Masta_Gee81
Enthusiast
- 5.397
Galaxy S III - Rom Criskelo
Firmware LKC - Android - Jelly Bean 4.1.2
ROM V20
Base Rom LKC Android 4.1.2
Kernel Stock + Sopport Init.d
MODEM Stock .LKC
Deodex .
Zipaling.
option in Aroma Recovey TWRP.
option in Aroma CF-ROOT / TWRP recovery
ADD Init.d Script Auto BackUP EFS (sdcard/ efs.criskelo.tar.gz) By Criskelo
Mod volume of Audio
Auto wipe cache & dalvik-cache before flashing
ADD Superuser.apk.
Add Flash Player apk
Launcher 4x5-4x5 MOD
SMS are not logged in CallLog.
Mod Settimgs.apk Version Rom and theme. + Add buttons Access Tools
Roletube (download videos from youtube SD-Card/downloads).
Host updated to avoid ADS.
ICS keyboard AOSP.
AppWidgetPicker (Agrupa Widgets de una misma APP).
ADD Power Menu Extended.
ADD Callrec, option.
[MOD]No increasing ring tone.
Replaced Video by Message button on the dialer
Contact Change button Video call SMS
Skip music tracks with volume buttons long press
Camera NoteII (Allows you to choose what the button Volume)
MOD SecMMS (no MMS conversion + Unlimited SMS recipient list and More)
[MOD] Mega Bass Beats! [DSPManager]
Theme AOSP By Criskelo
ADD Sony Bravia Enghien
ADD Sony Playstation Certified
Updated Gmail.apk V4.2
[HACK] Removing keyguard and other security policy restrictions from Email apk
MOD 24 Wallpapers
ink effect From Note 2
And more...
This rom will be installed by recovery mode, your device need Clock work mode recovery before installing.
Firstly, always make an android backup before flashing any rom :
Reboot into recovery, select option "backup and restore" and choose "backup", the backup will be in your sd card / clock work mode folder.
How to install this CriskeloRom ?
IF YOU COME FROM CriskeloRom, NO NEED TO WIPE, BUT IF YOU COME FROM ICS ROM OR OTHER CUSTOM ROM : WIPE DATA FACTORY RESET IS NEEDED BEFORE INSTALLING THE FULL ROM
- Make a Nandroid backup of your current rom (mode recovery/backup and restore/backup)
- Save your user apks with Titanium backup or other (don't save system apks)
- Put the zip downloded (CriskeloRom) on your intern SD card
- Go to recovery mode and : WIPE DATA FACTORY RESET + WIPE CACHE PARTITION + IN ADVANCED/WIPE DALVIK CACHE
Your phone is now clean, you can flash the Rom CRISKELOROM :
- Install zip from sd card
- Choose zip from Intern SD card
- Go on CriskeloRom, select " Yes "
ROM INSTALLING IT WILL TAKE SOME TIME...
- When you see : install rom complete : press go back, and press reboot system now :
You are on Jelly Bean Criskelo Rom
Downloads CriskeloRom S III V20 - LKC Android 4.1.2
MD5 Sum: 49690AA7675AD091339327FF67C8FA36.zip
LINK
CriskeloRomS3-V20-LKC-MD5-49690AA7675AD091339327FF67C8FA36.zip
Mirror 1
Mirror 2
Mirror 3
Mirror 4
Mirror 5
Mirror 6
XDA THREAD
