[ROM][I9505][4.2.2][XXUBMGA] *31.07.2013* Android Revolution HD 3.0
  • 81 Antworten
myreality
myreality
Enthusiast
3.898
Über die Rom:
System details:
  • Android 4.2.2 (Jelly Bean) - latest official Samsung I9505XXUAME2 firmware
  • This is improved version of stock ROM - no visual changes!
  • Very fast, clean & stable!
  • Full Samsung TouchWiz Interface
  • Multi-language (WWE)
  • For Samsung Galaxy S4 (I9505)
  • Thanks to Samsung for the base firmware
Included kernel details:
  • Stock kernel (the most stable)
ROM details:
  • Removed software (CPU) rendering - full Snapdragon 600 (GPU) rendering
  • Fully optimized and tweaked
  • Root access
  • Unsecured boot.img
  • Newest BusyBox
  • RAM optimizations
  • System signatures check enabled for system security and safety
  • Improved virtual memory management
  • Speed optimizations
  • Enabled GPU UI rendering
  • Data, cache and system partitions mounting tweaks
  • Bloatware applications removed
  • All /system applications updated to latest available
  • All /data applications updated to latest available
  • Improved CPU governors performance
  • Most optimal system scheduler
  • Disabled kernel debugging for better performance
  • Zipaligned (Improved RAM management)
  • Zipalign on boot (for user applications on data partition)
  • Fully de-odexed
  • init.d scripts (BusyBox run-parts) support
  • Auto init.d permissions set on boot
  • sysro/sysrw commands support
  • Excellent battery life!
  • Improved EXT4 performance
  • OpenVPN support
  • Most up-to-date system files permissions
  • Adobe Flash Player support
  • Support almost 24h a day
  • ...and many more!
Was wird benötigt:
  • Samsung Galaxy S4 (I9505)
  • Custom recovery (TWRP, CWM, PhilZ)
Installationsanleitung:
  • Lade dir die Rom herunter und platziere sie auf die interne SD Karte
  • Boot in den Reovery Modus (vol up + Home + power)
  • Wähle dann die .zip aus und flashe sie
  • Im AROMA Installer kannst du nun auswählen ob du einen data wipe möchtest(optional falls du von einer anderen Version kommst, Pflicht falls du von einer anderen Rom/Firmware kommst)
  • Nach dem flashen, dein S4 rebooten
Changelog:
--- release date: 31 July 2013 ---
Based on latest official Samsung I9505XXUBMGA firmware
Fixed NFC (Thanks to OptimalKiller)
Included and updated custom components:
--- Data partition ---
Adobe Flash Player 11.1.115.58 (For Android 4.0+)
Adobe Flash Player 11.1.111.50 (For Android 2.0+)
Adobe Reader 10.6.0
Dropbox 2.3.8
ES File Explorer 3.0.4
Facebook 3.3
Maxthon 4.0.4.1000
Twitter 4.1.1
--- System partition ---
Google Play 4.1.10
Gmail 4.5 (For Android 4.1+)
Gmail 2.3.6 (For Android 2.3.5)
GmsCore 3.1.36
SuperUser 1.0.1.8
SuperSU 1.30 (Only Samsung devices)
--- Aroma installer ---
Google Hangouts 1.0.2.695251
Google Maps 6.14.4
Google Plus 4.0.1.47928040
Google Street 1.8.1.1
Google YouTube 4.5.17
Google TalkBack 3.3.1
Google Chrome 27.0.1453.90
Google Music 5.0.1052J.707098
Google Keep 1.0.79
Google Search 2.5.8.675703 (For Android 4.1+)
Google Search 1.4.1.338691 (For Android 4.0.3)
Google Search 1.1.2.64376 (For Android 2.3.5)
Downloads:
HD 3.0: http://android-revolution-hd.blogspot.de/p/android-revolution-hd-mirror-site-var.html
Thread @ XDA
Reaktionen: niko2006
Würde die Rom gerne testen, aber wie bekomme ich die im IRC?
Musst dich gedulden. Das ROM wird neu gebastelt da es mit dem AROMA, wie beim HTC One, Probs bei der Installation gibt. Wer schonmal ein ROM auf dem ONE gelflashed hat, weiß wovon ich rede.
@myreality
Ne Quellenangabe wäre nicht schlecht.;)
Reaktionen: Blackman1945 und jgenz
Kann ich die einfach über eine MDM odexoded flashen oder muss die mE2 schon drauf sein?
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Müssen musst du nicht, wenn du die ME2 vorher allerdings mit Fullwipe geflasht hast, ist die Basis sauberer. ;)
Reaktionen: BIG_I
Naja, sauberer ist relativ.
Würde der ROM auch gerne eine Chance geben, aber ich warte noch auf einen Mirror ohne IRC.
Irc?
IRC = Internet Relay Chat
Ist ein rein textbasierter Chat. Dort wirst aber nicht fündig, gibt zur Zeit noch Probleme mit dem Aroma installer.
Quellenangaben findest du in jeder meiner Threads.
Hier war ich noch nicht ganz fertig als dein Hinweiß schon kam :winki:
@All OP wird aktualisiert wenn Mike die Rom freigibt. Der Aromainstaller macht beim Galaxy S4 mächtig Probleme und fliegt deswegen raus
Geht es dann noch wenn man von der mdm kommt ohne Aroma, weil bei allen anderen muss man ja die mE 2 vorinstalliert sein....
Reaktionen: Erdus
Geht vorran. Tester für 2.0 werden schon gesucht. :>
Ich hab da mal ne frage
Ich möchte die rom nutzen.
Hab root und CWM Advanced Edition PhilZ Touch. Wenn ich die rom drauf packe und neu boote bleibt er beim Samsung Logo stehen und macht nix mehr.
Was mach ich falsch?
Kamst du von einer anderen Firmware?
Wenn ja musst du wipen
Kann ich bestätigen, hatte die Stock MF8 komplett frisch via Odin aufgespielt.
1. Versuch: Aroma stürzte ab bei 10%
2. & 3. Versuch: nach ca. 30% der Installation ein Reboot und Loop beim S4 Logo.
Voll wipe hab ich gemacht aber keine Besserung. Danke aber für die Antwort.
Gleiche hab ich auch .... Auch bei full wipe :confused:
Habe es nun geschafft:
Als erstes dieses CWM (0611) flashen, dann Fullwipe +
advanced > mounts/storage > format Preload,
dann ging es wunderbar.
Ich hoffe es hilft.
Da warte ich lieber das mir zu aufwendig ;-).
Jetzt weiß ich auch warum das nicht geht der kann die Boot img nicht kopieren..... schlägt fail. Weiß wer wie mann in denn fast Boot Modus kommt bei denn s4?
Edit :
leider hat das bei mir nicht geklappt wie noisq beschreiben hatte .
ich hab das dann so gelöst =).
TWRP
normal wipe
flashed rom (aroma perfect)+[KERNEL][I9505] Abyss Kernel 1.2
rebooted
und läuft !
LG
xbampyx
sav
Rosenköpfchen
  • Niklas434
Holomen
Holomen
Fifaheld
Fifaheld
Fifaheld
