[ROM][MIUIv4] Team Custom Freaks Psycho MIUI | beastly fast and stable
  • 1.097 Antworten
seltsam... ich muss mal schauen was da los ist!
Hi, da wohl Probleme beim Download bestehen, stelle ich bis CustomWorx's Link wieder funktioniert meinen Bereit...
EDIT: Offline!
Reaktionen: Vremak und cust0mworx
kurzes Feedback:
Bisher läuft alles ohne einen Fehler!
Nutze es mit Nova Launcher und siyah
Super cust0mworx.
Der ursprüngliche Beitrag von 12:36 Uhr wurde um 12:39 Uhr ergänzt:
Noch was ;-) :
MIUI ROM 2.7.20 ist raus.
[Phone]
Optimise calls modify the contact record speed
Optimisation of restore of call records from the backup and recovery
Fix using the original corrugated lock screen, call background deformation
Fix in some cases to delete call records, results in sync problems
[Contacts]
Added bulk delete contacts
Fix in some cases cannot synchronise address book
[Messaging]
Fix SMS messages unable to send in some circumstances
Fix animated GIF in the drawing page will not play animated GIF
Fix list page, rotate the screen to exit the edit mode / search mode
Fix some PNG images cannot be sent as an attachment
Fix the attachment bar height shows incorrectly
[Lock screen, status bar and notifications]
New improved status bar and notification bar shortcut switch icons (toggles menu, notification bar and list etc)
[Desktop]
Fix on recent tasks to remove a single application, causes an FC error
[Camera] (MIONE Plus Only)
New AF (Auto focus) switch
Added two new real-time filters: Classic and LOMO
New voice-activated shutter, support for taking pictures using voice
Opening zero-delay shutter, fix in some cases leads to FC error
[Themes]
Fix problems with previewing themes not loading correctly
[Gallery]
New cloud albums storage support
Fix received GIF images view via gallery problems
[Notes]
Optimize the search interface, search results, real-time display
Optimise drag notes fluency
Optimise new notes, or move the notes to the notes folder, the notes will be created as a Sticky
Fix the New Memo button on the horizontal screen will appear stretched
Fix in some cases, dragging of notes leads to FC error problems
Fix drag and delete notes pop up input method issues
[Other]
Fix open and close sync switch, did not trigger the synchronisation
Fix synchronisation instructions, In some instances there will be a null returned
Fix to closing the sync switch, changing whilst using Wi-Fi, will cause sync problems
[Alarm Clock]
MI-ONE Plus support for alarms when phone is in shutdown state
Nimmst Du die Version für Dein nächstes Update?
Wäre super ;-)
Reaktionen: cust0mworx
Also so wie ich denn Changelog lese wurde der LS Bug nicht gefixt, na toll.
wer lesen kann ist klar im Vorteil!
"Fix using the original corrugated lock screen, call background deformation"
Wann kann man mit der neuen Version rechnen
Tapatalk by TF 201
Hey,
Einer ne Ahnung wie ich bei den Themen die Schrift ändern kann?
Weiß auf hell weiß kommt nicht so gut!
Ansonsten läuft die Rom echt gut nachdem die startproblemen mit titanium Backup geklärt wurden.
Gesendet von meinem GT-I9300 mit Tapatalk
Tapatalk by TF 201
Wenn ich es zeitlich schaffe, Sonntag Nacht
________
all I want is more
Reaktionen: mred33, siegal, El_Loco187 und 2 andere
rom geht ( sofern man sich wirklich an RICHIGEN fullwipe haltet) bei mir komplett fehlerfrei und super schnell ..... akku hielt der ersten tag bei intensiver nutzung auch sehr gut durch ohne zwischenladen
mred33 schrieb:
lässt sich das allgemein irgendwie ändern das bei miui der wlanzwang verschwindet imn google play??
Jop: Downloads und dann steht unten Download nur über WLAN, das stellst du einfach auf off.
MfG El_LoCo
>>>Gesendet von meinem S3 CustomWorx MIUI mit Tapatalk2
Reaktionen: Vremak
Funktioniert bei einen von euch die Taschenlampe wenn man lange auf hometaste drückt?
Das war bei Desire immer voll praktisch!
Ja Funktioniert
Warum geht es bei mir nicht?
Muss man die Lampe erst aktivieren?
Ähhh, du meinst aber schon die schnell Funktion auf dem Lockscreen, oder? Weil das mit dem HomeButton gedrückt halten um die Lampe zu aktivieren nur auf dem Lockscreen funktioniert.
Reaktionen: Vremak und santana81
die taschenlampe bei langem drück auf die mittlere taste funktioniert .... bildschuirm darf aber bei druck nicht schwarz sein ... ergo 2 mal drücken ;)
bezüglich wlan zwang ausschalten ..... danke für die erklärung der vorgehensweise aber das hilft bei miui v4 nicht .... die meldung im market kommt dennoch .... ist ein allgemeiner bug
Komisch, bei mir kommt nach Abschaltung des Wlanzwang wie oben beschrieben im PlayStore und normalen Daten Netz keine Meldung wegen Wlan, und das habe ich bei jeder Version die fürs S3 momentan gibt so gemacht und hatte keine Probs.
App "Downloads" öffnen --> Schalter bei "Download nur über Wlan" auf "Off" --> Menü drücken --> Einstellungen --> Schalter bei "Downloadbenachrichtigung" auf "Off" --> bei Popup-Fenster mit Warntext auf OK klicken --> fertig
Screenshot:
________
all I want is more
Du kannst die rom eig public machen, benutz sie seit release und es läuft einwandfrei :))
tapatalked von meinem Samsung Galaxy S3
Ist sie bereits ;)
Viel Dank :)
________
all I want is more
Android_Noob.
borisbecker01
borisbecker01
DreiTacos
DreiTacos
DreiTacos
