[ROM][I9300][4.1.2][XXELKC] *10.12.2012* TurkbeyROM V1+V1.1 [Aroma]
  • 1.506 Antworten
TurkbeyRom XXDLI8 JB 4.1.1 V9_RC8
Sooonnn!!!! :D:D:D
AP : XXDLI8
CP : XXDLI8
CSC : OXADLI8
Multi CSC
Added 94 csc
Default Csc - TUR
You can change in settings (Wipe your data)
Added siyah kernel 1.6beta13 in aroma
Added wanam repacked kernel in aroma (insecure) (Thanks Wanam)
Added yandex disk and mail in aroma
Added 15 Togles Bar Mod ( Thanks Wanam )
Added Galaxy Note 2 gallery in aroma
Fix gray statusbar to black
Added 15 tooggles turkbey theme in aroma
Added center clock mod in aroma
Added ARM TrustZone system security
Added modem XXDLI8 in aroma
New Systemui
added lockscreen and jobmanager icons in systemui
Added hardware information in setting
Big weather icon in lockscreen
Transparent weather widget
4 way reboot
init.d support
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Hide SMS from Call Log
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Battery % mod
Disabled scrolling cache
Enabled call recording
Removed keyguard ant other security policies from email app
Hacked Email
Added Hosts
Tweaks for sqlite optimication
Zipalign apps at boot
Tweaks for smoother scrolling
Tweaks for wireless connectivity
build.prop tweaks
more free ram and stablle
Many tweaks for better life
Added home lag fix
*** Last Updates ***
Update facebook
update twitter
Update apex launcher
update google drive
update whatsapps
update google currents
update opensignalmaps
Added cosmic flow live wallpaper
Added some scripts
Changed some scripts
Modded Phone
-Disabled increasing ringtone
-Patch makes it completely transparent band/banner in the dialer during call
-Patch disables the service messages notification in dialer, such as: "Conditional call forwarding active", "Call forwarded", "Call on hold", "Deflected call" and etc.
Modded Sms
Increase the maximum size of send messages with 300 KB to 1 MB
Modded Tw Launcher in Aroma
Tw Stock Orj
Tw 4X5 scr off
Tw 4x5 scr on
Tw 5X5 scr off
Tw 5x5 scr on
Tw 5x6 scr off
Tw 5x6 scr on
Changed setupwizard
Added turkbey icons for apps
Added transparent weather widget and changed weather icons (thanks poppuri)
Added swype and aops keyboard in aroma​
Reaktionen: sventehf, androiduser44, kunodownhill und 4 andere
Wann ist die online ???
Dann kann auch dieses Rom mal wieder probieren
Alles klar, gleich mal laden, um die Zeit bekommt man wenigstens gute Downloads gebacken.... :thumbsup:
Japp, 1:30min und fertig ;)
Wie schaut des eigentlich aus, sollte man auch beim S3 einen Fullwipe machen ?
@kskgepard
von welcher rom kommst du?
wenn du nicht schon die türkbey hast, dann ist ein full wipe Pflicht, aber mach vorher auf jeden Fall ein nandroid backup und sicher den efs ordner mit ktool ausm play store
androiduser44 schrieb:
@kskgepard
Komme von der Turkbey RC7.
Hab wie auch beim S2 schon, zur Vorsicht ( war ja damals auch immer besser ;) ) einen Fullwipe gemacht.
OT: Muss schon Sagen, des Flashen auf dem S3 ist, wie ich finde schon Klasse mit dem Touch und der ganzen Bedienung :D
wenn du von der rc7 kommst, dann reicht ein wipe des cache und des dalvik cache
ps beim s2 gab es auch das touchrecovery und das von fluxi war das beste, da es sehr ausgeklügelt war
wird zeit das fluxi sich ein s3 zulegt :D
vom fluxi kernel muss ich gar nicht erst reden, der war beim s2 mmn die referenz
Hab sie drauf und sie läuft bisher absolut super.
Bezüglich Touch Recovery bin ich ja noch verwöhnt vom Galaxy Nexus
Korrektur: Hab gerade festgestellt, dass nach dem Flashen sämtliche Rootrechte weg sind. Wie krieg ich die jetzt wieder?
Edit: Hab die Rom noch mal drüber geflasht und nun hab ich wieder Root. Wäre trotzdem dankbar, wenn mir jemand erklären kann, wie bei der Installation eines Custom Roms auf einem gerooteten Handy plötzlich die Rootrechte weg sein können.
Und noch eine Frage: Gibt es für die Rom einen Statusbar Mod? Ich finde die Aufmachung der Rom echt klasse, aber die Statusbar oben ist mir zu kitschig
einfach supersu aus dem store installieren
Hab Sie jetzt auch drauf und muss sagen rennt wie immer super!! Cool finde ich die neue Gallery vom Note2!
Alles in allem eine klasse Rom!
Wie immer sehr gute Arbeit!!
Apo
Welchen Kernel habt ihr von den dreien genommen?
Hallo!
Ich habe die Stock Rom drauf und CWM (also root) einfach per cwm flashen?
Ich hab alle drei ausprobiert und finde den Siyah hier am besten
Ja, einfach via CWM flashen.
Reaktionen: SoulReaver24
@commat
hat es geklappt mit den rootrechten?
Das mit Supersu nachinstallieren hatte ich probiert, hat nicht funktioniert.
Hab dann einfach die Rom noch einmal drüber geflasht und nun sind die Rootrechte wieder da. Weiß der Geier, warum die auf einmal weg waren.
bei mir sind die auch weg :D
Eine Frage noch:
ROM per CWM flashen und dann den Siyah-s3-v1.6b12 Kernel per Odin drauf?
@soulreaver
lad dir doch den siyah auch als cwm Version runter dann kannst du den auch per cwm flashen
