[ROM][I9300] *05.02.2013* MS Team HD9.0.1 Stable|Eye Catching|Aroma|Online kitchen
  • 1.135 Antworten
Slayer77
Slayer77
Dauer-User
617
Diese geniale Rom hab ich hier leider noch nicht gefunden und ich finde sie gehört definitiv auch hier rein.Ich habe schon viele Roms getestet aber diese gehört ganz nach oben.
MS Team is an experienced cooking team who cooked roms for SAMSUNG OMNIA II in the recent two years.You can take look at them here
And now our team is cooking their first ROM for SAMSUNG GَALAXY S3
MS Team theme:
This theme is not originally created by MS team.Files are gathered from various themes such as JB Domination , Alexander , raubkatze's mods and etc ... .
So all credits about this theme go to them.
Jelly Bean Domination theme:
Designed by Vertumus.
The true AOSP style
For more information you can refer to the original thread >here<
Stock theme:
Original Galaxy S3 Stock theme made by Samsung .
  • Rooted
  • Deodexed
  • Zipaligned
  • Busybox
  • Sqlite3
  • init.d scripts
  • Nano text editor
  • sysro/sysrw support
  • Open VPN Support
  • Speed Optimizations
  • I/O Performance Tweak
  • EXT4 tweak
  • Build.prop tweak
  • Memory tweak
  • CPU rendering tweak
  • 2d/3d graphics tweak
  • Ad block
  • Kernel error checking disabled
  • Debug performance tuned
  • video accelerate tweaked
  • Good Battery life
  • RAM optimizations
  • Aroma installer
  • Customizable installation
  • EFS Backup
  • system partitions mounting tweaked
  • No SMS in call log
  • Optional Extra apps
  • Optional bloatware apps
  • Stock / Siyah Kernel (you can choose what to install)
  • Different themes (you can choose what to install)
  • Different launchers (you can choose what to install)
  • Different MMS skins (you can choose what to install)
  • Different dialer skins (you can choose what to install)
  • Latest SAMSUNG APKs
  • etc
November 20, 2012 : 4.1.2
  • Rebased on XXELK4
  • MultiWindow feature with all apps supporting ( Thanks to bala_gamer )
  • Black glass MW theme by whiskeybro
  • MS Team balckbean theme by alvin551
  • Ac!d Audio Engine 5.0
  • Some options and mods removed due to incompatibility with 4.1.2 ( Will be added later to the kitchen )
  • Perseus kernel added to the AROMA
  • New Siyah kernel added to the AROMA
  • Android 4.2 camera added to the AROMA)
  • JB domination theme removed temporarily ( until vertumus makes it for 4.1.2 )
  • Some changes in SystemUI
  • Minor bugs fixed
xda link für den download und weitere Infos:
ACHTUNG!!! Im Aroma Intallationsverzeichnis DOWNLOADS aktivieren!! Bei nicht aktivierung kann es zu gapps Problemen kommen.
[ROM]Nov 20 |JellyBean|☆☆☆MS Team HD 6.0☆☆☆|Stable |Eye Catching|Aroma|Online kitchen - xda-developers
Reaktionen: T2X, zodiac80, m4dd0gg und 11 andere
Die neue Version(4.0)ist online und läuft 1A!!Nach wie vor die beste Rom die ich bis jetzt getestet habe und der Akku hält ausergewönlich lang.
Reaktionen: Carew und tectas
Hi, muss jetzt hier auch mal meinen Senf dazugeben und hierfür eine Lanze brechen. :rolleyes2:
Habe die Rom auch lange "ignoriert/übersehen" fand aber auch zu dieser Rom nur sehr wenige Infos.
War die ganze Zeit auf Dragon oder Turkbey.
Jetzt mit Dualboot, hab ich nach ner 2 ten Rom gesucht.
Alles mögliche, von slim über medium, full oder pure, durchgesucht und geflasht, war nie das Richtige dabei - diese war wirklich die letzte Sammy Rom, die ich nicht nicht probiert hatte (ausser den Neuen von Gestern, die gerade auf XDA noch erschienen sind).
Heute auf gut Glück mal diese ausprobiert, und ich muss sagen, wow, sehr schön gethemed (MS Theme), sehr guter Aromainstaller und ne Kitchen, die sehr regelmässig geupdated wird, wobei dabei auch sehr auf Userwünsche eingegangen wird.
Bisschen zum Aroma:
1. Man kann zwischen Stock, Vertumus oder MS Theme (ein Mix aus mehreren Themes) wählen, wobei letztere sehr an Original JB angelehnt sind.
2. Viele Sachen sind abwählbar, Apps (ist ja normal) aber auch direkt Widgets (finde ich sehr praktisch) und Transparente Widgets sind ab-/wählbar.
3. Läuft einwandfrei durch, ohne Hänger, ist ja gerade auch nicht mehr selbstverständlich.
Leider ist sie auch bei XDA noch recht unbekannt, aber so langsam, mit der Version 4, gehts da auch los. Immer mehr Inhalt in der kitchen verfügbar, und wirklich guter Support.
Hoffe ich habe hiermit ein bisschen Interesse geweckt. Leute probierts mal aus, habt nichts zu verlieren - ich finde die Rom echt super gelungen.:thumbup:
Happy Flashing
Reaktionen: Mitch Bue, Dalump, tectas und 4 andere
Hört sich alles sehr gut an. :thumbup: Das gute Stück werde ich bestimmt mal testen.
Wirst es nicht bereuen :thumbsup:
Hab sie auch erst einen Tag drauf, bis jetzt schaut die Akkulaufzeit aber sehr gut aus, hab sie mit Siyah Rc1 laufen, leicht übertaktet und undervolted.
Sehr flüssig, keine FC bisher, Spiele, Internet, alles luppt.
Werde mal ein paar Ladezyklen abwarten und dann nochmal berichten.
Endlich habe ich mal ne Rom gefunden, bei der ich nicht nach nem halben Tag das verlangen habe, sie wieder zu tauschen oder was neues auszuprobieren.
(Das erste Mal, seit Turkbey - Gott sei Dank gibts Dualboot) :D
Reaktionen: tectas
Meine Herren, richtig schön schnell das Teil. Optisch auch ein Genuss. Alles läuft wie es sein soll. Fehlerfrei bis jetzt. Wenn jetzt noch der Akkuverbrauch den Erwartungen entspricht...
Also ich bin auch richtig zufrieden..
Läuft bei mir nur im Energiesparmodus und trotzdem ohne lange Wartezeiten..
Nur eine Sache stört gewaltig.. Bei jedem Neustart steht da: Anwendungen werden aktualisiert..
Das sorgt leider dafür das meine Speicher Orte für Internet und Kamera verändert werden..
Weiß jemand welche App ich dazu deaktivieren müsste?
Komisch, dass mit den Aktualisierungen hab ich nicht, nur wenn ich vorher was geflasht hab, is aber klar, dass es sich dann aktualisiert.
Hast du vorher fullwipe gemacht? Systemapps von ner anderen Version mit Titanium wiederhergestellt?
Wenn nicht, nochmal mit Fullwipe installieren, und neu einrichten. Ansonsten würde ich es mal mit Wipe Cache und Dalvik und fix perfmissions probieren.
Sorry, leider kann ich nicht weiterhelfen, da es bei mir nicht vorkommt.
Reaktionen: tectas und dermarco255
Ist ja erstmal gut zu wissen das es nicht normal ist..:rolleyes2:
Dann kann ich gleich wohl oder übel nochmal loslegen..
Ich danke euch erstmal..
So, dann hier mal ein kleines Update zum Akkuverbrauch - ist schwieriger als gedacht ... ich krieg den Akku einfach nicht leer :razz:
Normalerweise beurteile ich die Akkulaufzeit erst nach 2 - 3 Ladezyklen (von 100% auf ca. 20%) in denen ich auch nichts flashe, aber hier muss ich einfach mal ein vorläufiges Ergebnis posten.
Meine Einstellungen:
- Nachts immer Flugmodus an, tagsüber wechsel Wifi, Data oder off
- Sync manuell
- Screen autobrightness
- nichts übertaktet
Siyah rc1 mit droiphile script: (batterie 100 - 50%) UV - 100
batteryprofile und EvenMoreBatteryTweaksGovernor zu finden hier [KERNEL][JellyBean][DB] SiyahKernel S3 v1.7rc1 - xda-developers (hoffe ich darf das hier posten)
Ergebnis: super,
Rom geflasht und gleich geladen.
Danach noch relativ viel (über die kitchen) nachgeflasht, ca. 10 flashes
nach 1t09h noch 50% übrig,
- 2 h 37 min Screen on,
- bisschen telefoniert,
- tapatalk, in den Einstellungen rungespielt, Benchmark usw.
Anmerkung:
Hätte damit sicher 5h screen on erreicht, bei 2t Standby, aber:
Der Flugzeugmodus hat mich noch nicht restlos überzeugt, immer mal wieder kurz aufgewacht, trotzdem in 8 h nur 2% verloren
Deshalb:
Galaxsih erst 1.2b4 30min später 1.2 stable (schlechtes Timing) nicht UV
- noch ein paar Benchmarks
- Screen ca. 38 min
- bisschen Internet, wollte ihn aber erstmal setzen lassen
(Flugzeugmodus; in 8h 0% verloren, das erste mal, dass ich früh aufgewacht bin und BatteryMonitorWidget grün auf 0.0% war, GAR KEIN aufwachen - perfekt)
Insgesamt:
1t17h noch 31 % übrig
3h15 screen on
Immermal Wifi oder Data (sehr wenig) an
Standby 1t14h
Wer jetzt sagt, du hast es ja gar nicht benutzt, jaein, stimmt nicht ganz.
Es ist mein normales Verhalten, kein auto sync, Wlan nur wenn ichs brauch, allerdings spiele ich sonst mehr =)
Mehr als 3h Screen on, ist nicht nichts, aber ich habe es bewusst auch mal zur Seite gelegt und nichts gemacht, da ich wissen wollte, wie der Standby - Verbrauch ist.
schaut euch einfach die Screenshots an, diese sprechen für sich (hoffe habe das richtig gemacht, mein erstes Mal Screenshots hochgeladen)
Ich persönlich freue mich auf die neue Version :tongue:
@ dermarco255
hast du es hingekriegt?
Reaktionen: tectas
Hallo komme von der Omega 27.2 und habe diese hier jetzt mal geflasht.
Dir Rom läuft sehr schön aber der Akkuverbrauch kommt mir mit dem rc1 ganz schön hoch vor habe an den Einstellungen nichts verändert.
Werde jetzt mal voll Aufladen und dann mal Testen
Hoi
In welches Datei kann ich denn die Größe der Betreiberschrift verändern? Wenn ich die Notification nach unten ziehe, steht der Text ein wenig in den Grau/Blauen Balken rein. Es ist kein Fehler, nur eine kleine Unschönheit, die mich persönlich ein wenig stört :)
Ansonsten TOP Rom... :thumbup:
@HUMBUG,
puh, da bin ich überfragt. Mein Lycamobile Logo passt wunderbar, hast du etwas an der font oder den dpi geändert?
Ich schätze mal, du musst in der in der framework oder Systemui suchen, bin da aber wirklich nicht sicher.
Diese müsstest du dann entpacken, und das entsprechende png ändern.
Das geht leider über meine Kenntnisse hinaus, für ein bisschen themen reichts, aber hier muss ein Profi her...
Also bitte Profis, meldet euch :tongue:
Wenn du einen Screenshot hast, frag doch mal auf XDA nach. Die Devs da sind super schnell und hilfsbereit.
Nein, hab das Problem noch nicht gelöst, hab die Rom zwar neu geflasht aber noch kein Full Wipe gemacht..
Mich hat es erstmal beruhigt das es nicht bei jedem der Fall ist.. Grins..
Und das meinte er sicher mit dem unterbrochen Betreiber Logo (ist mir vorher nicht aufgefallen!
die ROM ist echt super. Aber gibt es die Möglichkeit die Reihenfolge der "Schalter" für WiFi, Ton, etc. im Notification-Fenster zu änder? Finde es relativ unpraktisch, dass gerade die Einstellung für Ton soweit rechts ist und ich hin scrollen muss.
Danke schonmal vorab,
LaUltimaKA
Ja, die App heißt QUICK PANEL SETTINGS und wurde standardmäßig mit installiert.. Einfach auf widget Buttons wählen was du haben willst und darunter unter ORDER welche Reihenfolge du haben willst.. :)
Und ich hab verzweifelt in den Einstellungen gesucht....danke Dir, hat funktioniert!!!!
Also irgendwie läuft die Rom bei mir nicht so flüssig wie zum Beispiel die omega habe immer Mikro Ruckler wenn ich irgendwas mache und dann sich irgendwas Aktualisiert oder smart Stay gerade kontrolliert.
Oder auch beim Öffnen der Galerie
Liegt das vielleicht am Siyah Kernel?
Gesendet von meinem GT-I9300 mit Tapatalk
gibt es jetzt eig. ein Unterschied ob ich den Stock kernel oder die siyah kernel verwende?
Android_Noob.
Droid228
Droid228
borisbecker01
borisbecker01
