[ROM][XXALEF][14JUN] CM-Zoom v1.0 - Stability & Performance
  • 13 Antworten
Scoty
Scoty
Ikone
1.852
Quelle: XDA
Code:
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
Features:
- AOKP/CM9 counterparts
- CM9 Launcher
- CM-Wallpapers
- Auto-start Init.d scripts
- [MOD] Android 4.0.4 Package for S3 [V2]
- RAM Scripts
- ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
- Enabled GPU UI rendering
- SD Card speed tweak
- Improved camera performance
- Zipaligned (Improved RAM management)
- Zipalign on boot for user applications on data partition
- Titanium Kernel
v1.0 Download
Credits:
ReActiveDisorder for Scripts/Help
Samsung for stock ROM
AndreiLux for Kernel
CM-Zoom v1.0 Changelog
v1.0 includes the following:
- Update: franco.Kernel r2
- Update: 720p YouTube
- Update: DSP-Manager
- Update: ICSwiz UI v0.2
- Update: CM9 /Media
- Update: CM9 Ringtone's set by Default
Reaktionen: croatia1
Haha Reviewer's :D
Ich liebe diesen Typen, 14 Jahre jung und dauernd nur am Spamen.
Bis jetzt sind ja nur schlechte ROMs am Start
Reaktionen: cust0mworx, teddy3 und ANDI&roid
v0.3 ist da. Leider kein Changelog aber soll wohl heute auch noch die v0.4 kommen.
Updating this ROM to Zoom 0.4 now.
Includes:
ROM totally rebuild w/ Kitchen instead of the old method I used to work with.
Using 0.2 Base making this 0.4
Perseus 10 Kernel
Re-Zipaligned
Added Init.d Support
ROM made by using KITCHEN!
Technically the same just switched bases for optimized and faster speeds.
Download Link for 0.4: Here
Patch 1: HERE (flash through CWM, do not wipe anything)
- Fix: Superuser is now working
Sehr bedenklich:
hört sich toll an, werd ich gleich mal testen :)
Er ist wirklich überall, hat kein Handy und postet überall irgendwelche ROMs die nur geklaut sind.
Aus Prinzip würde ich die ROM nie nutzen, die Hyper ROM ist ja auch klasse..
bekomme kein root bei der rom alle kernel durch und kein plan was da los ist
Hast den Fix geflasht?
Gesendet von meinem GT-I9300
Reaktionen: qwasd
oh mal wieder überlesen thx und sorry
v0.6 ist da. Rest siehe Start Post.
die custom geht, doch passen die original widgets nicht ganz auf den bildschirm.
v0.9 Online.
wie läuft die rom denn allgemein...funktioniert alles?
v1.0 ist Online.
Android_Noob.
zultanweb
Z
hexo07
Androidwizard
Androidwizard
