[ROM][XXELL5] RGUI JB V11 Faster.Smoother.BatteryFriendly
  • 390 Antworten
gnOrfi schrieb:
Wo Changelog? :what:
changelog V3:-
1. Fixed Keyboard layout
2. Support Multiple CSC
3. Tried best to fix launcher lag
4. Replaced samsung Sms app to aosp
5. Cleaned up build.prop and Init.d for better results
6. Added AOSP apps as Add-ons
---> calender,calculator,email,exchange,mms,deskclock,3 D gallary,keyboard,live wallpaper
7. Added ICSwiz_UI_BETA_v0.3 thanks to jackmu95
8. Disabled lockscreen 4way rotation
9. Enabled keyboard change icon
10. Added Android battery icon
11. TW Launcher redraw is minimised by the modified services.jar thanks to UpInTheAir for the information
12. Accuweather app added as requested by users
13. Updated Gapps
14. Disabled scrolling cache
15. Enabled Call recording thanks to wanam
16. Removed sms log from call log thanks to wanam
17. Added 4way reboot thanks to kristofpetho
18. Removed keyguard and other security policies from email app
19. init.d script support
20. Samsung Camera HX-MOD v1.35 by hyperX
21. Added siyah kernel 1.1
22. Tweaks for Sqlite optimisation
23. Increased touchscreen sensitivity
24. Zipalign apps at boot
25. Tweaks for smoother scrolling
26. Removed bloatware apps
27. tweaked kernel governors
28. Removed weather widget, you can download it .........here.......
29. New live wallpaper
30. Proximity sensor tweak, minimized duration of black screen before call screen appears
31. Minimized duration between two rings
32. tweaks for wireless connectivity
33. HD Youtube player
OP updated.
Ein Glück hat er die Lockscreen 4 way rotation wieder rausgenommen. Finde, dass das Rom super läuft und wenn man momentan nicht auf die S3 Zusatz Features und 64 gb! verzichten will, dann ist man hier super aufgehoben. Wechsel zwar andauernd mit cm9 und akop, was ja dank nandroid echt flott geht, aber lande immer länger und wieder hier.
teddy3 schrieb:
Habs grad getestet, Samsung Apps geht bei mir problemlos auf dem S3 und dem Tab.
Bei mir immernoch nicht.... ich vermute doch mal, dass es bei mir zumindestens irgendwie an dem Rom liegt... Übermorgen werde ich dann mal auf R3 updaten und dann, falls es immernoch nicht geht, mit Omega 5.2 ausprobieren :-S
Ist dieses Asus Wetter widget noch drin?
Asus Wetter Widget ist noch drin
Gesendet von meinem Transformer Prime TF201 mit Tapatalk 2
Also bei mir laufen Samsung apps unter v.3.
Edit:
Kann allerdings nichts downloaden ;)
Top top top. Weiter so.
wie ist das zu verstehen?
wie kann ich das sms/mms app von Samsung wiederherstellen?
Bei mir werden sms auf dem lockscreen nicht angezeigt. Weiß jemand wie man das beheben kann? LG
Wie ist bei euch die Akkulaufzeit im Verhältnis zur Stock?
sent from SGS3 used Tapatalk.
Würde mich auch interesieren. Finde das gut :)
PS: kann man da auch Whatsapp nachrichten anzeigen lassen?
Er setzt Grad alf6 um ;)
Version kommt.....
RGUI IV
changelog IV:-
1. rearranged toggles
2. power button wake up only
3. Increased notifications,ringtone,speaker volume & Disabled camera sound
4. Disabled non market app restriction by default.
5. Stock kernel with init.d support
6. Blue ics battery icon with left side clock ( for other mods check post 2 )
7. Added AOSP apps as Add-ons
13. Updated Gapps
21. Cleaned up build.prop and Init.d for better results
28. Removed weather widget, you can download it .......CLICK HERE........
Reaktionen: Aerox, Neo3477 und Kumo
OP update.
Basiert das Update schon auf alf6?
Jep.
Reaktionen: Neo3477
verspürt ihr irgendwelche Verbesserungen bei V4. gegenüber v1.1, v.2, v.3?
Svoice ist bei mir verschwunden. Wo bekomme ich es wieder her?
Android_Noob.
hexo07
Androidwizard
Androidwizard
borussemd
Caho
