[ROM][XXELL5] RGUI JB V11 Faster.Smoother.BatteryFriendly
  • 390 Antworten
teddy3
teddy3
Dauer-User
283
[ROM][XXELL5][28 Dec] ╠█╣ RGUI JB V11 ╠█╣ ✰| Faster.Smoother.BatteryFriendly |✰ - xda-developers
RGUI JB V11
Changelog JB V11
- Based on XXELL5 firmware
- Modem BUELK1
- Added Galaxsih V2.0 b7 kernel
- Added 23 toggles
- Added crt-off animation
- Added AOSP lockscreens ( Settings -> Lock Screen -> Lock screen settings -> AOSP LockScreen )
- Added Multiwindow Control app
- Added 15INK Effect
- Added 3way reboot
- Added Torch in lockscreen ( long press menu key in lockscreen )
- Added long press volume buttons to Skip Tracks
- Added mega flipfont package
- Added RGUI Kitchen in Settings
- Updated kitchen files
- Added many scripts to tune kernel governer
- Added themed systemui, framework-res.apk and contact
- % ICS style Battery
- Updated SuperSU
- Fixed twlauncher redraw
- Improved Internet speed
- tweaks for smoothness
- tweaks for battery life
- tweaks for ram management
- tweaks for touchscreen sensitivity
- Tweaks for render UI with GPU
- Tweaks to remove lag
- Removed bloatware apps
- Proximity sensor tweak, minimized duration of black screen before
call screen appears
- Minimized duration between two rings
- Disabled scrolling cache
- Enabled Call recording
- Disabled non market app restriction by default
Quote:
Kitchen Features :-
- Notification for Latest ROM
- Download Latest ROM
- Choice for Customized kernel
- Choice for Modems
- Mods
- Themes
- Apps
- Script to tweak kernel
Kitchen Features :-
- Choice for Modems
- Mods
- Themes
- Apps
Download Link
If you are liking RGUI ROM then dont forget add 5stars to this thread
Download link for ICS
RGUI Samsung Galaxy S3 Rom by Rohit
Download link for Jelly bean
Main Page - RGUI Forum
Always Do FULL wipe, for better result
Reaktionen: rudl1220, musti19, Kaiho und 3 andere
Woher gibts den das lecker weather widget?
würde mich auch interessieren
Das ist das Asus Weather Widget.
Reaktionen: DJDAKI
kannst du mir sagen wo ich das finde, habe überall gesucht
Muss ich was wipen?
Bei einen neuen Rom ist ein full wipe immer gut.
Schon immer wieder erstaunlich was " Disabled scrolling cache " doch ausmacht :) 0 Ruckler via. Tapatalk. Das RoM läuft im übrigen sehr gut.
Reaktionen: Kamillo und powerzumsel
Top, gefällt mir sehr gut die Rom. Sehr schnell.
Taugt mir bislang auch von allen RoMs am meisten.
Auch mal installieren. Im Grunde ist das Rom aber nicht viel anders wie alle anderen bisherigen aber wissen tut man es ja erst dann genau wenn man es selber vorher getestet hat.
Ist es auch nicht aber.... Gerade ich als Tapatalk viel Nutzer merke das scrolling disable extrem, in Kombination mit meinem Lieblings Kernel meine Nummer 1.
Habe die letzten tage alles geflasht und bin hier hängen geblieben:) ich mag es.
Gesendet von meinem GT-I9300
Ich verwende auch gerne Tapatalk und bei manchen Roms bekomme ich schon oft die Kriese wenn das Scrollen mehr ein Ruckeln ist. Aber das scrolling disable haben doch eh inzwischen fast alle Rom hier oder nicht zumindest die neuesten Versionen davon.
Edit: So habe es auch drauf. Mal eine weile testen.
Da kann ich nur zustimmen.
So läuft nicht schlecht. Bis auf die fehlende BusyBox gutes Rom.
Sind die Rom´s fürs S3 immer so groß (600MB) ?
Läuft diese Rom bisher am stabilsten von allen?
Sollte man dann auch einen anderen Kernel nehmen oder den wo dabei ist?
Danke euch
Nicht alle Roms sind so groß aber die meisten schon. Ich verstehe es auch nach wie vor nicht was Samsung sich dabei gedacht hat vor allem weil der Ram eh so gering ist.
Kann mir jemand nochmal einen link senden,wo ich eine Anleitung zum flashen finde? Habe bislang die alf 2 original drauf .
Zweite Frage, ist alles in deutsch,auch beim Wetter widget?
Danke
Ergänzung : ich muss erst cwm von chainfire über odin flashen , richtig?
Wenn ich dann diese Rom flashe ,erhöht sich dann dieser unter weil es kein originales ist?
Android_Noob.
hexo07
Androidwizard
Androidwizard
borussemd
Caho
