[ROM][I9505][4.4.2][XXUGNK4] *12.01.2015* Omega v40 [Omega Files]
  • 2.875 Antworten
Falls jemand ein ähnliches Problem mit random Reboots hat wie ich neulich , hier eine mögliche lösung die mein Problem gelöst hat .
Und zwar liegt das wohl am Systemcache schiessmichtot und dafür gibt es ein Xposed Framework was sich "Samsung Kitkat Systemserver Crash Fix " schimpft .
Einfach über den Xposed installer runterladen , modul aktivieren , neustarten , et voila , hatte seitdem keine Reboots mehr :)
Reaktionen: prodb
Omega v36 Opening Post and Download Center
Please read this post carefully.
Here you will find all information you need for the latest Omega Rom.
Do not download and flash before reading all the info provided here!
Download Center can be found at the end of this post
Changelog:
Based on firmware XXUGNG8 Android 4.4.2 (Date: 23/07/2014)
Kernel talexop v2.51
Updated:
ANT Radio Service
Backup manager for apps and data
Chrome
Flipboard
Play Music
Hangouts
Hide It Pro
HP Print Service Plugin
Notification Manager
WiFi Scheduler
TripAdvisor
Recycle Bin
All mods from previous Omega Kit Kat 4.4.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
Direct Download Links for v36 added to Omega Files Pro (with resume option)
Update repo to Omega Files Pro to get the updates for v36
Please read the following before flashing:
knox:
The new Omega is based on Samsung Android 4.4.2 Kit Kat firmware and it needs the new bootloader to work.
This mean the knox will be triggered and your warranty will be void, more info:
All you wanted to know about KNOX Void Warranty 0×1
Installation:
1. Backup your device (nadroid backup, titanium backup, efs backup ... etc) and save the backup to a safe place.
2. Flash the new bootloder and modems with odin
Bootloader -> BL_I9505XXUFNAD_481100_REV06_user_low_ship_MULTI_C ERT.tar.md5
If you already have the new Kit Kat bootloader there is no need to flash it again.
Modems XXUFNC9 -> I9505XXUFNC9_GSM_LTE_Modems.tar
Power off device completely, then boot to download mode and flash bootloader (if needed) and modems with odin
Then boot to android and check if the new modem XXUFNC9 flashed ok (if wifi is not working is normal)
3. Boot to Recovery --recommended TWRP, get the latest version from here -> TeamWin Projects - TWRP 2.7 - Samsung Galaxy S4 (i9505) | TeamWin--
and flash Omega and then boot to android.
You can flash without full wipe if you are coming from a previous Omega Kit Kat version, if not then flash with full wipe
EDIT: Its reported that current 4.4.2 versions are working with the old bootloader
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
SuperSu:
Opens SuperSu and update SU binary, then choose normal and reboot device.
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation
Download Center:
Please do not make mirror links
Donation:
If you like Omega v36 + Omega Files app and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: viech-doc, Deutz40 und hoffisoft
Alter Bootloader ohne Knox: welches Modem aktuell verwenden?
userpulsar schrieb:
....Wer noch den alten Bootloader hat sollte via Odin ein neues Modem flashen...der Pulsar
Mezzy schrieb:
...Also vorsichtig mit der Wahl eines ganz neuen Modems, denn die sind nur für den ganz neuen Bootloader....
Ich habe noch den alten Bootloader ohne Knox und will den behalten. Welches aktuelle Modem kann man damit gefahrlos verwenden?
Ein klasse Rom. Danke Indie!
@Evilflasher
Der DANKE-Knopf müsste bei Dir eigentlich funktionieren, oder? :winki:
Sei doch nicht albern. Gibt auch ein button "ein klasse rom"? :rolleyes:
Danke "sagen" meiner Meinung nach höfflicher als der Button!
OT Out !!!
Reaktionen: Evilflasher
@BBF-Android
Das ist nur DEINE Meinung. :lol:
BTW: Haben wir jetzt schon wieder einen Streit hier? Nur weil ich nebenbei ein Danke für Indie reklamiert habe??? (*Kopfschüttel*)
Das sind nun mal diese Forum-Gepflogenheiten.-
Reaktionen: wii360
Sehe ich ähnlich wie Optimolly. Dafür ist der Danke-Button da (Forenregeln). Also nutzt ihn.:smile:
Was nützt einem ein Danke in schriftlicher Form, INDIE liest hier eh nicht mit. So bekommt er wengistens was für seine Mühen.
Reaktionen: wii360
Bin momentan noch auf cm 11 würde aber gerne wechseln. Bleibt mir der alte bootloader erhalten, wenn ich auf omega wechsel?
Nochmals, und das stand hier und auch in anderen Threads schon mehrfach, es wir KEIN Bootlaoder mitgeflasht. Das geht beim S4 genauso wenig per Recovery wie ein Modem. Muss man alles per Odin flashen.
Wichtige Mitteilung !!!
Hallo und Guten Abend an alle.
Möchte Euch mitteilen, das ich mir ein Galaxy S5 geklauft habe und nun nicht mehr öffters hier im S4 Forum bin, da ich in den nächsten Wochen mein S4 Verkaufen werde.
Daher wäre dieser Thread Frei, für einen/r der Intresse hätte diesen Thread weiter zu pflegen, soll sich doch bei mir melden.
Besten Dank
Grüsse
BBF-Android
Falls Interesse an diesem Thread besteht, bitte an einen zuständigen Moderator wenden.:smile:
Reaktionen: BBF-Android
Omega v37 Opening Post and Download Center
Changelog:
Based on firmware XXUGNH7 Android 4.4.2 (Date: 20/08/2014)
Kernel talexop v3.3
Mods:
3MinitBattery Mod updated
Updated:
Polaris Office Viewer 5
YouTube
Trip Advisor
Samsung Link
Google Search
Google Drivw
Google TTS
Play Music
Chrome
Dolphin Browser
Dolphin Jetpack
Dropbox
Es File Explorer
Flipboard
ANT Radio Service
App Settings
Wanam Xposed
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
Direct Download Links for v37 added to Omega Files Pro (with resume option)
Update repo to Omega Files Pro to get the updates for v37
knox:
Installation:
3. Boot to Recovery --recommended TWRP, get the latest version from here -> TeamWin Projects - TWRP 2.8 - Samsung Galaxy S4 (i9505) | TeamWin--
SuperSu:
csc:
Remove bloatware:
Download Center:
Donation:
If you like Omega v37 + Omega Files app and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: Mack75, viech-doc, Evilflasher und 2 andere
kennt noch jemand eine andere Seite zum runterladen die dauert ja Stunden...
mit dieser App KLICK ME und WLan geht es deutlich schneller.
Alternative DL Quellen/mirror sind untersagt
Reaktionen: Listo
Omega v38 Opening Post and Download Center
Changelog:
Based on firmware XXUGNH8 Android 4.4.2 (Date: 25/08/2014)
Kernel talexop v3.3
Updated:
Samsung Service
ANT+ Plugins Service
Google Talkback
Wanam Xposed
Rom is No Full Wipe
Omega Files:
Omega Files Pro:
Direct Download Links for v38 added to Omega Files Pro (with resume option)
Update repo to Omega Files Pro to get the updates for v38
knox:
Installation:
SuperSu:
csc:
Remove bloatware:
Download Center:
Donation:
If you like Omega v38 + Omega Files app and you use them please consider a donation.
Omega v37 had thousands of downloads and 1 donation
Enjoy the new Omega
Reaktionen: hoffisoft
Habe den OP mal angepasst. Weiß nicht ob BBF-Android hier noch rein schaut.
Mack75
hundsmiachn
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
