->TopAZ<-
Ehrenmitglied
- 6.434
Thread steht zur Übernahme der Pflege. Siehe hier: #440 ->TopAZ<-
This is the Easiest way to root Samsung Galaxy S4 LTE (GTi9505) by DjeMBeY
Main benefits of using this method are:
- FULLY ROOTED
- No need for Insecure Kernels.
- Complete, Odin flashable Packages.
- Can be used on Non-Rooted devices.
- Binary Flash Counter will NOT increase
- System status will stay NORMAL/OFFICIAL.
- Only 1 file and you have a complete firmware including Root permission.
- Fully working KIES & OTA updates (FYI: root will be lost after software update)
ATTENTION PLEASE:
- Use Chainfire's CF-AutoRoot if you want to root your existing Stock ROM.
- Custom Recovery is NOT included. If you need one, you will need to install it separately.
- DO NOT use CF-AutoRoot for Pre-Rooted ROM's as it can mess things up!! Use it ONLY for OFFICIAL STOCK ROMs
Flashing instructions:
1. Install KIES or USB drivers from here
2. Download and run Odin from here (v.3.04 is recomended)
3. Make sure that ONLY AutoReboot & F.Reset Time is ticked in Odin options
4. Download and extract one of Pre-Rooted ROM's
5. Load extracted file (.tar.MD5) as PDA in Odin.
6. Turn OFF your phone, Press&Hold POWER+HOME+VOLUME_DOWN buttons until phone boot into Download/Odin Mode
7. Connect phone to the computer and WAIT for the drivers to be installed. You will see blue or yellow indicator in left top corner of Odin, with phone connected to port: COM:x
8. Click START and wait until you see GREEN indicator [PASS], flashing is finished
9. Unplug USB cable and enjoy.
10. If your Phone Status shows CUSTOM, remove battery for few seconds and check again, if still nothing, perform FACTORY DATA RESET.
NOTE: you can use Triangle Away, tick "System modified workaround" option and restart your phone. Device Status will change back to OFFICIAL without Factory Reset.
TESTED ON I9505!! Works like charm...
Modifications:
- latest su binaries
- SuperSU.apk
Download Stock + Rooted XXUBMF8
md5sum[8e799867428978efa050b40156423dc6]
Download Stock SLIM + Rooted XXUBMF8
md5sum[9cfddc22d61f5dcc203edaece0d8edfa]
Gelöschte Apps
md5sum[bf7767d0db718818f36ae08c156c5444]
Originaler XDA_Thread
Im XDA-Forum findet ihr noch einige weitere Links wie ein CWM-Flash-File und einige Informationen.
Ich habe, da sich bisher niemand gemeldet hat, den Thread administrativ übernommen.
Damit ist der alte TE entlastet und die ROM kann nun von mir zur Pflege übernommen werden.
Topaz
