skraw
Stamm-User
- 141
Jetzt musstest Du wirklich mehr als 30 Jahre warten bis Dir einer erklaert warum Du die Games am C=64 nicht laden kannst?
LOAD "*",8,1
Bitteschoen ;-)
LOAD "*",8,1
Bitteschoen ;-)
* High recommendation CWM 6.x.x.x
* Copy the Pardus HD RoM file to your Galaxy S3's internal SD card.
* Turn off your Galaxy S3.
* Boot into Recovery Mode by pressing and holding down the Volume Up, Home, and Power buttons.
* Make a NANDroid Backup by selecting Backup and Restore. Select Backup.
* Select Wipe Data/Factory Reset. Confirm the action on the next screen.
* Select Install ZIP from SD card.
* Select Choose ZIP from SD card and then select the Pardus HD RoM file.
