[ROM][I9300][4.3|4.1.2][XXUGNA7|XXEMRG] *10.02.2014* Omega v56|v50.1[Themes]
  • 7.188 Antworten
Es muss e i n uptade her . Vieles funktioniert noch nicht reibungslos
Gesendet von meinem GT-I9300
:thumbsup::thumbsup::thumbsup:
::indie::
Hello Omega friends
I was very busy with work the last 2 days I was not able to read your posts.
I made progress with v45 and I hope I will be able to finalize to new rom today so you can have it tomorrow.
By the way, from my test the new leak has no bugs and problems so expect a great Omega Rom
Stay tuned for more later!
xda-developers - View Single Post - [ROM][XXUFMB3|XXEMC3][19Apr] Omega v44.4 ●►JB 4.2.1|4.1.2◄●Omega Files●►12 Themes◄●
Freu mich schon
Reaktionen: diddsen
Hab die Stock 4.2.2 drauf... Hammer ;)
Noch flüssiger als früher..
Indie:
Hello Omega Family,
I stayed up late last night and I manage to finish the new Omega v45
All goodies from 4.2.1 rom added and more.
Also Omega Settings with the usual mods and MW support.
I am uploading the new v45 now so Omegas Team can test it.
I will try to make add support for v45 to Omega Files tonight after work.
If all goes well the new rom will be released tomorrow,
stay tuned for more later
...bin gespannt!
Reaktionen: Chris_84, Bl4ck3vil und Nekromonga
New version Omega v45 Jelly Bean 4.2.2:
Based on beta firmware XXUFME3 Android 4.2.2 (Date: 08/05/2013)
Kernel Stock XXUFME3
Modem BUEMD1
Multi 128 csc set to EUR
Busybox v1.20.2
efs Backup (added the option to create efs backup during installation)
init.d support without the need of a kernel that supports init.d
Aroma installer - Installation is fully customizable by user and there is options to install everything or remove all Bloatware - read here for more info
User can flash apps and bloat apps any time without the need to flash again the whole rom, (flashing the rom once is required)
Full Wipe option
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Added:
Omega Files app - can be removed from Settings > Applications if someone has OF Pro app
Omega Settings app
Omegas - Emblem bootanimation by our artist anbech
Omegas - Emblem Shutdown Animation by our artist anbech
Omegadroid wallpaper added in default wallpapers
SuperSU
Mods:
Reboot menu with Recovery and Download
Email with Exchange Security Disabled
Call Recorder
Phone with no increasing ringtone
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Modded YouTube by rolle (can download videos)
Note II POPUP Browser
Battery % mod
Completely Silent Camera
TouchWiz with wallpaper scrolling
TouchWiz with Rotation
Hide sms from call logs
No sms to mms conversion
Unlimited contacts to sms - mms
Enable sub Symbols on Stock Samsung keyboard
Added exit menu to stock web browser
Disable Scrolling cache
Menu Long Press to kill app
Security check disabled
Samsungs Task Manager Shortcut app with Multiwindow Support by indie
Omega Settings
Enable - Disable Auto Call Recording for Incoming calls
Enable - Disable Auto Call Recording for Outgoing calls
Enable - Disable Increasing Ringtone
Enable - Disable Wallpaper Scrolling
Enable - Disable Blocking Mode Icon
Added Multi Window support to Omega Settings
Google apps from Android 4.2:
Playstore
Gmail v4.2
Camera and Gallery from Android 4.2
Keyboard Android with Gesture Typing from Android 4.2
Keyboard with Emoji Support from Android 4.2
Clock Application from Android 4.2
Omegas addon applications:
SuperSU
Flash player Support
Es File Explorer
Hide It Pro
Download All Files
ZArchiver
Addfree
FastDormancy Toggle for I9300 by gokhanmoral
CPU Adjuster v2.7.5 by bartito
Acount Sync Profiler by bartito
Removed:
Bloatware
Boot sound
Charger Connection Sound
Tweaks:
build.prop tweaks
Stock Theme Changes:
Omega Theme for aroma installer by our artist anbech
Black status bar
Accuweather Widget transparent
Updated:
All apps to their latest version
All mods from previous Omega JB 4.2.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files Pro:
Support for v45 will be added soon to Free & Pro apps!
Direct Links Added to Omega Files Pro
Please read the following before flashing v45:
1. Make sure to make and keep in a safe place an efs backup - nadroid backup - titanium backup , in case you ever need to restore them.
2. Use Full Wipe to flash Omega v45 !!!
3. Not all Themes - kernels are compatible with Samsungs leaked 4.2.2 android based rom
4. To activate Developer options at Settings, go to Settings > About Device and press 7 times on Built number - Omega v45
Donation:
If you like Omega v45 and Omega Files and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: Chris_84, Bl4ck3vil, Kumo und 5 andere
Hallo! Hab ja die 4.2.2 stock drauf... meine frage ist kann ich die Omega rom einfach im cwm flashen? Also die 4.2.2?
Hier klappte es ohne Probs. Ohne full wipe o.ä. einfach direkt flashen.
Gesendet vom Galaxy S3 mit Tapatalk 2
Mit odin oder normal cwm? Und wenn ich die von 4.1.2 wieder haben will was muss ich denn machen?
läuft alles (gps, wifi, datenverbindung?) wie isses mit batterydrain?
Funktionieren tut alles!
Akku ist schwer zu sagen bis jetzt, aber die Stock 4.2.2 hatte schon optimale Laufzeiten...
Reaktionen: Chris_84 und kolacell
Also so läuft alles ziemlich rund nur der Akku wird manchmal (bei bestimmten Aktionen) ziemlich warm
....von unterwegs mit SG lll
Moin
Bis jetzt läuft alles.....nur der RAM Verbrauch ist ziemlich hoch...ca.600mb
Mit 4.1.2 hatte ich ca.400mb....
Achja und bei der Pin Abfrage gibt es noch einen Grafikbug. Und ich kann das Landscape des Homscreens nicht mehr abschalten. Das nervt....
Wird bestimmt bald gefixt.
geht bei euch die allshare funktion ? also zb filme aufm dem TV "STREAMEN" ?
bei mir findet er keine Geräte mehr.
mit der 4.1.2 hat das problemlos gefunzt
wunderbar...ich habs geahnt...der müll kommt mir nicht in die tüte...da bleib ich bei der ultima v12, die ist stable! danke für die infos
Du muss die allshare deinstallieren und dann von Samsung store runterladen installieren. Keine ahnung warum aber hat bei mir auch nicht funktioniert ich habe es so gemacht und jetzt gehts
Also ich habe ja nur diese ALLSHARE CONTROLL App installiert gehabt - diese habe ich deinstalliert und neu installiert - beim start meckert diese aber ALLSHARE FRAMEWORK NOT INSTALLED
beim alten 4.1.2 konnte ich, wenn ich ein video abgespielt habe, oben links auf den share button klicken, und das video wurde direkt auf dem tv abgespielt...
da mich das 4.2.2 eh net wirklich vom hocker haut, werde ich wohl wieder erstmal auf die 43.3 zurück wechseln :)
Bin erstmal wieder zurück zur 43.3....:blink:
Da sind noch zu viele Kleinigkeiten die mich stören....allshare, Landscape,Speicher
Ich hoffe beim nächsten Update wird es besser
:thumbsup:
werde ich nun auch machen ;)
trotzdem danke für deine hilfe arnavutoglu
darkone500 schrieb:
Moin
Wegen dem grafikbug.einfach das xposed framework und nottached installieren.bei xda gibts den passenden thread.ist fuers s4 das meisre lauft aber auch beim s3.dann unter lockscreen hide emergency button und schon sieht alles so aus wies soll.Hat noch weitere nette optionen.
Edit:
Hier der link
http://forum.xda-developers.com/showthread.php?t=2289294
