DrAlenFeinstone
Bei mir auch so... Mal abwarten...
-Pat86- schrieb:Im Anwendungsmanager die Kontakte app suchen und Daten löschen drücken, dann sollte es gehen.
Effe101 schrieb:Was muss man da machen, dass die apps laufen?
Star TUX schrieb:Morgen!
Ich hatte einmal ein ähnliches Problem. Bei mir wurden einige GApps einfach nicht richtig installiert. Ich habe einfach neu geflasht und dann hat alles geklappt...
LG
Effe101 schrieb:Kann mann die GApps auch nach installieren, oder müssen die über den kompletten FW Flash dann mit dem Aroma gemacht werden. Wenn ja wo findet man die GApps
UltimaROM - v13.0 Ramuh
Updated to latest Jelly Bean Firmware XXEMD3
Updated ALL Mods to XXEMD3 base
Added 1% Battery Mod to Advanced Settings
Added AOSP Contacts and Dialler
Added HTC Lockscreen
Added Rotary Lockscreen
Removed Bottom 25 Toggles postion
Added Transparent/Colour Notification picker
Added Alarm Icon Toggle
Added Tab Slider and AOSP styled Tab Slider Lockscreen
Added Battery Bar
Added Toggles, Signal Icon and Battery Colour chooser
Removed many things from the installer to save space. Xperia Z Keyboard, WeatherLove Widget (get from market), LG Weather
Rotating Lockscreen removed as it messes with newer Lockscreens (sorry!)
Fixed S4 icons
Fixed S4 Sounds
Updated SuperSU
Updated a number of other apps
Updated and fixed Samsung Link
Added Google Hangouts (replacing Talk) and themed version.
Removed Swipe Dialler (unnecessary now with the AOSP Contacts)
Stock Google 4.1.2 Calculator replaces Samsung one (smaller, better RAM footprint)
Added Video Editor from Nexus 7 ROM
Fixed AOSP Vibration and IME Toggle (no longer have to toggle on and off to make it work)
Added Wakelag fix toggle - read the information carefully and decide if it's for you. YMMV.
Fixed Lockscreen torch. Now you hold the home button to activate. The screen doesn't go off while you have the Torch running.
Fixed Call Recording mod (including the delay). You can now switch off the recording button.
Added battery full notification toggle and low battery warning toggle.
Added TricksterMOD app for configuring Kernels (alongisde their respective apps, if any)
Added Blocking Mode toggle in settings
Added ExternalSD2InternalSD toggle in settings
