[ROM][I9300][4.3|4.1.2][XXUGNA7|XXEMRG] *10.02.2014* Omega v56|v50.1[Themes]
  • 7.188 Antworten
Ruggl schrieb:
Huhu Leute sagt mal funktioniert bei euch das Android-Hilfe app ? Bei mir kommt nur nen weisser Bildschirm mit dem Hinweis das keine Verbindung hergestellt werden kann und das ich mich an den Admin wenden soll
Hat nichts mit der Rom zu tun, ist ein Fehler von AH. Wird bald gefixt.
Reaktionen: alsdorfer und Ruggl
New version Omega v32.1 Jelly Bean:
Based on XXDLJ5 Android 4.1.1 (Date: 26/10/2012)
New:
Google apps from Android 4.2:
Included by default:
Playstore v3.9.17
Gmail v4.2
Can be install from Custom Install Option:
Camera and Gallery from Android 4.2
Keyboard Android with Gesture Typing from Android 4.2
Keyboard with Emoji Support from Android 4.2
Clock Application from Android 4.2
Added:
OnlineNandroidBackup v2.5.4 credits to H3R3T1C and ameer1234567890
Note II POPUP Browser by raubkatze
Updated:
SuperSU v0.98
Dropbox v2.2.1
hosts
Mods:
Email with Exchange Security Disabled
Task Manager Shortcut by cb56
Theme:
Accuweather Widget transparent by raubkatze
Removed to Bloateware and added to Custom Install:
Sansung Fonts: ChocoEUKor.apk - HelvNeueLT.apk - RoseEUKor.apk
Dialer Widget
Samsung Widget FavoriteApp
Simple Favorites Widget
SPlanner App Widget
Simple Alarm Clock
All mods and updates from previous Omega JB versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is No Full Wipe
Omega Files JB:
All files from v1.08 are compatible with Omega v32.1​
Omega Files Jelly Bean:
Please read the following before flashing v32:
1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
2. If you want to flash theme or kernel, please make sure first they are compatible with Jelly Bean Omega
3. Please update Omega Files to v1.08 from Play Store
4. MyFiles app is removed from Omega v32.1, get it from here and flash it via CWM Recovery
5. If you flash without wipe you need to clear Gmail and Google Play Store chache, else apps might not work.
Donation:
If you like Omega v32.1 please consider a donation to help me continue this project.
Enjoy the new Jelly Bean Omega
Reaktionen: Kumo, Klaus-DK, Nekromonga und 7 andere
seit der V32.1 ist mein eigene dateien weg! Hat noch jemand das problem???
steht genau über dir =)
Reaktionen: nene
Siehe Post über dir
Reaktionen: nene
Der PopUp Browser ist top!
Da wünscht man sich fast schon Multiview herbei^^
New version Omega v33 Jelly Bean:
Based on test firmware XXELK4 Android 4.1.2 (Date: 08/11/2012)
Kernel Stock XXELK4
Modem DDDLJ1
CSC: JKELK5
efs Backup (added the option to create efs backup during installation)
Omegadroid Walk Bootanimation by Jorq1H and anbech
CWM Manager v3.60 by Chainfire (not fully compatible)
Busybox v1.20.2
SuperSU
init.d support without the need of a kernel that supports init.d
Aroma installer - Installation is fully customizable by user and there is options to install everything and remove Bloatware - read here for more info
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Playstore v3.9.17
Gmail v4.2
Omegas addon applications:
Es File Explorer (with great Root Explorer)
Hide It Pro
Download All Files
ZArchiver
FastDormancy Toggle for I9300 by gokhanmoral
Flash player Support
Removed:
Bloatware
Boot sound
Charger Connection Sound
Shutdown Animation
Mods:
All supported languages enabled
All supported languages for Samsung Keyboard enabled
V6 SuperCharger credits to zeppelinrox
Tweaks so memory will never go below 200 mb
Disabled advertisements
Faster GPS lock
Modded YouTube by rolle (can download videos)
Join more unlimited contacts in the contact app
Tweaks:
build.prop tweaks
Stock Theme Changes:
Dithered Holo Background
Please read the following before flashing v33:
2. If you want to flash theme or kernel, please make sure first they are compatible with Jelly Bean Omega 4.1.2
3. Omega Files is not compatible with Omega v33 - use it only with v32.1
4. Many mods are not included - I wanted to share with you v33 and our progress so far and I will make the rest of the mods ASAP.
5. First screen is on Israel language, I will change this to English in the next update.
6. Flash v33 with Full Wipe
Donation:
If you like Omega v33 please consider a donation to help me continue this project.
Reaktionen: Nekromonga, d407974 und Kumo
oh manno, :) gerade die 32.1 installiert und schon kommt die 33. geht ja rasend los hier.
deine arbeit in allen ehren indie. machst du auch mal ne pause?
Wie immer wurde hier klasse arbeit geliefert. noch einmal vielen vielen dank für deine unermüdliche arbeit
Jaaaa endlich kommt Multiwindow und noch andere Features.:love::thumbsup:
Multi View (Multi Windows Multitasking, same as in Note II)
Page Buddy
Notification Panel (Notification Panel can now be customized)
Smart Rotation (Screen Display adjusts to your angle of sightings)
Continues Input in Samsung Keyboard (Like Swipe or Android 4.2 Keyboard)
Paper Artist App (Same as in Note II)
New Gallery App (Same as in Note II – This is AWESOME)
Reaktionen: Kumo
Omega 33 installiert und es läuft gefühlt noch smoother.Multi Windows ist einfach genial.Und das beste es läuft auch mit anderen Launchern.:thumbsup::thumbsup::thumbsup:
Muss man bei jeder neuen Version eigentlich full wipen oder kann man die nicht einfach drüberbügeln ?
Jedesmal den App-Drawer neu einrichten mit Ordern und so ist weng doof.
Backup machen von sowas geht ja anscheinend noch nicht.
neu drueberbuegeln reicht aus
na, bei der V33 würd ichs machen!
neu drueber buegeln reicht aus
Reaktionen: eagle*23*
Also ich mach eigentlich immer nur ein full wipe wenn ich auf eine andere Rom wechsle, oder wenn es größere FW sprünge sind. Sollten fehler auf Tretten kannn man immer noch ein full wipe hinterher schieben
Greetz
Moin NOBODY auch schon wieder wach und in fremden Foren als das eigene unterwegs :)
6. Flash v33 with Full Wipe..... deswegen meine Frage
Habe von v13 auf v31 ohne Full wipe geflasht und jetzt von v31 auf v33 auch.
Bis jetzt hatte ich nie Probleme ohne Full Wipe.
Früher unter ICS gabs eher mal ein Problem wenn man kein Ful Wipe gemacht hat.
ansonsten, fröhliches Flashen :)
War Blödsinn! Weil ich Blind war! Sorry!!!!!!!!!
Du bist ja ein ganz schneller:lol:
Na ja, kann ja mal passieren. Jedoch komme ich generell nicht ganz so schnell und du?
Pocketsoldier
Pocketsoldier
Pocketsoldier
SavanTorian
Esat-net
Esat-net
smalldookie
yarali
yarali
