[ROM][I9505][4.4.2][VJUFNB2] *28.04.2014*BinDroid_Rom_V3.1.0 *keine Entwicklung mehr*
  • 6 Antworten
BBF-Android
BBF-Android
Dauer-User
268
Features:
- Disabled signature check
- Fix SDcard read/write access
- Recompressed for less stress on RAM
- Optimized PNG files
- Removed Debugging info
- AddonPack
- BinDroid Skin
- Wanam Pre-config
- Theme
- SecLauncher3
- SystemUI
- Framework-res
- TWframework
- root
- Unsecure boot.img
- busybox
- init.d support
- sqlite3
- openvpn
- zipalign
- sysro
- sysrw
- deodexed
- System Cleaned
- NoKnox
- Basic Bloat Cleaning
- Gapps removed (PlayStore still in the ROM)
- build.prop tweaks
- changed ringtone setup
- changed default wallpapers
- removed bootsound
- removed touchsound
- Added
- Addfree
- Adobe Reader
- ES File Explorer
- TitaniumBackup
- Xposed Framework
- Wanam Module
Cleaned system even more
Removed APK's (945Mb)
- AccuweatherPhone2013
- AlarmWidget
- AnimatedScene
- ANTRadioService
- BasicDreams
- com.coolots.chaton
- com.hp.android.printservice
- com.sec.app.samsungprintservice
- com.sec.chaton
- DigitalClock
- Analog Clock
- DioDict3Service
- DualClockDigital
- EasyFavoritesContactsWidget
- EasyLauncher
- EasySettings
- GearManagerStub
- GroupPlay_25
- JobManager
- Kies
- MusicFX
- MobilePrint3
- MobilePrintSvc_CUPS
- MobilePrintSvc_CUPS_Backend
- MobilePrintSvc_Epson
- MobilePrintSvc_WFDS
- MobileTrackerEngineTwo
- MusicCommonUtility
- MusicLiveShare2
- MusicPlayerWT
- PhotoRetouching_FHD_J
- S_Translator_CSLi
- SamsungApps
- SamsungAppsWidget
- SamsungBooks
- SamsungGames_H
- SamsungHub
- SamsungHubUpdater
- SamsungLearning
- SamsungLink18
- Samsungservice
- SamsungMusic10
- SamsungOCR2
- SamsungVideo
- SamsungWallet_Stub
- SamsungWatchON
- SetDefaultLauncher
- SecCalculator_3d
- SecLiveWallpapersPicker
- SecSetupWizard2013
- SecVideoListUpg
- SecVideoPlayerUpg
- SensorService2_5
- ShareVideo
- SHealth2_5
- SimpleWidget
- SmartBriefing4x2
- SMemo2
- SNoteProvider
- SPDClient
- SPrintSpooler
- VoiceRecorder
- WeatherWidgetDaemon
- Knox app
- ContainerEventsRelayManager
- Removed fonts
- ChocoEUKor
- CoolEUKor
- RoseEUKor
- SamsungSans
- Removed livewallpapers
- NoiseField
- PhaseBeam
- Removed
- Addfree
Basic rom setup like previous versions
Cleaned even more, now 863Mb
Download Rom here --> BinDroid Galaxy S4 I9505
oder >>MEGA MIRROR<<
YOU NEED TO FACTORY RESET/DATA WIPE, WIPE CACHE & DALVIK-CACHE VIA CMW
BinDroid_GT-I9505_VJUFNB2_V3.1.0-AddonPack
Date: 2014-03-14
>>Download<<
Kernel_BinDroid_GT-I9505_V1.1.0
Created: 2014-03-06
>>Download<<
BinDroid_GT-I9505_VJUFNB2_V3.0.1-Update
Date: 2014-03-10
>>Download<<
--- >> Offizielle BinDoid Homepage << ---
:thumbup: Der
Button beisst nicht! :thumbup:
Reaktionen: cordobah
werde ich mal testen :biggrin:
Warum stellst du ein ROM vor was schon seit Wochen eingestellt wurde? Siehe auch hier dazu
[Discontinued][ROM] BinDroid NB2 V3.1.0 | Themed & Optimized | LITE - [Kernel] BinDroid V1.1.0 | UV/GPU OC | Linaro Toolchain
Oder sein Post das er sein S4 verkauft hat und sich ein M8 zugelegt hat.
Dutch Danny schrieb:
I sold my S4, and will no longer update my work here.
I will no longer get notifications of this thread.
It will stay open for others to discuss my work...
Cheers
Klick
Reaktionen: HaPe1968
Uups... Das hab ich nicht gesehen... Hab sogar unter SuFu gesucht ... Stelle nicht einfach eine Rom her wenn ich weiss das es schon eine gibt ...
Tut mir leid ..
Habs wirklich nicht endeckt .. Ehja also dann kann dieser Thread gelöscht werden ...
Sorry hanspampel.. Echt viel Zeit vergeudet :( Ja nun .. :(
Danke für die Info!
Der ursprüngliche Beitrag von 22:02 Uhr wurde um 22:04 Uhr ergänzt:
EDIT: EDIT: ist ja keine Rom hier ... Wollte nur diese Rom hier im Forum vorstellen ... Machen doch viele oder nicht ..
Ist ja nicht schlimm .. Es gibt diesen Thread hier im Android Hilfe Form noch gar ned ..
Nur bei XDA .
Ansonsten könnte man da ein paar Threads löschen die auch von XDA Kopiert und vorgestellt wurde ... hmmmm
Der ursprüngliche Beitrag von 22:04 Uhr wurde um 22:05 Uhr ergänzt:
und plus ist die eingestellt... es gibt schon eine neue version zwar die 3.1.1 wie auch kernel siehe webseite !
Lieber BBF-ANDROID
Erst richtig lesen, dann verstehen, dann überlegen und letztlich posten.
Das Rom gab's hier natürlich nicht. Habe auch keine Problem damit das du es hier vorstellst, nur wird der Anklang recht gering sein, denn die Leute erwarten Updates. Die wird es nicht geben da eingestellt und S4 verkauft.
Auch gibt es kein 3.1.1. Das ist nur fürs HTC One. Wo wir wieder beim ersten Punkt wären, richtig lesen.
Ok verstehe Dich ganz und klar..
Wie gesagt wollte es nur hier mal Posten, da ich diese Rom nicht gefunden habe, erst durchs Glaxy Tab gefunden habe.
Wollte nur was gutes tun, und andern Leuten die die Rom noch nicht kennen ev gerne mal testen würde, so wie ich ..
Denn sie ist mega schlank, die meisten überflüssigen Daten sind weg, das nimmt mich wunder... sobald die Rom heruntergeladen ist, mit Kernel, werde ich sicher Rückstellung nehmen! Wie sie ist, Screenshoot ect .... Das gibts ja leider noch nicht mal ...
Wie bei einigen Threads auch ... Denn wenn man den Screenshoot sieht, bekommt man auch eher Lust und Laune dieses Disign mal zu Installieren bzw dann die Rom ..
Wie gesagt wenn es Dich stört das ich hier den Thread eröffnet habe, dann nehme ich Deine Worte zu Herzen und man kann den Thread löschen ...
Einfach schaade um die Zeit die ich verbracht habe, alles richtig anschauen, Downloaden dannach uploaden thread super wie möglich erstellen .. und und und ... da brauch man schon gute 3-5 Stunden..
Gute Nach allerseits ... Werde Rom morgen Testen ...
Also schlicht ein schlanges Rom, mit kleinen Features wie Xpoesed. ( siehe bilder DPI / - Appdraiwer, nur 1 Seite voll Apps !!! ) ##´
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
arjen robben
hanspampel
hanspampel
