[ROM][I9300][4.4.2][XXUFNE2] *28.07.14* UltimaROM v17.2 Diablos [HD-VOICE][SAM/AOSP]
  • 893 Antworten
EP76 schrieb:
Ging leider nicht, den neuen Bootloader kann man anscheindend nicht so einfach wieder entfernen.
Ist aber nicht so schlimm, ich hab noch ein Triangle Away das wenigstens so lange den Counter resetet bis zum nächsten reboot. So funktioniert mein AllshareCast Dongle wenigstens.
Laut Chainfire muss man einen Stockkernel und ein Stockrecovery haben, damit man den Counter dauerhaft
reseten kann. Ich habe das versucht, sobald ich aber wieder ein Custom Rom, in dem Fall die Ultima Rom flashe, kommt wieder das rote Ausrufezeichen.:mad2:
Um den neuen Bootloader zu entfernen fand ich folgendes auf xda.
I used to get the red exclamation mark on my phone from the very first time I rooted and flashed custom Roms or kernel.
I haven't flashed this new boot loader but for those trying to get rid of it follow these steps:
- Use Triangle Away to reset the flash counters, and pull the battery immediately after rebooting starts
- Boot into recovery and perform a wipe, and pull the battery immediately after rebooting starts
- Go to SamMobile and get the stock firmware for your region
- Flash that stock firmware on your device
- Let Android boot, go through device setup (without doing any logins) until Android is fully usable again
- Reboot
- Wait at least 10 minutes
- Check Settings->About device->Status and make sure Device status is not "Modified"
- Perform another factory reset
- Boot into download mode and make sure the flash counter and system status are all set to official
These steps are given by chainfire and they helped me get rid of it. But main thing is to make sure not let your phone boot after resetting counter and wherever it says to pull battery do it as said and wait for at least 15 seconds before reinserting the battery. I had to do this whole thing twice to get it correctly. So do try this and give your feedback if it works with this new boot loader.
Reaktionen: EP76
Hallo
hab das Problem das ich seit der rom keine Namen mehr angezeigt bekomme von meinen Leuten sprich es steht nur noch die Nummer da und nicht zb Familie
Woran kann das liegen
devilisalone schrieb:
Hallo
Dieser Fix sollte das Problem lösen.
  • No_Contact_Names_fix.zip
Danke Klaus aber das ist auch nicht die Lösung. Hab auch in der Anrufprotokollen nur die Namen bei abgehenden also gewählten Nummern drin
Moin,
Update auf 8.1 ist da...
Werde es heute spät abends erst Flashen können. :mad:
Freu mich total, da endlich auch die Notificationbar transparent gemacht werden kann.
8.1
1 Download-Netzwerkfehler, warum auch immer
2 Download-Abgebochen
3 Download-wird in einer Stund geöffnet
:cursing:
Version 8.1 läuft super ohne irgend ein Wipe über die 8.0 geflasht.:thumbup:
wie lange hast du zum runterladen gebraucht?
Reaktionen: niveacreme
ich hab 25 Mbit und er ist noch nicht fertig (über eine Stunde)
Ja wie ist das eine komplett neue Version oder nur ein 40mb update? Habe um 7 Uhr Updateme eingefroren, da er sich ständig meldete....
Ganz neues Rom ;)
Hat jemand einen Downloadlink für den PC ohne updatefunktion im Telefon?
Wäre super!
Lg
Was meinst du mit updatefunktion im Telefon.
na direkt über das wlan des Telefons upzudaten mit der Updatefunktion ...
Achso ja das weiß ich eh, aber romhut geht nicht und der rest ist schweinelangsam...
Man darf hier laut den Entwikler keine Mirros Links angeben ich schicke dir ne PM da kanst du vom meinem Server laden.;)
So habe geupdatet ohne Wipe über die 8.0. Alles bestens. Matt sollte die Funktion im Installer without kernel einfügen damit der bestehende bleibt - leider ist nur der yank 2.8g implentiert.
Aktuell ist 3.0a mit der Lösung des sudden death problems.
Wie immer mein Kommentar:
Hammer ROM! :D:D:D:D:D:D
