Jrejo
DarkAngel1971 schrieb:
java version "1.7.0_67"
Java(TM) SE Runtime Environment (build 1.7.0_67-b01)
Java HotSpot(TM) Client VM (build 24.65-b04, mixed mode, sharing)
C:\ApkManagerV6.1\place-apk-here-for-modding\../place-apk-here-for-modding/signedSystemUI.apk konnte nicht gefunden werden
C:\ApkManagerV6.1\place-apk-here-for-modding\../place-apk-here-for-modding/unsignedSystemUI.apk konnte nicht gefunden werden
I: Baksmaling...
I: Loading resource table...
I: Loaded.
I: Decoding AndroidManifest.xml with resources...
I: Loading resource table from file: C:\Users\Karsten\apktool\framework\1.apk
I: Loaded.
I: Regular manifest package...
I: Decoding file-resources...
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_quick_panel_on.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_quick_panel_off.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-xxhdpi/jbp_tw_quick_panel_quick_setting_button_bg_normal.9.png". Renaming it to *.png.
W: Could not decode attr value, using undecoded value instead: ns=android, name=drawable, value=0x0108109a
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_quick_panel_quick_setting_button_bg_normal.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_recent_app_bg.9.png". Renaming it to *.png.
W: Could not decode attr value, using undecoded value instead: ns=android, name=drawable, value=0x01081099
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_recent_app_tumbnail_bg.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-xxhdpi/tw_quick_panel_dim.9.png". Renaming it to *.png.
I: Decoding values */* XMLs...
I: Done.
Exception in thread "main" brut.androlib.err.UndefinedResObject: resource spec: 0x0108109a
at brut.androlib.res.data.ResPackage.getResSpec(ResPackage.java:61)
at brut.androlib.res.data.ResTable.getResSpec(ResTable.java:58)
at brut.androlib.res.data.ResTable.getResSpec(ResTable.java:54)
at brut.androlib.res.data.value.ResReferenceValue.getReferent(ResReferenceValue.java:62)
at brut.androlib.res.data.value.ResReferenceValue.encodeAsResXml(ResReferenceValue.java:46)
at brut.androlib.res.data.value.ResScalarValue.encodeAsResXmlAttr(ResScalarValue.java:44)
at brut.androlib.res.decoder.ResAttrDecoder.decode(ResAttrDecoder.java:40)
at brut.androlib.res.decoder.AXmlResourceParser.getAttributeValue(AXmlResourceParser.java:313)
at org.xmlpull.v1.wrapper.classic.XmlPullParserDelegate.getAttributeValue(XmlPullParserDelegate.java:69)
at org.xmlpull.v1.wrapper.classic.StaticXmlSerializerWrapper.writeStartTag(StaticXmlSerializerWrapper.java:267)
at org.xmlpull.v1.wrapper.classic.StaticXmlSerializerWrapper.event(StaticXmlSerializerWrapper.java:211)
at brut.androlib.res.decoder.XmlPullStreamDecoder$1.event(XmlPullStreamDecoder.java:80)
at brut.androlib.res.decoder.XmlPullStreamDecoder.decode(XmlPullStreamDecoder.java:130)
at brut.androlib.res.decoder.ResStreamDecoderContainer.decode(ResStreamDecoderContainer.java:34)
at brut.androlib.res.decoder.ResFileDecoder.decode(ResFileDecoder.java:107)
at brut.androlib.res.decoder.ResFileDecoder.decode(ResFileDecoder.java:91)
at brut.androlib.res.AndrolibResources.decode(AndrolibResources.java:238)
at brut.androlib.Androlib.decodeResourcesFull(Androlib.java:115)
at brut.androlib.ApkDecoder.decode(ApkDecoder.java:114)
at brut.apktool.Main.cmdDecode(Main.java:146)
at brut.apktool.Main.main(Main.java:77)
DarkAngel1971 schrieb:Der Umstieg lohnt sich auf jedem Fall und das nicht nur wegen der 34 Toogles.
Gründe:
- Install geht ohne Probleme von statten
- neue Camera von @Albe (XDA) mit allen Mods integriert
- 34 Toogles
etc.
* Rom läuft sehr schnell
* Akkuverbrauch auch ohne UPSM-Manager absolut in Ordnung
* viele Extras (AirCommand etc)
* Optisch ein Hingucker wer es etwas farbiger mag
(kann aber auch nachträglich über diverse Mods auf Wuala geändert werden)
...habe die Rom noch etwas mit zB. MyMagazine, LED-Blinker,
Flash Notification, Asus-Weather Widget aufgewertet und muss sagen, dass
der Erbauer "Carotix" (XDA) ganze Arbeit geleistet hat.
Ich war lange Zeit auf der Project X unterwegs, gerade wegen der S5-Angleichung.
Aber jetzt bin ich von dieser Rom überzeugt und begeistert.
