[Rom - MIUI V4 - BASE SAMMY - ICS] - MIUI Galnet Mod. - Update 2.9.11
  • 71 Antworten
Hallo meine lieben,
ich habe noch nie Miui drauf gehabt.
Jetzt baut sich eine frage auf...
Wo bekomme ich die Miui Wetter Widget her?
DrAlenFeinstone schrieb:
Hallo meine lieben,
DAS, fragte ich mich auch schon oft. :D
Danke für deine hilfe quasimodo.
Die App ist installiert und im Einsatz.
So neue Version ist draussen.
Change Log 2.7.20
- MIUI Base Updated to 2.2.20
- 3 Way Reboot Removed (To Be Readded)
- Removed CRT Effect (Causing Lag)
- Additional Audio Gain Hacks
- Additional Fixes to Aroma Config Files
- 2 New Kernels Added to Aroma (SpeedMod & N.E.A.K)
- Other Kernels Updated to Latest Versions
- Cleaner Update Script
- Normal Hacks Included
- Other Tweaks to Stablise UI
Also Includes the following:
- Included Aroma Installer with a vast array of options
- Bloatware (Samsung Applications such as S-Voice, Flipbook etc)
- Apps (Adobe Flash Player, Polaris Office, Sasmung Music Player & Video)
- Google (Google Currents, Drive, Plus, Maps and Open Signal Maps)
- Kernels (Franco, Ninphetamin3, Siyah and Stock)
- Launchers (Apex Launcher, LG Home 3, MIUI and TouchWiz)
- Mods (Bravia, DSP Manager and Volume Loud Hack)
- Zipped Aligned
- Proximity Sensor Tweaks
- Touch Sensative Tweaks
- Media Stagefright Tweaks for better video streaming
- Phone Ringtone Tweaks
- Database Optimization
- Voltage Control Tweaks
- Audio Default Gain Tweaks (better sound quality)
- LED Notification Tweaks
- CPU and Ram Tweaks
- SU Updated
- WIFI, GPS and Data Tweaks for faster, more accurate lock on and tracking.
- UI tweak for buttery smooth transactions
To be done in future builds:
- 3 Way Reboot To Be Included
- Multi Lang to be included when ready
- Modem Selction to be made available in Aroma
- Clean up of Applications installed within Aroma
You may download the 2.7.20 rom direct by Clicking Here (721MB)
Please enjoy and if you have any issues please feel free to post them below.
Regards,
Mathew
Quelle
Eingangsposts Aktualisiert!
Updated 2.8.3 Online
- Downloadlink steht in Post 2 zum Download bereit
- Changelog entnehmt Ihr Post 3
Viel Spaß beim Flashen! :winki:
2.8.6 Online - Siehe Post 2!
Change Log
- 2.8.6 Includes Multi Languages (With thanks to translators..!!)
- Camera Black Bar Fix (Let me know if this works for you!)
- MIUI Base Updated to 2.8.3
- Screen Brightness Tweaks
- Kernels Updated to Latest Versions
- System UI Hack for Faster Transactions and Loading
Reaktionen: Simuur95
Nächstes Update kommt in Kürze, eventuell schon Heute Nacht!
Weekly 2.8.17 Online - Downloadlink Siehe Post 2!
Multi LP Version folgt eventuell noch
Change Log
- MIUI Base Updated to 2.8.17
Hallo bei der neuen 2.8.17 geht die theme apk nicht hat da jemand eine lösung?
Gleicher Fehler bei mir auch!
nehmt die von miui-germany kein problem damit mit den themes
Meinst du die Themen apk ersetzen?
nein die ganze rom die ist genial
Die ist zwar nicht schlecht fehlen aber viele stockapps.
Fehler ist bekannt Update wird kommen.
Es gibt ein offizieles multilang sprachpaket für miui 2.8.17 hab es installiert alles in deutsch....an den theme hat such noch nichts geändert. Man kann die theme aber direkt wechseln aus dem miui Ordner nur nicht bearbeiten..extended setting gibt es auch und funktioniert 3way reboot hab ich selber zugefügt funktioniert auch...
Update auf 2.8.24 idt da...:thumbup:
Eingangspost dazu aktualisiert!
I would like to take the time to thank Mark at MIUI Android for allowing me to post my modified roms here for your benefits and enjoyment.
Change Log 2.8.24
- MIUI Base Updated to 2.8.24
- Normal Hacks Included as shown below
Please note that the Aroma Installer file shows 18th August by mistake..!
- Zipped Aligned
- SU Updated
- 3 Way Reboot To Be Included By Default (Coming very Soon!)
- Modem Selction to be made available in Aroma (Coming very soon!)
You may download the 2.8.24 rom direct by Clicking Here! (723 MB)
Regards,
Mathew
Q
MiSeRy
Q
quasimodo
Q
Q
@HOSCHI@
@HOSCHI@
