[ROM][I9300][4.3|4.1.2][XXUGNA7|XXEMRG] *10.02.2014* Omega v56|v50.1[Themes]
  • 7.188 Antworten
Laut rom toolkit hab ich den dlih bootloader. Das ist doch ein alter oder nicht?
Chris_84 schrieb:
Hallo Leute! Kleines Update. Omega 38 ist im beta Status.
Komm ja mit dem Downloaden nicht nach.
Erst heute wieder mal reingeschaut und dann diese Nachricht :ohmy:
Dann wart ich doch gleich :thumbup::love::love:
New version Omega v38 Jelly Bean:
Based on firmware ZSEMA1 Android 4.1.2 (Date: 04/01/2013)
New:
Kernel Stock XXELLC
Updates:
hosts
All mods and updates from previous Omega JB 4.1.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files Jelly Bean:
Please read the following before flashing v38:
1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
2. If you want to flash theme or kernel, please make sure first they are compatible with Jelly Bean Omega
3. Please update Omega Files to v2.07 from Play Store - Omega Files is not yes updated, please do not use Omega v37 mods from Omega Files with Omega v37.1 and v38
4. If you flash with no full wipe then you should remove your google account - clear data from phone + contacts then reboot and add your google account again to fix the link to contacts problem in call log and sms.
5. MultiWindow Complete Control by LegendK95 included, if its not working go to settings > disable multiwindows > Reboot > enable multi windows and it will work.
6. I will soon make a post for Omega Settings with screenshots and proper credits.
7. About the new bootloader, read here.
8. The new mod "Lock Button @ status bar next to clock" locks the device when you press it, its not included in v38 but you can get it from here. And you can remove it by flashing this CWM zip
Donation:
If you like Omega v38 and you use it please consider a donation.
Enjoy the new Omega
Reaktionen: hanspampel, Kumo, Chris_84 und 6 andere
das mit dem bootloader verstehe ich nicht.. kommt es bei der version also auch zu dem schon bekannten problem oder nicht?
Das Rom läuft bei mir einwandfrei.....Danke an Indie :thumbup:
Es gibt zwar noch kein jkay dafür, aber ich werde sie gleich mal ausprobieren :D
Werde mir eine toggel2g Version kochen. Wenn die jemand haben möchte, bitte per pn, dann lade ich sie hoch.
Reaktionen: fliegenpups und pandabra
die raubkatze mods laufen noch nicht richtig?
Ja. Aber er arbeitet daran. War ziemlich beschäftigt in letzter zeit und hatte nicht die Möglichkeit daran zu arbeiten.
Reaktionen: der_sascha
Chris_84 schrieb:
Wenn du den alten bootloader brauchst. Ich hab ne flashbare zip Datei die du einfach über cwm installierst.
Wenn du den hast der vor der XXELLA war wäre nett wenn du den mir geben kannst.
so ganz sehe ich mit dem bootloader immernoch nicht durch.
kann mir das einer von euch vielleicht kurz mal erklären warum so viele auf den vorherigen zurück wollen und sind damit dann auch die mods von OMEGA 37 flashbar..bzw laufen diese dann wieder?
Schitte Omega v38 kann man nicht Downloaden.
Webhost ist ist die alte Version v37.1
Torrent kommt Error 404
das der crt effekt nur geht wenn wlan an ist hab ich jetzt ein paar mal gelesen...
Gibt es da nen fix???
Will den wieder haben... :sad::sad::sad:
Sonst läuft die Omega 37.1 bei mir sehr sehr gut. Akku ist auch wieder besser geworden. Mit der 36 gings bei mir ein bisschen mehr wie einen Tag. Jetzt bin ich wieder auf 2 Tage... :tongue::tongue::tongue:
Aprophis schrieb:
Tatsächlich, ist mir noch gar nicht aufgefallen.
Das ist aber bis jetzt das einzige Problem mit der 37.1 bei mir :thumbup:
http://db.tt/B40s9pJ8
Der ursprüngliche Beitrag von 11:48 Uhr wurde um 11:52 Uhr ergänzt:
Der Bootloader hat keinen Einfluss auf die Mods. Viele wollen zurück weil langsam klar wird das der Bootloader nichts fixt so wie am Anfang geglaubt wurde. Sondern das er scheinbar nur die Funktion hat zu kontrollieren ob du gerootet bist wenn du es zum richten einschickst.
Reaktionen: der_sascha und Klaus-DK
Also bei mir geht der crt effekt zwar auch ohne wlan. Allerdings nicht immer. Ca bei jedem 20-30ten mal gehts nicht. Kann das jemand bestätigen?
liegt das an der rom oder am kernel?
ich hab den yank kernel drauf. Mit dem stock kernel war es aber genau so.
Bin gerade auf der v37 mit Motomoto Theme. Kann ich die V38 einfach drüber flashen oder muss ich wipen?
Gibt es noch irgend einen Download Link für die V38 :confused2:
Pocketsoldier
Pocketsoldier
Pocketsoldier
SavanTorian
Esat-net
Esat-net
smalldookie
yarali
yarali
