[ROM][I9300][4.1.2 EMF1 & 4.2.2 UFME7][AROMA] *26.06.2013* Android Revolution V28/32
  • 329 Antworten
hanspampel
hanspampel
Ehrenmitglied
9.864
Gibt doch tatsächlich nun ein ROM von Mike1986. Bekanntgeworden ist er ja durch seine Android Revolution ROMs. War auch damals mein erste Custom ROM für mein damaliges Desire HD. Nun gibt es es auch fürs S3.
Proudly presenting you...
Users experience with Android Revolution HD
"My phone is now perfectly smooth, fast, stable. I do not expect much more from my phone!"
DarkAdrien
"This release is amazing! ROM feels super fast! Great job Mike & the team! (...) Never noticed any lag. 1 word: brilliant."
Selec1
"Feels a lot smoother in use - scrolling, swiping between sense screens. Much nicer feel. This is a real good one, Mike. Many thanks
dsm52
>>> Very fast | rock stable | stock look | great support <<<
System details:
  • Android 4.2.2 (Jelly Bean) - latest unofficial Samsung I9300XXUFME7 firmware
  • Android 4.1.2 (Jelly Bean) - latest official Samsung 9300XXEMF1 firmware
  • This is improved version of stock ROM - no visual changes!
  • Very fast, clean & stable!
  • Full Samsung TouchWiz Interface
  • Multi-language (WWE)
  • For Samsung Galaxy S3 (I9300)
  • Thanks to Samsung for the base firmware
  • Video Review by MohammedAzi
Included kernel details:
  • Stock kernel (the most stable)
ROM details:
  • Removed software (CPU) rendering - full Exynos 4 Quad (GPU) rendering
  • Fully optimized and tweaked
  • Root access
  • Unsecured boot.img
  • Newest BusyBox
  • RAM optimizations
  • System signatures check enabled for system security and safety
  • Improved virtual memory management
  • Speed optimizations
  • Enabled GPU UI rendering
  • Data, cache and system partitions mounting tweaks
  • Bloatware applications removed
  • All /system applications updated to latest available
  • All /data applications updated to latest available
  • Improved CPU governors performance
  • Most optimal system scheduler
  • Disabled kernel debugging for better performance
  • Zipaligned (Improved RAM management)
  • Zipalign on boot (for user applications on data partition)
  • Fully de-odexed
  • init.d scripts (BusyBox run-parts) support
  • Auto init.d permissions set on boot
  • sysro/sysrw commands support
  • Excellent battery life!
  • Improved EXT4 performance
  • OpenVPN support
  • Most up-to-date system files permissions
  • Adobe Flash Player support
  • Support almost 24h a day
  • ...and many more!
You need:
  • Samsung Galaxy S3 (I9300)
  • Custom recovery
How to flash:
  • Download ROM and place it on your virtual SD card
  • Boot your phone in recovery mode (vol down + power)
  • In main menu, select "install zip from sdcard"
  • Select "choose zip from sdcard" and browse to the location of Android Revolution ROM
  • You can use data wiping option in AROMA (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
  • After flashing process is complete, reboot the device
» Performance Tweaks, % battery mods, & other add-ons:
» You can easily customize my ROM and make it LITE by removing some components with ROM Cleaner:
» If you want to flash different custom kernel, you can do it easily using Kernel Update Utility by jkoljo:
Android Revolution HD 28.0
Android Revolution HD 32.0
--- release date: 26 June 2013 ---
  • Based on latest official Samsung 9300XXEMF1 firmware (28.0)
  • Based on latest unofficial Samsung I9300XXUFME7 firmware (32.0)
  • Re-designed and updated AROMA installer
  • Zipaligned using SDK r22
  • Other minor changes and fixes
  • Included and updated components:
--- Data partition ---
Adobe Flash Player 11.1.115.58 (For Android 4.0+)
Adobe Flash Player 11.1.111.50 (For Android 2.0+)
Adobe Reader 10.6.0
Dropbox 2.3.8
ES File Explorer 3.0.4
Facebook 3.3
Maxthon 4.0.4.1000
Twitter 4.1.1
--- System partition ---
Google Play 4.1.10
Gmail 4.5 (For Android 4.1+)
Gmail 2.3.6 (For Android 2.3.5)
GmsCore 3.1.36
SuperUser 1.0.1.8
SuperSU 1.30 (Only Samsung devices)
--- Aroma installer ---
Google Hangouts 1.0.2.695251
Google Maps 6.14.4
Google Plus 4.0.1.47928040
Google Street 1.8.1.1
Google YouTube 4.5.17
Google TalkBack 3.3.1
Google Chrome 27.0.1453.90
Google Music 5.0.1052J.707098
Google Keep 1.0.79
Google Search 2.5.8.675703 (For Android 4.1+)
Google Search 1.4.1.338691 (For Android 4.0.3)
Google Search 1.1.2.64376 (For Android 2.3.5)
- If your current firmware version doesn't match ROM firmware version, wiping data inside AROMA is highly recommended!
Android Revolution HD 28.0 [4.1.2]
--- MD5 Checksum: 98E048563FBDCC4D3C5090CD358A1160 ---
Android Revolution HD 32.0 [4.2.2]
--- MD5 Checksum: AA5C47338F5CD992A50C924D74E4FFE0 ---
Alternative Mirror Downloads
Für alle die die Probs mit dem Super Wipe haben, machen einfach nen ganz normalen Fullwipe wie bei jedem anderen ROM auch, Wipe Data/Factory Reset, Wipe Cache, Wipe Dalvik Cache, Format System(dabei sicher sein das ein ROM auf dem Handy ist)
Super Wipe
--- This script will erase and format your data (including Internal SD Card), system and cache partition ---
--- Your External SD Card will remain untouched FAT32 and it's recommended to leave it like that ---
--- Your Internal SD Card (/data/media) will be wiped ---
--- You need to copy ROM .zip file to your External SD Card before using Super Wipe ---
Gibts nicht mehr optional. Ist in den AROMA mit implementiert!!
Quelle
Der ursprüngliche Beitrag von 15:56 Uhr wurde um 15:59 Uhr ergänzt:
cf5ffjv
Performance Tweaks for Android Revolution HD
  • data_writeback journalism for /system, /data and /cache partitions.
This mod will turn ON data_writeback for all 3 partitions - system, data and cache. This will drastically improve I/O performance (mostly on write operations) at the expense of file system integrity in certain situations, like unexpected system shutdown. The risk is not extreme, but still bigger then regular. Use this to improve your system performance, but you flash it at your own risk!
Download here:
Android Revolution HD EXT4 Tweaks v.0.1
  • Force GPU rendering on 2D operations.
This mod is working similar to "Render GUI with GPU" option in Development Settings. Flashing this will force whole system to use GPU rendering (instead of CPU) for all kind of 2D/3D operations. This might improve 2D operations performance, but keep in mind that some apps are not working correctly with GPU rendering. After using this mod you no longer need to tick "Render GUI with GPU" in settings. Even if un-ticked it will be still working. Flash it at your own risk!
Download here:
Android Revolution HD GPU Rendering v.0.1
Edit: Auf neue Version 28/32 geupdatet
Reaktionen: wuerfel, Arkido, FliegerNRW und 3 andere
WOW:scared: Ich kenne seine Roms noch von Desire HD Zeiten. Seine Rom war wirklich klasse!!!!
Ist den dieses Super Wipe wirklich notwendig oder kann ich es so macehn wie immer ohne dieses Script?
mfg
1.1.0 funzt aber nicht. Gibt immer noch FCs, zumindest was den Messenger angeht. Ich würde eher auf die 2.0 warten.
Der ursprüngliche Beitrag von 18:09 Uhr wurde um 18:20 Uhr ergänzt:
V2.0 kommt später. Wohl späten Abend oder heut Nacht.
Der ursprüngliche Beitrag von 18:20 Uhr wurde um 19:28 Uhr ergänzt:
Mike ist V2.0 am uppen. Kann etwas dauern. Macht schonmal nen Backup der Apps mit TB. Gibt wieder nen Fullwipe.
Android Revolution HD 2.0.0
--- release date: 27 July 2012 ---
  • Re-based using latest I9300XXLG6 firmware
  • Fixed FC in messages app
- Super Wipe is highly recommended!
Hab 2.1 seit 30min drauf, schauen wir mal. Gut das super wipe meinen titanium ordner gekillt hat, liegt ab jetzt auf der externen sd:rolleyes2:
Downloade sie mir gerade ! Meint ihr man sollte sich die EXT4 Tweaksit drauf machen ?
@Maestro2k5
THEME ICS BLUE MOD V3
funktioniert alles ausser die Akku anzeige
bei mir (und wie vielen anderen) bleibt hängen
hatte 85% angezeigt obwohl das handy auf 63% war
warte auf update
Reaktionen: boeck9999
Alles klar danke :)
Reaktionen: hasbai
placebo-rom
Ich finde es sehr schön, dass es ARHD nun auch fürs S3 gibt.
Habe seit Samstag mein S3 und hatte vorher ein HTC Sensation XE, auf den ich ARHD laufen hatte.
Habe es gestern Abend mal installiert und muss bis jetzt feststellen, dass mein Akku sehr schnell leer geht!
Lade es gerade mal voll und will dann einen Wipe machen.
Bis jetzt überlebte der Akku gerade mal 12h, obwohl das S3 mind. 6h im Flugmodus war.
Ich habe bis jetzt noch keine Batterie Anzeige in Prozent gesehen, habt ihr da nen Tipp? Zumindest gehe ich auf click hier und es wird nichts geladen.
Was ich auch schade finde, dass ich nicht soviel Platz auf den Homescreens habe wie z.B. unter Omega.
Aber Mike hat auch erst gerade mit der ROM begonnen, lassen wir ihn noch etwas experimentieren!
Ich freu mich schon auf weitere Updates!
Gruß Stiegl
Naja das ist "pures" Stock. Da gibts keinen 5x4 oder 6x5 Launcher. Deswegen haste weniger Platz auf dem Homescreen. Prozentanzeige müsste aber gehen. Kann man in den Einstellungen-->Battery oder so einstellen. Habs nicht mehr aufm Schirm.
Zum Akkuverbrauch kann ich nix sagen, habs nicht drauf. Aber mehr wie 12Std. solls schon halten. Kommt natürlich drauf an was du damit machst. Wenn du 5Std. davon im Netz gesurft bist kann das hinkommen. Ansonsten mal nen anderen Kernel flashen.
Hey, danke für deine Antwort!
Dann muss ich mal gucken welchen Launcher die bei Omega verwenden.
Stimmt, das mit der Prozentangabe hab ich mal gesehen, hab es jetzt eingestellt. Prima Sache!
Der Akku hält jetzt schon besser, nach über 2,5h rund 8%, das geht in Ordnung.
Denke das mit dem Akku wird sich noch einpendeln.
Gestern hatte der Akku aber nach 8h im Flugmodus schon über 10% verloren.
Nach dem Battery Wipe scheint es besser geworden zu sein.
Mit Kerneln kenne ich mich bei S3 noch gar nicht aus. Werde ich mich ggfs. mal einlesen. Kenne nur den Sebastian und den Faux für das HTC Sensation.
Aber wenn das so wird wie beim Sensation, dann werden die Kernel auch in der ARHD Rom sein und man kann beim flashen wählen, ob man den Stock oder einen anderen haben möchte.
Bin auf jeden Fall gespannt was Mike noch so alles schönes bringen wird!
Ich hätte mir gestern nur mal richtig angucken sollen was der Super Wipe macht. Da steht bei, dass es die interne Karte löscht. Hab ich nicht gelesen, zum Glück hab ich das CWM Backup auf die externe SD gemacht. Titanium hatte ich natürlich alles intern. Aber keine Daten sind mir verloren gegangen! Puh! ^^
gruß Stiegl
Neue Version ist draußen :) 2.1.1
Reaktionen: hanspampel
Danke, habs geändert.
Hi Leute.
Zur kurzen Erklärung:
Ich hab mein Handy gerootet laut "Android-Hilfe" Anleitung mit Hilfe Odin.
Ein Backup habe ich jetzt erstellt und bin jetzt auf der Suche nach schönes Rom´s.
Bzw möchte ich einfach mal welche ausprobieren um zu schauen welche mich persönlich am Besten ansprechen.
Daher bin ich jetzt hier gelandet.
Bei "Android Revolution HD - Rom"
Jetzt die peinliche Frage.
Wo ist der Link zum runterladen? Ich finde den nicht. haha. Sry dafür.
Danke im vorraus :)
Das muss dir nicht peinlich sein! :tongue:
Ich hatte das gleiche Problem, Chrome zeigte mir das nicht immer an, also hab ich die Seite einfach mal mit dem Internet Explorer geöffnet und schon hatte ich die Links!
Ab und an waren die Links auch im Chrome zu finden! Keine Ahnung was das ist!
Reaktionen: Naderik
Im ersten Post unter Downloads(ganz groß)-->click here;)
Reaktionen: Naderik
