[ROM][I9505][4.4.2][XXUGNG2] *20.07.14* Y.C.D Rom[S5 Features, Stability, BatteryF]
  • 36 Antworten
BBF-Android
BBF-Android
Dauer-User
268
Rom Features
V3.4
Based on the XXUGNG2 firmware
Deodexed
Zipaligned
Rooted
Busybox
Googy-Max3 Kernel
Framework-res from Ambasadii mod
Deleted symbols in the keyboard
Added story album
optimezed settings no more fc
optimized exchange sync problem
added tinted status bar
change samsung apps with galaxy apps
added and fixed samsung hub
removed some unnecessary tweaks from build.prop
And more...
S5 Apps
S5 Launcher, File Browser,
S5 Tool Box
S5 Internet Browser,
S5 Video,
S5 WatchON,
S5 Music Player
S5 Story Album,
S5 Contacts and Phone With record option,
S5 Keyboard,
S5 Email,
S5 Gallery,
S5 S Planer,
S5 Group Play,
S5 S Health,
S5 Optical Reader,
S5 S Translator,
S5 Memo,
S5 Voice Recorder,
S5 Activity Zone,
S5 S Baro.
S5 Group camcorder
S5 Samsung Level
S5 S Console
S5 Video Editor
S5 TaskManager
S5 SamsungMagnifier
S5 Firewall
S5 Backup
S5 UPSM
S5 Download Booster
S5 Air Wake Up,
S5 Baby Monitor
S5 Settings.
S5 Lockscreen
S5 Quick connect
4 way reboot menu
Facebook, Twitter, Instagram, Root Browser
Full KNOX Free
Battery Tweak
Some System and framework modification.
Removed some Bloatware (CSC Apps, OTA update, ...)
Know Bugs
Nothing!
Download Rom V3.4 MEGA
Bitte keine andere Mirrors hinzufügen. Danke!
v3.4
Final build
Fixed all bugs (Full Stable)
Rebuilded Build.prpeed amd ram tweaks
Need Full Wipe
v3.3
Fixed almost all bugs
Added ambasadii S5 Mod
And more
Need Full Wipe
v3.2
Based on XXUGNG2
Added story album
And more...
You absolutely must make full wipe ( unless you make full wipe Please don't report any bug or issue )
v3.1
Canceled
v3.0
This is last build for XXUGNF1 Base
This build is Realy Stable for daily use
Added Call Record
Added Smart Remote
Updated S5 Apps
Updated Kernel
Fix lock screen issue
Added Tamirda's S5 mod again
Some apps move the data folder
if you want to light rom you can uninstall a lot of apps
NEED FULL WIPE
v2.9
Fixed airview
Fixed S5 photostudio
Deleted Tamirda s5 mod (If you want to this mod you can download 2nd link)
Added S5 settings
Change kernel with googymax3
Fixed recovery installation problem.
Deleted Samsung Hub
Added Emergency Mode in Power menu
Added some tweaks Build.prop
And more...
This version is very close to S5
NEED FULL WIPE
v2.8
Fixed music player, upsm, camera, samsung link, AllSahare
Rebuild some framework files,
Added themes
Changed kernel with talexop Kernel i9505 NF1 v2.51
Update SU 2.0.1
More battery tweaks (realy incredible battery life)
Changed device name in build promp (you can update S5 features in Samsung Apps)
ETC...
v2.7
Based on XXUGNF1
S5 apps updated
Updated Kernel Googy-Max3 Kernel 1.0.9
Added 4 way reboot menu
Added Quick connect
Added Facebook, Twitter, Instagram, Root Browser
Added Tamirda's S5 Mod
UPSM, Download Booster, Air Wake Up, Baby Monitor, S5 Settings.
Added S5 Lockscreen
Updated SU & Bussybox
Fixed Some Framework and S5Browsers problems
More free Ram
Full KNOX Free
Removed csc apps.
And others minor changes
v2.6
Added:
Change Kernel With Googy-Max3 Kernel 1.0.7
S5 Features
Group camcorder
Samsung Level
S Console
Video Editor
TaskManager
SamsungMagnifier
Firewall
Backup
Fixed:
Samsung Link
Optical Reader
TW My Magazine
More ram tweaks and etc.
v2.5
Added: S5 Story Album,
S5 Keyboard,
S5 Email,
S5 Gallery,
S5 S Planer,
S5 Group Play,
S5 S Health,
S5 Optical Reader,
S5 S Translator,
S5 Memo,
S5 Voice Recorder,
Activity Zone,
S Baro,
fixed framework problem and it was modified for better view (very close S5)
ipv4 tweaks and zipalign on boot
v2
First Stable Release
Fix Sfinder
Add S5 Contacts and Phone, S5 Music player
Minor update, more dalvik and ram performance
Installation:
1 Reboot in recovery mod. ( Recommended TWRP)
2 Full Wipe your phone
3 Install Y.C.D Rom
4 Reboot your phone (if there is install patch)
and Enjoy
:thumbup:
Achtung:
Das Flashen der ROM ist Eure Sache. Seid euch vorher im klaren was Ihr macht. Denn weder AH, Ich, Yasan oder sonstjemand übernimmt die Verantwortung für evtl. Schäden an Euren Geräten!
XDA Member yasan
@ Albe95
@ Chainfire
@ Chaos ^_^
@ Wanam
@ Ekola
@ citymen34
@ $ideWinder
@ speedyranger
@ talexop
@ Ricardo_Is
@ oracle01642
@ googy_anas
@ gashishpetim
@ SnowPluralism
@ ambasadii
@ tamirda
Orignalthread
XDA
Reaktionen: king79 und DarkAngel1971
Ist UPSM patch v2 dabei??
Hey
[ROM][I9505][XXUGNG2] ►Y.C.D Rom◄| v3.2 | UPDATE 13/07/14 [S5 Features, Stability, Battery friendly] ist raus
v3.2
Based on XXUGNG2
Added story album
And more...
der Pulsar
Reaktionen: BBF-Android und black_belt
Hab den Rom seit gut einer Woche drauf, und alles läuft ohne Probleme
Top Arbeit
kann ich die Rom auch mit PhilsTouch install,oder giebt es dort probleme?
Ja geht .. einfach bei Install Zip unten bei dont allow uptade X raus! bevor man die ZIP Flasht ...
Grüsse
BBF
dont allow update ist in den neueren versionen der Philz nicht nich mehr vorhanden....aber trotzdem erstmal danke. werd es mal versuchen ;)
habe da noch eine frage,funzt das screenmiorring in dieser rom ?
hat jmd. vlt. bitte einen anderen link ich weiß nicht hab mit dem link iwelche probleme ?! >.<
Reaktionen: kingjezdi
Nice One!!! :D
Danke :scared:
Und weiter geht's.... v3.4 ist online
Hallo mal eine Frage. Was ist der Unterschied zwischen den beiden ?
Download S5 Patch ( Danke @Tamirda )
UPSM Mod (with tamirda's settings) Download
Läuft die Rom mit dem alten Bootloader ?
Gibt es schon Themen für diese Rom
den patch braucht man nicht mehr, der war für die v3.0
den anderen wäre den UPSM Patch, weiss leider nicht viel über den, hab nur mal hier im Forum gelesen, das man keine Widgets auf den Nova & Apex Launcher bringt, und aus diesem grunde gab es diesen Patch ...
Bitte korrigiert mich wenn ich da was falschen erzähle ...
Vileicht kann da jemand mehr über diesen Patch erzählen ... Soweit ich weiss gibt es v1 & v2 Versionen ...
Grüsse
BBF
Reaktionen: bunnys7679
Weißt du ob es ein Theme dafür gibt?
frage kurz nach ... wurde noch bei v.2.9 benutzt ... aber ich bin mir beim UPSM nicht sicher daher frage ich nochmals nach ...
Gebe dann bescheid ...
Der ursprüngliche Beitrag von 20:39 Uhr wurde um 20:41 Uhr ergänzt:
jup es gibt themas ... diese hier kannst du für jede rom benutzten ...TW natürlich... habs selber auch ...
hier [THEME][i9505/i9500][TW] BobCat Theme Lives &hellip; | Galaxy S4 | XDA Forum
Hab ja die S5 Einstellungen. Werden die auch gethemt oder nur die S 4 Einstellungen ?
das kann ich Dir nicht sagen, ich hab Echoe Rom mit S5 Statusbar aber mit S4 einstellungen, hat sich aber alles geäandert ...
Also ich denke sollte gehen ... Mach ein Backup deines Systems, und bevor die ZIP flashst Wipe Cache & Davlik dann erst Flashen ...
Gib doch bescheid wenns geklappt hat, ev mit einem Screenshot, somit wissen auch andere ob sich die S5 einstellungen auch verändern ...
Der ursprüngliche Beitrag von 21:28 Uhr wurde um 21:29 Uhr ergänzt:
und Patch und UPSM waren die gleichen ... Also braucht man beide nicht mehr , ist nun in der Rom integriert ...
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
Tubii
