[ROM][I9505][4.4.2][XXUNGNK4] *12.12.14* ECHOE ROM V.39.1 S5 Port, Part XIII
  • 1.450 Antworten
MaTzElUxE schrieb:
Weiß jemand was ich machen kann wegen dem Wifi-Direct? Wlan selber geht, und wurde auch mit Fullwipe geflasht.
das gleich problem hatte ich auch musst einfach im aroma allshare mit installieren dann geht komischerweise auch wifi direkt
Ok Danke mach ich mal. Verbraucht die v21 bei euch auch so viel Akku?
V22 ist online, falls es jemanden nicht mitbekommen hat. ;)
Reaktionen: Redink und abemann
Jup, allerdings erstmal "nur" ein pre-release.
Ohne Aroma Installer
(25 May 2014) Echoe Rom v.22 Pre Release Version (No Aroma) (NE5 Base)
Key Features:
This is the Pre-Release Version, meaning there is no Aroma- The following are the default options
- Updated to latest Samsung 4.4.2. Base (I9505XXUGNE5)
(PDA: I9505XXUGNE5 CSC: I9505OXAGNE5
CHANGELIST: 1567293 BUILD DATE: 13.05.2014)
- White Ported S5 Keyboard
- 4 way reboot
- Call recording
- Modded Settings and all the extra Echoe apps
- SystemUI with OG, torch and 6 toggles
- Modded S4 sms
- Modded logs provider (No sms or mms in call logs)
- Modded S4 launcher for speed
- AEL Kernel v2 repacked (with NE5 ramdisk) as the default kernel***
- In the xposed menu, added S5 Xposed Theme to change your systemui to the s5 one on the fly
- Updated Xposed Framework, SuperSU, GravityBox, WanamXposed, LED Manager,
Xposed Torch, Led Manager, Wanam Language Enabler
- All the other little mods all Echoe versions have (secondary symbols in kb, ALL LANGUAGES ENABLED,
colored splanner, exit and home options in stock sbrowser, etc. etc.)
***Note1 : The version of AEL Kernel included in the pre-release version
is the overclock one. By default the frequency settings are max: 2.1 ghz and min: 162 mhz. When you are done
with your setup, download a CPU Control app ("No frills CPU" or " SetCpu" are recommended) and set your
preferred frequency and other settings.
***Note2 : YOU REALLY NEED TO DO A CLEAN WIPE BEFORE FLASHING v22!!!
Please do not report problems if you have not done a clean wipe...
@ www.************
Reaktionen: Redink
Ohne Aroma is mir persönlich Viel lieber.
Braucht man sich nicht ständig den ganzen ungewollten "Zusatzmüll" downloaden...
Warum bekommt man seit einigen Versionen,wenn man die FD App öffnet, nur eine Fehlermeldung? Man kann leider kein FD an- bzw abschalten...:winki:
FD App?
Fast Dormancy?
ich bekomm es irgendwie nicht installiert, wähle beim Aroma installer die Apps was ich brauche Youtube Gmail, dann lädt es und dann kommen Fehler Meldungen Interneten Angehalten, Samsung Hubs angehalten obwohl die nicht mal ausgewählt waren =/ was mach ich den Falsch
abemann schrieb:
FD App?
Fast Dormancy?
Ja genau Fast Dormancy.
Na nicht direkt App da sie ja in der Echoe Kitchen verbaut ist.
Jedenfalls habe ich mit der schon seit mehreren Versionen immer das gleiche Problem. Bekomm dort immer einen Fehler nagezeigt aber warum??
Wie kriege ich die hässligen standard kontaktfotos weg? Jemand ne idee?
Wann schätzt ihr, dass die aroma-version von v22 kommt?
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Corona999999, keiner von uns ist Hellseher!
Reaktionen: corona999999
Der post war garnicht von mir, les mal richtig
Reaktionen: meine-Handywerkstatt
Verdammt, ich Hirsch....
My fail, sorry. :D
Nachdem das dann geklärt ist ;),
ich mein irgendwas von ein paar Tagen gelesen zu haben, bis die Aroma-Version erscheint.
meinst Du das vielleicht ??:
In GravityBox
Reaktionen: RS966
Post von Friedrich420 auf XDA von gestern später nachmittag ca 17:30 Uhr :
AWESOME! ! Keep the feedback coming guys!! you have made me a very happy man on a manic Monday Aroma version most likely tomorrow
Wenn alles gut geht, kommt die Aroma also heute raus ... :thumbsup:
Reaktionen: abemann und hufnagel
OP aktualisiert...
Reaktionen: RS966 und meine-Handywerkstatt
Bin mit der Pre-Version zufrieden.
Gibt's in der Rom mit Aroma eigentlich Unterschiede zur Pre..?
Ich meine jetzt nicht den aufgeblähten Zusatz Kram, sondern Unterschiede an der Rom selber....
An sich läuft die v22 im Gegensatz zur v21 wieder besser, wie ich finde.
Wesentlich Akku freundlicher und alles smooth mit dem Kt 14.05...
1.Was mich bisschen verwundert ist der Mist mit Fast Dormancy und der dort kommenden Fehlermeldung.
2. Meine Statusbar bleibt, wenn man in den Einstellungen geht sichtbar und auch bedienbar. Nicht unbedingt schön aber geht trotzdem gut. Liegt das vielleicht an dem S5 Kram der im Xposed mit bei ist?
sav
Rosenköpfchen
darkwing_x
hanspampel
hanspampel
  • Niklas434
Holomen
Holomen
