[ROM][I9505][4.4.x][GNI2][GNH7] *16.11.14* Project X *end of live*
  • 4.142 Antworten
wenn jemand helfen will sollte ein code hier drin sein irgend ein size wert
Code:
<?xml version="1.0" encoding="utf-8"?>
<com.android.keyguard.KeyguardPINView android:orientation="vertical" android:id="@id/keyguard_pin_view" android:layout_width="fill_parent" android:layout_height="fill_parent" android:contentDescription="@string/keyguard_accessibility_pin_unlock" androidprv:layout_maxHeight="@dimen/keyguard_security_height" androidprv:layout_maxWidth="@dimen/keyguard_security_width"
  xmlns:android="http://schemas.android.com/apk/res/android"
  xmlns:androidprv="http://schemas.android.com/apk/res/com.android.keyguard">
    <FrameLayout android:layout_width="fill_parent" android:layout_height="fill_parent">
        <FrameLayout android:id="@id/keyguard_securityview_area" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_marginBottom="100.0dip">
            <LinearLayout android:orientation="vertical" android:id="@id/keyguard_bouncer_frame" android:background="#40ffffff" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_marginLeft="10.0dip" android:layout_marginRight="10.0dip" android:layoutDirection="ltr">
                <include android:layout_width="fill_parent" android:layout_height="wrap_content" android:layout_marginLeft="-13.0dip" layout="@layout/keyguard_message_area" />
                <LinearLayout android:orientation="horizontal" android:layout_width="fill_parent" android:layout_height="0.0dip" android:layout_weight="1.0">
                    <EditText android:textAppearance="@style/TextAppearance.NumPadKey" android:gravity="center" android:id="@id/pinEntry" android:background="@null" android:layout_width="0.0dip" android:layout_height="fill_parent" android:cursorVisible="true" android:singleLine="true" android:maxLength="16" android:editable="true" android:layout_weight="1.0" android:imeOptions="actionDone|flagForceAscii" android:layout_marginStart="@dimen/keyguard_lockscreen_pin_margin_left" />
                    <ImageButton android:gravity="center_vertical" android:id="@id/delete_button" android:background="?android:selectableItemBackground" android:paddingLeft="24.0dip" android:paddingTop="8.0dip" android:paddingRight="24.0dip" android:paddingBottom="8.0dip" android:clickable="true" android:layout_width="wrap_content" android:layout_height="fill_parent" android:src="@drawable/ic_input_delete" android:contentDescription="@string/keyboardview_keycode_delete" />
                </LinearLayout>
                <View android:background="#55ffffff" android:layout_width="fill_parent" android:layout_height="2.0dip" />
                <LinearLayout android:orientation="horizontal" android:paddingLeft="27.0dip" android:paddingRight="13.0dip" android:layout_width="fill_parent" android:layout_height="0.0dip" android:layout_weight="1.0">
                    <view android:id="@id/key1" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="1" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key2" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="2" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key3" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="3" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                </LinearLayout>
                    <view android:id="@id/key4" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="4" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key5" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="5" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key6" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="6" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                </LinearLayout>
                    <view android:id="@id/key7" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="7" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key8" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="8" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <view android:id="@id/key9" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="9" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                </LinearLayout>
                    <Space android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" />
                    <view android:id="@id/key0" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:layout_weight="1.0" androidprv:digit="0" androidprv:textView="@id/pinEntry" style="@style/Widget.Button.NumPadKey" class="com.android.keyguard.NumPadKey" />
                    <ImageButton android:id="@id/key_enter" android:paddingRight="30.0dip" android:layout_width="0.0px" android:layout_height="fill_parent" android:layout_marginRight="12.0dip" android:src="@drawable/sym_keyboard_return_holo" android:layout_weight="1.0" android:contentDescription="@string/keyboardview_keycode_enter" style="@style/Widget.Button.NumPadKey" />
                </LinearLayout>
            </LinearLayout>
        </FrameLayout>
        <include android:layout_width="fill_parent" android:layout_height="fill_parent" layout="@layout/keyguard_securityview_overlay_layout" />
    </FrameLayout>
</com.android.keyguard.KeyguardPINView>
Der ursprüngliche Beitrag von 20:20 Uhr wurde um 20:22 Uhr ergänzt:
ich vermute es liegt an der deutschen tastatur weil 7 und 9 ... 4 buchstaben haben
Diese einhandbedienung geht bei mir nicht obwohl eingeschaltet. Ist das normal? Muss ich was zusätzlich aktivieren. Hab patch 3 drauf weil das mit dem sperrbildschirm in patch 4 für mich nicht so wichtig ist
Gesendet von meinem GT-I9505
Reaktionen: dack23
ja den patch installieren dann funktionierts
patch v 5
Zippyshare.com - UPSM-Patch5.zip
ich habe auch die platform xml ersetzt also wenn jemand kopier rechte nicht hatte sollte es das beheben
Reaktionen: schmedie, DarkAngel1971 und merlin110
hy habe die Rom noch mit dem patch 3 drauf kann ich jetzt den patch 5 einfach drüber flashen oder muß ich die Rom ganz neu flashen mit dem patch 5
mfg.markus
Reaktionen: dack23
Besten dank. Teste gleich Patch 5
mfg.markus
Ja weil immer alles von den vorherigen Patches drin ist
Changelog Patch 5?
Bitte an alle mit patch 5 testet mal die schreibrechte auf sd
Der ursprüngliche Beitrag von 21:21 Uhr wurde um 21:35 Uhr ergänzt:
merlin110 schrieb:
Changelog Patch 5?
habe ich schon geschrieben
one hand mode
neue widgets für samsung apps
google now(auf wunsch)
platform.xml(wegen fehlender schreibrechte)
Reaktionen: merlin110
Funktioniert jetzt.
Der ursprüngliche Beitrag von 21:44 Uhr wurde um 21:51 Uhr ergänzt:
Wo kann man denn den Google Now Launcher aktivieren?
Reaktionen: dack23
Patch geflasht läuft so weit .....toller Danke Text ^^
Reaktionen: dack23
DarkAngel1971 schrieb:
Funktioniert jetzt.
Müsste als app im app drawer sein
Reaktionen: Fabolicius
Nein. Leider nicht.
Edit: Sorry übersehen. Alles bestens. Danke!
Reaktionen: dack23
Kann ich bei der Rom eigentlich kein Art einstellen?
Reaktionen: dack23
ist da kid modus drin?? :) bruach dad
Reaktionen: dack23
@sazan ja Kinder Modus ist vorhanden
Nein bis jetzt bei keiner Rom soweit ich weiß
Also nur bei nicht Samsungs Roms. Wie z.b cyanogen mod
Wurden Bugs oder weitere funktionien hinzugeüfgt oder nur FIrmware mit der Rom aktualisiert ?
Bugs wurden hoffentlich nicht hinzugefügt :D
Es wurden nur Bugs gefixt
