[ROM][I9505][4.4.2][XXUNGNK4] *12.12.14* ECHOE ROM V.39.1 S5 Port, Part XIII
  • 1.450 Antworten
Nach dem letzten Update musste ich alles neu einstellen, wollte nur mal fragen ob das bei der Rom immer ist?
Diese ROM kommt ja ohne Youtube App, wenn ich die App aus dem Play Store lade wird Youtube beim öffnen der App sofot mit einer Fehlermeldung angehalten. Welche Youtubeversion funktioniert mit dieser Rom einwandfrei?
(14 September 2014) S4 Echoe Rom v31 (OFFICIAL ANDROID 4.4.4.)
Changelog/ Features
Quote:
- Updated to Official 4.4.4 Samsung Base
Country: USA (T-Mobile)
Version: Android 4.4.4
Changelist: 2437203
Build date: Wed, 27 Aug 2014 12:41:58 +0000
Product Code: TMB
PDA: M919UVUFNH7
- Modded Settings for echoe extra settings, torchlight (!!), download booster, AppOps
- Modded Systemui with the new 3MinitBattery Mod and Invisible Lock Button
- Modded SecPhone.apk for Call Recording
- Modded SecMms with the usual mods
- Modded TW Launcher for speed
- No SMS/MMS in call logs
- All the little mods that are done via CSC
(Secondary symbols in keyboard, folder view in sms, call button in contacts ,etc)
- Xposed Installer and the following xposed modules and extra apps (as shortcuts in the Echoe Settings):
Gravity Box, Wanam Xposed, 3minit Battery Settings, Network Speed Indicator, MWManager, CpuSpy, etc)
- 4 way reboot via the Echoe Extra Settings (Use Gravity Box or wanam xposed for extended power menu)
- Another exclusive unreleased "REPACKED x2" S4 AEL Kernel v6.1
- Semi- Debloated (ALL the TMO junk is gone as well as most of the gapps)
- Im sure lots of tweaks that im too lazy to list
MOST IMPORTANTLY:
- EVERYTHING WORKS (wifi, mobile data, sound, MTP)
Some of you depending on how old your stock stuff is may need to flash the 19505XXUGNH7 Modems
found here: http://forum.xda-developers.com/show...php?p=50965837
- It should be obvious that you need a CLEAN INSTALL!!
(Its not only a new base, it's a version upgrade and it's a port as well)
- Note 1: This is a NO AROMA Installer Rom
- Note 2: This Rom is meant for the International I9505. Wifi calling obviously will not work for us.
I have no idea whether it will work for TMO users.
I cannot offer support to non- International variants.
Galaxy S4 (I9505) | EchoeROM EchoeROM
Reaktionen: arjen robben
Da steht final bedeutet das das die Rom nicht weiterentwickelt wird ?
Ich habe die Rom drauf und es hat meine Simkarte nicht erkannt
immer kommt Pin eingabe
Ich habe Vodafone
:huh:
Habe auch Vodafone, bei mir läuft alles bestens.
Bei mir läuft auch alles bestens. Bis auf das Problem im angehängten Screenshot. Jemand ne Idee? Wollte fast dormancy ausschalten hatte mir beider letzten Version super geholfen nun dieser Fehler. Hab übrigens die neueste v30 drauf.
und vom aussehen her noch gleich? oder gibts au neuen launcher?
Alles gleich.
Reaktionen: kingjezdi und arjen robben
Wie läuft die V31?
EDIT: läuft bei euch die YouTube 5.9.X?
Läuft wie Butter bei mir, ich bin beeindruckt.
YouTube löppt...
und Fussnote :
OP aktualisiert---
Was ist mit international Version gemeint? Hab ein freies s4 von Amazon ist das dann dafür geeignet?
I9505 ist die internationale Version.
achso ok danke ;)
und bringt die 4.4.4 irgendwelche besonderen neuerungen zur 4.4.2 mit? Außer das es diese Version nicht mit S5 Ports gibt?
Also ich habe das Gefühl, das aufgrund der 4.4.4 Base, alles ein wenig runder und zackiger läuft.
Reaktionen: r00bst3r
kann mir jemand was zum Modem sagen ? hab das GNH7 hier heruntergeladen ,muss aber feststellen das mein S4 nun immer LTE anzeigt obwohl keiner hier vorhanden ist.
hallo leute,
habe bei v31 das problem das nach einiger zeit kommt das keine sim-karte erkannt wird und er neustarten muss und nach einer gewissen Zeit wieder.
Habe dieses Modem geflasht GSM_Modem_XXUGNH7_and_LTE_Modem_XXUGNH7
und das 2te Problem ist das er mir immer 4G anzeigt obwohl LTE hier gar nicht verfügbar ist, vielleicht kann einer weiterhelfen.
Reaktionen: RS966
Das Problem mit der SIM Karte habe Ich auch - hatte Ich auch schon bei der V29, nachdem Ich den Kernel V6.x geflasht hatte.....
Muss wohl mal nen anderen Kernel testen, ob's dann noch auftritt ....
(20 September 2014) S4 Echoe Rom v32 (VJUGNH2)
Changelog:
Quote:
- Updated to Latest Samsung 4.4.2 Base
PDA: I9505VJUGNH2
Version: Android 4.4.2
Changelist: 2507854
Build date: Fri, 15 Aug 2014 14:55:27 +0000
Product Code: ZTO
- Changed the Aroma Kernel Options a bit:
a. AEL Kernel v6.2 Mainline
b. AEL Kernel v6.2 Superlative
c. Adam Kernel
d. Talexop Kernel
e. KT Kernel
f. Stock I9505VJUGNH2 Kernel
- EVERY endless option that v30 has
Installation:
- This is a 4.4.2 Rom so you will only need the newest modems ONLY if you want to
use stock kernel
- I recommend a CLEAN WIPE (wipe data/factory reset and system) for everyone
but especially if you are coming from a S5 Port Rom or from a 4.4.4. Rom
NOTE: This ROM doesnt contain the UPSM MOD. If you want a S5 Port Rom use Echoe v30.1
.... or maybe wait a bit
Reaktionen: abemann
sav
Rosenköpfchen
darkwing_x
hanspampel
hanspampel
  • Niklas434
Holomen
Holomen
