I
indie
Omega v28 Opening Post and Download Center
Please read this post carefully.
Here you will find all information you need for the latest Omega Rom.
Do not download and flash before reading all the info provided here!
Download Center can be found at the end of this post
Changelog:
Based on firmware XXUFNC9 Android 4.4.2 (Date: 19/03/2014)
Kernel talexop v2.5
Updated:
Omegas multi csc
Xposed Installer
Trip Advisor
Chrome
Fixed:
Screen Mirror
All mods from previous Omega Kit Kat 4.4.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Kernel talexop v2.5
Updated:
Omegas multi csc
Xposed Installer
Trip Advisor
Chrome
Fixed:
Screen Mirror
Rom is No Full Wipe
Omega Files:Omega Files Pro:
Please read the following before flashing v28:
knox:
The new Omega is based on Samsung Android 4.4.2 Kit Kat firmware and it needs the new bootloader to work.
This mean the knox will be triggered and your warranty will be void, more info:
All you wanted to know about KNOX Void Warranty 0×1
If you flash Samsung's based Android 4.4.2 Kit Kat firmware there is no way to go back to Jelly Bean
If you are ok with this then continue, else you can get Omega v19 with android 4.3
Installation:
1. Backup your device (nadroid backup, titanium backup, efs backup ... etc) and save the backup to a safe place.
2. Flash the new bootloder and modems with odin
Bootloader -> BL_I9505XXUFNAD_481100_REV06_user_low_ship_MULTI_C ERT.tar.md5
If you already have the new Kit Kat bootloader there is no need to flash it again.
Modems XXUFNC9 -> I9505XXUFNC9_GSM_LTE_Modems.tar
Power off device completely, then boot to download mode and flash bootloader (if needed) and modems with odin
Then boot to android and check if the new modem XXUFNC9 flashed ok (if wifi is not working is normal)
3. Boot to Recovery --recommended TWRP, get the latest version from here -> TeamWin Projects - TWRP 2.7 - Samsung Galaxy S4 (i9505) | TeamWin--
and flash Omega and then boot to android.
You can flash without full wipe if you are coming from a previous Omega Kit Kat version, if not then flash with full wipe
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
csc:
Multi csc included in Omega
Remove bloatware:
You can remove all bloatware during Omegas installation
Installation:
csc:
Remove bloatware:
Donation:
Enjoy the new Omega
