[ROM][I9300][4.3|4.1.2][XXUGNA7|XXEMRG] *10.02.2014* Omega v56|v50.1[Themes]
  • 7.188 Antworten
New version Omega v37 Jelly Bean:
Based on Final firmware XXELLC Android 4.1.2 (Date: 22/12/2012)
Kernel Stock XXELLC
Modem XXELLA
New:
Multi csc PHEELL3 set to EUR - 128 csc (added 5 Russian)
Updates:
Dropbox v2.3
Flipboard v1.9.19
Google Services
AdFree v0.8.47
hosts
Mods:
Media Scanner Fix - credits to shoman94
Fixed:
Google+ FC when instant upload opens - by LegendK95 - fix posted here by Chris_84
Removed:
Lock on status bar next to clock - Can be added from Omega Files
All rotations enabled
Restored:
IME switcher on notification area
All mods and updates from previous Omega JB 4.1.2 versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files Jelly Bean:
Please read the following before flashing v37:
1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
2. If you want to flash theme or kernel, please make sure first they are compatible with Jelly Bean Omega
3. Please update Omega Files to v2.05 from Play Store - will be online soon.
4. If you flash with no full wipe then you should remove your google account then reboot and add your google account again to fix the link to contacts problem in call log and sms.
5. MultiWindow Complete Control by LegendK95 included, if its not working go to settings > disable multiwindows > Reboot > enable multi windows and it will work.
6. InkEffect at Lockscreen is not enabled by default, go to settings > Lock Screen > Lock Screen options and set it from Ink Effect menu
7. About the new bootloader, read here.
Donation:
If you like Omega v37 and you use it please consider a donation.
Enjoy the new Omega
Reaktionen: Android-FanX79, Nekromonga, Metalmaxx und 10 andere
Donate :thumbsup:
Prost Indie:thumbup:
Reaktionen: Chris_84
Reaktionen: Chris_84 und darkone500
New version Omega v37 Jelly Bean ....sie läuft wieder erste Sahne !
Reaktionen: Chris_84 und Bl4ck3vil
Nachdem ich mittlerweile über ein anderes Forum herausgefunden habe, dass die Umschaltung Wifi/mobiles Internet über den Kernel gesteuert wird, habe ich mir den Siyah geflasht. Seitdem klappt die Umschaltung wieder einwandfrei. Falls jemand das selbe Problem hat wie ich.
v37 läuft echt super!
Frage am Rande: Was mir fehlt, was ich mir Wünschen würde wäre noch ein Mod der mir beim laden des Akku einen Signalton gibt wenn der Ladevorgang abgeschlossen ist. Gibt es sowas?
Ja gibts. Einfach in der kitchen schauen. Indie hat fast alle systemtoene rausgenommen und muessen bei bedarf naxhgeflasht werden
Da sind nur 3 Stück drin und der Restore Plug in charger Sound gibt nur beim einstecken des Ladegeräts ein Ton.
Heute Vormittag habe ich die neue Version installiert. Läuft bisher recht gut.
Nur wie ich installieren wollte (Custom) ist mir der Bildschirm beim auswählen "eingefroren".
V37 läuft, bis jetzt alles super :) Good work!
Ohne full wipe
@rootboy
Ach so, das ist nur der plug in. Hmm dann weiss ich nicht. Hab die toene e immer draussen. Dachte da sei auch einer bei full charge.
@seini
Ja, das liegt an der aroma version. Ab und zu friert der ein . indie sollte mal das aroma updaten. Kann ich ihm bei gelegenheit mal sagen, ist ja keine grosse sache
jo, der aroma nervt schon... auch antippen der jeweiligen Auswahl ist oft Glücksache und muss mehrmals gemacht werden
Ist denn der Kontakte Bug in der 37 nun behoben,oder doch nicht?
Ich las da nebenan bei Xda was drüber.
Jap. Zumindest ist bei mir alles gut. Schon seit v36
Und wenn nicht,dann eben google abmelden und wieder anmelden. Dauert doch nur ne minute ;)
Also bei mir war er noch da.
Bei mir war er auch noch da...aber kein Problem
gesendet vom Galaxy S3 mit Omega V33.2
Ich hatte on seit v36 nicht mehr. Und wenn doch, ist kP oder? Schnell geloest, indem man google ab und wieder anmeldet
Richtig
Uploaded with ImageShack.us
hi habe folgendes problem alles funktioniert top nur die build nr. und die Basisband versionen unterscheiden sich habe schon mehrmals drübert geflasht aber sie ändert sich einfach nicht
Pocketsoldier
Pocketsoldier
Pocketsoldier
SavanTorian
Esat-net
Esat-net
smalldookie
yarali
yarali
