[ROM][I9505][4.4.2][XXUFNB8] *26.02.2014* BoBCaTROM EVO V13
  • 202 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
Based on Official firmware XXUFNB8 android 4.4.2
CSC OXAFNB8 choose in aroma default Set
• Kernel ==> Repacked Stock NB8 Kernel for OLD and New bootloader (special Thx @jeboo)
• Deodexed busybox
• Zipalign new applications at boot and db optimize
• Knox free
• Modded settings with link to BoBCaTROM Control , it include many options:
- Es File Explorer
- Ad Away
- Multi Window Manager
- Cpu monitor
- Cpu monitor
- Cpu spy
- Language Enabler Thx @wanam
- Fast Dormancy
- LogCat
- MD5 Checker
- Boot Manager
- Led Manager
- Gps Fix
- Notification Toggle
- Busybox Manager
- LMT (Pie-Gesture)
- Change DPI
- App OP
- Network Speed Control ON-OFF
- Ripple/Circle Effect Lockscreen
- Viper4AndroidFX thx @zhuhang - Change battery icon on the fly and select battery charge animation thx @gharrington ==> http://forum.xda-developers.com/show....php?t=2633378[/COLOR]
- OTA Update Home with link to WUALA folder for Updates, Extra, Themes , link to XDA thread and donation button
- OTA Update Pro, automatic alerts of new release with possibility to download it directly
- Reboot menu five way (normal, recovery, download, fast, only systemui)
- Xposed installer + modules
* App DPI settings
* Greenify
* Intelli3G
* MultiwindowManager
* Youtube Adaway, Xposed Torch (Credits @wanam
- Gravity Box(Credits @C3C076==>http://forum.xda-developers.com/show....php?t=2554049 )
• Features list:
- CyanogenMod Pie controls
- Expanded Desktop
- Statusbar QuickSettings tile management with tile reordering
- Lockscreen targets
- Statusbar icon coloring
- Statusbar Brightness Control
- Statusbar icon colors
- Additional QuickSettings tiles:
- Sync on/off, WiFi AP on/off, GravityBox shortcut, Torch, Network mode (2G/3G/2G+3G switch), Sleep, QuickRecord,
QuickApp, GPS on/off, Ringer mode, Volume tile, Camera tile, ...
- Quick pulldown - switches to QuickSettings when status bar is pulled down near edges
- Auto-switch to QuickSettings when there are no notifications
- Center clock in statusbar
- Battery indicator style
- Navigation bar tweaks including cursor control keys
- Low battery warning policy
- Disable LED flashing when battery low
- Disable LED while charging
- Advanced power-off menu (reboot, recovery)
- Volume key cursor control
- Skip tracks by volume key long-press while screen off (thanks to rovo89)
- More volume levels for music stream
- Option to control safe headset media volume
- Button for clearing all recent tasks at once
- CRT screen off animation
- Minimal brightness setting
- Autobrightness levels adjustment
- Lockscreen tweaks - show widgets maximized, lockscreen background style (color fill, custom image)
- Lockscreen rotation
- Hardware key actions - menu long-press/double-tap, back long-press, home long-press
- Dithered Holo background
- Option to use solid black Holo background
- Expandable volume panel
- Option to unlink ringtone and notifications volumes
- Notification drawer style (background color, image for portait/landscape, transparency)
- Button backlight modes (default, disabled, always on while screen is on)
- Dialer (Phone) tweaks
- Launcher tweaks
- Screen recording
... more to come
• BOOTANIMATION QMG,icons,Signal, Wifi and 180battery (thx) @pas2001)
• Enabled secondary symbols on stock samsung keyboard
• Browser with exit option
• Sms will display sent time instead off received time
• Unlimited contacts join
• Fix NFC Payment
• Phone Full Caller ID thx @Carotix
• Hide sms from call logs
• Email with Exchange Security Disabled
• 4Way reboot menu
• more to come
ACHTUNG
I remember putting the new bootloader knox goes to 0X1 with loss guarantee.
NB. with the latest philzTouch there were problems in the flash, I recommend philz_touch_6.07.9 jfltexx-tested and ready
- If you already have the correct bootloader and modem NA5, ignore step 3-4.
1. Backup your device... ROM... EFS...
2. MD5 checks the downloaded zip and copy it to your device
3. install new bootloader (ODIN) https://mega.co.nz/#!ZhYiHRKI!UJ3m7y...Hyjb6nPN8O6Qj0
4. install new modem and NHLOS NA5 (ODIN) https://mega.co.nz/#!UxBUVZjJ!JPFZH3...nj1lgXh74Mldqg
5.Flash Bobcatrom v12 NA5 with fullwipe
6.Install Xposed framework and enable the modules
ATTENTION
if you have the old bootloader and want to try the rom,
after installing you can install this kernel http://d-h.st/2t2
Notice
is just to try it, there are bugs ... soft reboot when installing or uninstalling applications and are not uninstalled, you need a file manager with root permissions
for Fix security lockscreen (old bootloader)
edit bulid.prop with a file manager with root permissions
search:
security.mdpp=None
change to
#security.mdpp=None
if you have problems with wifi
search
ro.securestorage.support=true
change to
ro.securestorage.support=false
Reaktionen: tobiasth, sventehf, Steveria und 7 andere
Macht einen super Eindruck die Rom. Da hat apachi scheinbar ganze Arbeit geleistet.
Leider ist bei mir das Hintergrundbild (Tattoo-Girl) welches man in Aroma
für das Dropdown-Menü auswählen konnte, verschwunden. Ich vermute, daß es mit Lightflow zusammenhängt. Jemand eine Idee wie man das wieder hinbekommt?
Guten Morgen,
Bombe das die Rom endlich da ist, aber scheinbar geht das WiFi nicht wie ich auf XDA gesehen habe?! Weiß jemand mehr?
Gesendet von meinem GT-I9505G mit der Android-Hilfe.de App
Habs auch grad installiert und Wifi geht nicht
Hab noch den alten Bootloader drauf... Muss ich jetzt den neuen drauf machen für die Rom? Und wenn ja muss ich was dabei beachten?
Hast Du denn den neuen Bootloader und das Modem geflasht?
Hatte ich schon drauf, soll ich ggf. nochmal neu flaschen?
Edit: habe den Bootloader und das Modem aus Apachis Link installiert und nun geht WIFI
Kann dir da leider grad nicht weiterhelfen, bin noch am laden der V12.
Frage mich selbst grad ob ich das flashen soll wenn WifI nicht geht... :-/
schau mal hier, hab ich grad auf XDA gesehen....
http://forum.xda-developers.com/showthread.php?t=2299087&page=224
aber ob das klappt?
Also bei mir läuft es perfekt! Nach Anleitung installiert und bisher kein Problem mit WiFI
Morgen
Ich habe schon den Neuen Bootloader und Knox auf 0x1 was muss ich beachten wenn ich KitKat installieren will ?
Anbei ein Screenshot was mein Handy jetzt drauf hat
Gruss
Edit:
Instaliert ist Derzeit BlackBox 2.2.1
Weiß jemand wie ich die Datenanzeige neben der uhr deaktivieren kann ?
Du solltest die Anleitung beachten ;-)
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Also ich hab das Problem das wenn ich die uhr mittig haben will systemui angehalten wird. Und die uhr bleibt links. Hab beim flashen auch centeruhr ausgewählt.
Dann wird die ganze zeit splaner angehalten. Kann jemand helfen bei den beiden probs?
@Playsat
Es ist ne kleine App, im rommanager findest die, oder deinstallieren
Reaktionen: playsat
Hallo hab auch die V12 jetzt drauf und auch ein Problem!
Ich kann keine apps mehr löchen ,wenn ich sie deiinstaliere fährt das handy direkt in den neustart.
An was kann das liegen?
Mit der V11 ist alles super gelaufen.
lg patric
lg patric
@Attak76
Das ist ein typisches Fehler wenn man den alten bootloader hat, es liegt am Kernel und es gibt ausser neuem bootloader soweit ich weiß keine andere Lösung
Ich habe euch mal hierher verschoben. Bitte drauf achten wo ihr hin postet!!
Reaktionen: beicuxhaven und NapDogg
oh ich dachte ich hab den neuen drauf ,aber ich kann ja mal den neuen draufflashen oder?
Jungs ihr spielt mit dem Feuer!
Lest euch die Anleitung genau durch. Ihr könnt sonnst euer s4 killen!
Wenn man den Knoxfreien BL hat, dennoch in den Genuss von KK kommen möchte, kann sich auch mal das Rom aus meiner Sig ansehen.
Falls Knox keinen abschreckt, flasht einfach den neuen BL.
weiß jemand zufällig ob Wanam läuft auf der V12?
