice in aroma)
* Added AOSP calculator (choice in aroma)
* Updated Google Play Services v7.5.73
* Updated Google Play Store v5.6.8
* Updated the Imperium LL Kernel v1.9
* Fixed Video Player FC
* Fixed Alarm Clock FC (no needs wipe data)
v7.0 - 31/05/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOE2
* Added "hide sms/mms in the call log" choice in aroma
* Removed Google Chrome
* Fixed black statusbar with the S6 TW
* Fixed Video Lag
* Fixed "No Increasing Ringtone" installation issue
* Fixed MirrorLink issue (please, report me a feedback)
* Updated Google Play Services v7.5.71
* Updated Google Play Store v5.6.6
* Updated the Imperium LL Kernel v1.8
v6.0 - 21/05/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOE1
* Added Kids Mode Installer (aroma>bloatware)
* Updated S6 Mirror Link from the last FW
* Updated Google Play Services v7.5.62
* Updated the Imperium LL Kernel v1.7a with the OE1 initramfs
v5.1 - 19/05/2015
* Added S6 TouchWiz, Widget Meteo and fonts
* Added S6 Peel SmartRemote
* Added S6 Optical Reader
* Added aroma choice for disable Cam sound when you START and STOP a video
* Added aroma choice for disable LOW Battery alarm sound
* Updated 3Minit Battery Mod v3.1
* Updated Google Play Store v5.5.12
* Updated Imperium LL Kernel v1.7a and STweaks v1.7.3 (thanks to B--B)
v5.0 - 03/05/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOD7
* Added S6 wallpapers in wallpaper picker by default (no needs to download it from OTA)
* Added "NO increasing ring tone" mod in aroma (no needs to download it from OTA)
* Added S5 Memo (Promemoria)
* Added S6 Magnifier
* Added Magnifier, Torch and Screen Capture in Toolbox by default
* Updated aroma installer v3.00beta1
* Updated Google Play Services v7.3.29
* Updated Imperium LL Kernel v1.6
* Fixed Scrolling Wallpaper issue
* Fixed icons theme issues
v4.0 - 18/04/2015
* Based on the Samsung Lollipop 5.0.1 FW I9505XXUHOC6
* Removed Hangouts
* Removed S6 Launcher and fonts (for now)
* Added S5 My Files (Archivio)
* Added S6 theme for S4 TW
* New Settings UI (air gesture is back)
* Galaxy App moved in aroma
* Updated S6 Keyboard from the last official fw
* Updated Google Play Services v7.3.27
* Updated Google Play Store v5.4.11
* Updated Imperium LL Kernel v1.5
* Fixed "int.utent.sist." stopping issue
v3.1 - 06/04/2015
* Added Canada and Israel CSC
* Added "Edit after screen capture" option in Settings/Display
* Added "3dot menu button and Sx Soft Key as Recent Apps" choise in aroma
* Added S6 animations
* Added S6 lockscreen with centre clock and weather
* Added S6 Wallpaper
* Added S6 Keyboard
* Added S6 TW launcher
* Added Toolbox support (manage it in Imperium Settings)
* Bypassed 5 apps limit for Toolbox
* S6 fonts set as default
* Updated Google Play Store v5.4.10
* Updated Busybox v1.23.2
* Other changes and bugs fixed
v3.0 - 28/03/2015
* Based on the last official Lollipop 5.0.1 firmware I9505JVUHOC1
* Added S6 sounds
* Added S6 boot and shutdown animations
* Added S6 fonts
* Added search button to the Settings
* Added Note4 popup view MultiWindows
* Added MirrorLink support
* Added a new choise in aroma for enable the scrolling wallpaper in home (for TouchWiz users)
* Added again the hidden torch menu in settings\screen
* De-bloat:
* - Removed Samsung Hub
* - Removed Flipboard
* - Many others bloatware moved in aroma
* Updated Google Play Services v7.0.99
* Updated AdAway in material design
* Updated Imperium kernel v1.3
* Fixed graphic issue whit the colourable battery (for 3Minit battery mod users)
v2.0 - 19/03/2015
* Based on the last Samsung Lollipop 5.0.1 FW I9505XXUHOB8
* Added Imperium kernel v1.0
* Added Imperium OTA files
* Added "Silent" toggle (included in the I9505XXUHOB8 FW)
* Added many other unlock effects
* Updated and added more csc
* Updated 3Minit Battery Mod 2.3
* Updated Google Play Store v5.3.6
* Updated AdAway (thanks to mrRobinson)
* Fixed video HD issue
* Fixed Google Play Services issue
* Fixed Samsung Keyboard language FC with secondary symbol enabled
* Fixed lock button on statusbar that was installed always
* Fixed screen mirroring with custom kernel (thanks to xxjomamaxx)
v1.0 - 05/03/2015
* Initial release based on the official FW Lollipop I9505XXUHOA7
* Deodexed
* Zipaligned
* Root with SuperSU v2.46
* BusyBox v1.23.1
* Removed Bloatware
* 5 Way Reboot
* ROM Control by Kryten2k35
* Lock Button on statusbar
* TorchLight (Settings/Display)
* Enabled more additional lockscreen effects
* Enabled Ambient Display on Settings
* Enabled Grey Scale in Power Savings
* Enabled many other hidden features
* Added Theme Support with more themes (Thanks to Albe95)
* Added Call Recording
* Secondary Symbol on the keyboard
v14.0 - 02/08/2016
v13.1 - 02/04/2016
* Fix S Memo FC
v13.0 - 07/03/2016
v12.1 - 27/02/2016
v12.0 - 20/01/2016
v11.0 - 28/10/2015
* Updated ITV csc
v10.1 - 28/09/2015
v10.0 - 13/09/2015
v9.1 - 26/07/2015
* Added Mirror Link
* Added S5 Gallery
v9.0 - 26/06/2015
* Added S6 Browser
v8.0 - 20/06/2015
v7.1 - 06/06/2015
v7.0 - 31/05/2015
* Fixed Video Lag
v6.0 - 21/05/2015
v5.1 - 19/05/2015
v5.0 - 03/05/2015
v4.0 - 18/04/2015
* Removed Hangouts
v3.1 - 06/04/2015
* Added S6 Keyboard
v3.0 - 28/03/2015
* Added S6 sounds
* Added S6 fonts
* De-bloat:
v2.0 - 19/03/2015
v1.0 - 05/03/2015
* Deodexed
* Zipaligned
* BusyBox v1.23.1
* Removed Bloatware
* 5 Way Reboot
Known issues:
XPOSED
For the framework:
- You have to install the Xposed framework from aroma installer
- Download and install the module
- Launch Xposed Installer, go to the "Modules" tab (you will also get there if you click on the notification warning you that the module is not enabled yet)
- Enable the module by checking the checkbox
- Reboot
CREDITS:
Quelle XDA
