[ROM][I9505][4.4.2][XXUGNK4] *23.Jan* CarHDRom V.36s.final [S5 Port Stock and Theme]
  • 1.608 Antworten
kann ich die Transparenz
nachträglich verstellen...oder nur bei der installation ?
ich meine des geht nur bei der installation
Gravitibox
CarHDRom V.27.1 GNF1 - 4.4.2
Aroma Version - Themed - Full Transparent
Working With Old Bootloader
Based on firmware XXUGNF1
ROOTED
DEODEXED
ZIPALIGNED
BUSYBOX
SQLITE3
SUPERSU
NO BOOT SOUND
FIX NFC PAYMENT
CSC FEATURES
DELETED KNOX FILES
4WAY REBOOT
NO CALL LOG SMS IN CONTACTS
LTE ENABLE
BOOTANIMATION CarHDRom
ADAM KERNEL 2.3 thanks to @wanam
AROMA: no-wipe or full wipe
AROMA: select your apps
AROMA: select your csc
AROMA: with or without lock in statusbar
AROMA: efs backup
AROMA: icons blue or true
AROMA: statusbar icons true
AROMA: transparency 10% 25% 50% 75%
AROMA: contact icons stock or themed (iron)
AROMA: mms S4 or S5
AROMA: phone S4 or S5
AROMA: quicklauncher selected
AROMA: calculator S4 or S5
AROMA: S5 Lockscreen new
AROMA: Theme Reflex Blue new
you can change or revert all of the options in aroma
without full wipe when you want, there will be no conflict
FULLY TRANSPARENT FRAMEWORK
and no transition effect ... very fast
Apps in system:
Translate inverted/transparent
GVoice S5 new
Multiwindow inverted/transparent
Email with Exchange Security Disabled inverted/transparent
Play Store inverted/transparent
Dropbox inverted/transparent
YouTube HD inverted/transparent
AccuweatherPhone2014 S5 inverted/transparent
Google Search inverted/transparent
Google Now inverted/transparent thanks for theme inverted to @Gunthermic
Calendar S5 new
WatchON inverted/transparent
SamsungVideo inverted/transparent
Hangouts inverted/transparent
OGBattery inverted/transparent
MyFiles S5 transparent
PullUp 1-2 inverted/transparent
GravityBox inverted/themed
Sfinder inverted/transparent
Calculator S5 tranparent
Launcher S5 4X5 5X6 with rotation
RomControl
OTA
Contacts S5 transparent
Phone modded by me S5
Phone Carotix S5 / S4
Full Caller ID
Call Recording
No Increasing Ringstone
Full Transparent
Popup Incoming Call Notification
SystemUI S5 :
Battery 1%
Clock to left
Lock to right (from aroma)
Pulldown selected from GravityBox
6 Toggles
Clear button on the top (header)
flashlight toggle thanks to @Netuser
SFinder transparent
Apps added in data
Tapatalk transparent (in dark mode)
Whatsapp inverted/transparent thanks for inverted to BlackTeam
Messenger inverted/transparent
Widgets transparent:
Mms 5
Mms 4
Hangouts
Splanner
Facebook
Email
Google Search
Whatsapp
Additional Mods:
Sound Boost thanks to @contrinsan
Downloader Boost
Particle effect
DOWNLOAD V.27.1
md5: f739989e8858e2b4178f004234e8a225
Bitte mit Fullwipe flashen
Reaktionen: Mezzy und cordobah
auch mit full wipe wenn ich die v27 schon draf habe ..?
japp
Wieso ist das eigentlich jedes mal so ein Aufwand mit dem Accuweather?
Fullwipe, geflasht und immer ist Accuweather nicht gethemed.
Dann wieder die Prozedur.Mit Titanium deinstallieren, Neustart,Titanium Back von der noch funktionierenden Version aus 26.1 wiederherstellen, WeatherDaemon2014.apk installieren, Neustart und erst dann ist es wieder gethemed.
Wenn ich alles mit Fullwipe aufsetze, sollte man doch eigentlich davon ausgehen das alles normal verläuft.
Philz ist auch die aktuelle Version drauf und ich habe sogar vorher noch die Funktion Clean Install ausgeführt.Sauberer geht doch eigentlich kein flashen der ROM oder?
Dann lass ich es erst
Läuft zur Zeit Grad so gut
Der ursprüngliche Beitrag von 21:48 Uhr wurde um 22:03 Uhr ergänzt:
Oder gibt es einen guten Grund für das update?
so wie ich das sehe nur kleinkram
Welchen kernel kann man den empfehlen der nicht soooo viel akku braucht? Habe den alten bootloader
Guten Morgen,
Bekomme ständig die Fehlermeldung com.systemui wurde beendet. Habe Full Wipe gemacht und schon mehrfach neu geflasht und trotzdem kommt die Meldung wieder. V27.1
Hat da noch jemand das Problem!
Danke Button noch nicht aktiv für mich. Deswegen im Voraus DANKE:thumbsup:
Hi, habe des auch manchmal bei anderen Rom`s. Ich habe dann einfach den Kernel gewechselt.
hi und welchen kernel hast du genommen?ALE?
irgendeinen, bis das system läuft. Und wenn das nix hilft, full wipe und alles frisch installieren.
ist kids mode dabei? konnte es nicht rauslesen
Nein in der letzten Version nicht. Vielleicht morgen in der V28
Reaktionen: sazan
dann warte ich einfach mal ab
CarHDRom V.28 GNG2 - 4.4.2
Based on firmware XXUGNG2
ROOTED
DEODEXED
ZIPALIGNED
BUSYBOX
SQLITE3
SUPERSU
NO BOOT SOUND
FIX NFC PAYMENT
CSC FEATURES
DELETED KNOX FILES
4WAY REBOOT
LTE ENABLE
AROMA: 5 options for lock and clock in statusbar new
AROMA: efs backup
AROMA: statusbar icons true - blue - carotix new
AROMA: mms S4 or S5
AROMA: calculator S5
AROMA: Theme Reflex Blue - BlueLight - Orangenew
Apps in system:
Google Search inverted/transparent new
Calendar S5
OGBattery inverted/transparent new
RomControl
OTA
Full Caller ID
Call Recording
Full Transparent
SystemUI S5 :
Battery 1%
Clock to left
6 Toggles
SFinder transparent
Apps added in data
Mms 5
Mms 4
Hangouts
Splanner
Facebook
Email
Google Search
Whatsapp
Additional Mods:
Downloader Boost
Particle effect
Bitte mit Fullwipe installieren
DOWNLOAD V.28 - mega
md5: 8457e608333aa2dc41ed94ecbbe1326c
Reaktionen: The_Rock01 und Mack75
v28 erstmal nicht flashen. Man bleibt in der Bootschleife hängen !!!
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
S2-Flasher
Trucker1109
Trucker1109
