[ROM][I9300][4.3|4.1.2][XXUGNA7|XXEMRG] *10.02.2014* Omega v56|v50.1[Themes]
  • 7.188 Antworten
Omega v44.4 - Freut euch drauf :scared:
Omega v44.4 Jelly Bean (19/04/2013):
Based on beta firmware XXUFMB3 Android 4.2.1 (Date: 19/02/2013)
New:
Omega Files app
Omega Theme for aroma installer by our artist anbech
Floating Omegadroids by NadMaj
CSC with more countries + HD Voice working on every carrier that supports hd voice updated by gnarg
Updated:
Flash Player v11.1.115.54
Gmail v4.3.1
Chrome v26.0.1410.58
Google+ v3.6.1.44747389
ZArchiver v0.6.5
Talkback v3.3.1
Multi Window Manager v1.3.7
Onadroid Backup v3.0.2
Google Search v2.4.10.626027
Flipboard v1.9.28
Dropbox v2.3.5
CPU Adjuster v3.0.7
Samsung Push Service
Hosts
All mods from previous Omega JB 4.2.1 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
(Quelle)
New version Omega v44.4 Jelly Bean 4.2.1:
New:
Omega Files app
Updated:
Gmail v4.3.1
ZArchiver v0.6.5
Talkback v3.3.1
Flipboard v1.9.28
Dropbox v2.3.5
CPU Adjuster v3.0.7
Hosts
Rom is No Full Wipe
Omega Files Jelly Bean:
Please read the following before flashing v44.4:
1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
2. Use No Full Wipe only from v44 + v44.1 + v44.2 +v44.3 - if you are coming from other roms or Omega versions you need Full Wipe
3. To gain root open SuperSU and update the binary if needed
4. Not all Themes - kernels are compatible with Samsungs leaked 4.2.1 android based rom
5. Please update Omega Files
6. Known bug: SPlaner FC when you press week and year and the side panel
7. To activate Developer options at Settings, go to Settings > About Device and press 7 times on Built number - Omega v44.2
8. Login to dropbox to get 50GB free space - cool
My Pledgie:
Please support me to get the new Samsung Galaxy S4,
this way I will support one more device with Omega roms
and I will not have to sell my other devices to get the new S4.
Donation:
If you like Omega v44.4 and you use it please consider a donation.
Enjoy the new Omega
Reaktionen: Chris_84 und Bl4ck3vil
was sind die aktuellen bugs von 44.4 ? kann man die schon im alltag usen ?
sent from my i9300.
Also die Bugs von der Android 4.2.1 Firmware sind geblieben, z.B. Lockscreen Datum, S Planner.
Allerdings ist es wie die vorherigen Versionen bereits auch alltagstauglich.
Gesendet vom Galaxy S3 mit Tapatalk 2
Kann man den Landschaftsmodus im TW Launcher irgendwie deaktivieren? Ich habe es schon in den Omega Settings versucht (mit der Option "Launcher Rotation") aber das funktioniert irgendwie nicht.
Habe gestern die v44.4 geflasht, und habe auch einen extremen Akkuverbrauch...
In BBS kann man leider nicht wirklich was rauslesen, mein S3 bleibt nur die ganze Zeit wach...
Sieht man z.B. auch in Einstellungen -> Akku, da steht Android OS ganz oben mit "Wach bleiben"
Weiß zufällig schon jemand durch was das verursacht wird?
Hallo. Wie kann ich bei der 44.1 einstellen, das das Hintergrundbild nicht mitscrollt. Gibt es einen mod dafür???
MasterElwood schrieb:
Sorry wenn ich so spät dran bin.
Bin auf 43.1 mit Stock Kernel und hab immer noch dir Gefahr vom Speicher Bug.
Was muss ich flashen damit dir Gefahr weg ist?
Thanx in A.
Keiner Einer :(
Geh mal in Omega Settings nach ganz unten und dort unter TW Launcher der erste Eintrag.Dort dürfte ein Haken gesetzt sein.
Hallo kurze frage gibt es bei der 44.4 den ink color effekt?
Weiß hier keiner etwas dazu ?
sent from my i9300.
Da gibt's nix zu wissen
Ich hab mit der Rom nen Verbrauch von unter 1% im Standby mit allem dies und das eingeschaltet ;)
Kann also an allem möglichen liegen, aber nicht an der Rom
bin wieder auf 4.1.2 durch Backup...
weiss jemand wie ich den 0 Ordner wegbekomme ? alle dateien von /sdcard/0/ auf /sdcard/ verschieben und dann löschen? Könnte das funktionieren ?
sent from my i9300.
sent from my i9300.
Haargenau. Sollte das Problem weiterhin bestehen was bei manchen der Fall war das sie einfach wieder nen 0 Ordner hatten musste formatieren.
ich hatte lange Omega auf meinem S3, mit der Zeit mehrten sich die Abstürze und Freez. Werkszustand herstellen und andere Custom Roms halfen alles nichts. Erst nach der Installation der letzten Samsung original FW funktioniert das Handy fehlerfrei.
Ich habe es jetzt gerootet.
Ich möchte jetzt CWM Recovery haben, so wie ich es von Omega gewöhnt bin, zusätzlich mit dem Siyah Kernel für Multiboot. Siyah konnte ich problemlos Flashen. Nur bei CWM Recovery finde ich nicht dies Version, welche in Omega enthalten ist.
Kann mir jemand einen Tipp geben?
In der Rom ist kein cwm enthalten...
@x1337
versuch mal : root explorer,data/media da sind auch die ordner drin und lassen sich löschen.habs eben bei mir gemacht,klappte 1a
habe da mal eine Frage, hab die 44.3 installiert, wenn ich das S3 mit dem PC verbinde und schau im explorer unter GT-I9300 im Phone dann habe ich an freien Speicher, im Phone von den 12 GB nur noch 4 GB frei und 8 GB belegt, es sind aber nur 4 Ordner in denen insgesammt knapp 15 MB an Daten vorhanden, wo ist der Rest verblieben?
Kann mir da einer weiter helfen!!!
Holger
ich habe 44.4 drauf und habe irgendwie keinen seriellen BT connect mehr zum Laptop. Hat hier jemand eine Idee? Habe schon oft neu gekoppelt usw. Aber nix zu machen.
weder inbound noch outbound
Holger
Habe mir mal das App DiskUsage installiert, dort zeigt mir die App unter Storage Card ein Ordner System data mit 7155 MiB das kann doch nicht sein, ich kann ihn auch nicht löschen.
Weiß einer was ich machen kann um diesen löschen zu können???
Pocketsoldier
Pocketsoldier
Pocketsoldier
SavanTorian
Esat-net
Esat-net
smalldookie
yarali
yarali
